Homework Help: Calorimetryis my answer right
  1. Aug 7, 2009 #1
    A 0.10 kg piece of copper at an initial temperature of 95°C is dropped into 0.20 kg of water contained in a 0.28 kg aluminum calorimeter. The water and calorimeter are initially at 15°C. What is the final temperature of the system when it reaches equilibrium?
    M(w) = 0.20kg
    Cp,(w) = 4186J/kg°C
    M(Al) = 0.28kg
    Cp,(Al) = 899J/kg°C
    T(w) = T(Al) = 15°C
    M(Cu) = 0.10kg
    Cp,(Cu) = 387J/kg°C
    T(Cu) = 95°C
    I'm confused because usually there is just the water and the substance, but now theres the aluminum calorimeter to account for. I'm not sure what to do..do I still use the Qw= -Qx approach? If so, do I add the aluminum info to the water info...someone else seemed to do it that way, but he and i got answers differing by about 1 degree.
    2. Relevant equations
    -Q(Cu) = Q(Al+w)
    3. The attempt at a solution
    [cp(cu)] [M(cu)] [ΔT(cu)] = [cp(al) + cp(w)] [M(al) + M(w)] [ΔT(al and water)]
    (-387)(0.10)(Tf-95) = (899+4186)(0.28+0.20)(Tf-15)
    Tf=16.77 degrees C
    **Before, I made the right side negative (Q al+W) and got 16.25, almost the same thing, so I don't know if that matters, or if I did the math wrong. Anyhow, is my above work correct?
  3. Aug 7, 2009 #2
    YES!
    Not quite. Instead, use a different term for the contribution of each. Try this:
    -Q(Cu) = Q(Al) + Q(w)
    -[cp(cu)] [M(cu)] [ΔT(cu)] = cp(al)M(al)[ΔT(al)] + cp(w)M(w)[ΔT(w)]
    The water will gain heat energy. The aluminum cup will gain heat energy. Both will start at the same T (15 degrees, in this case), and both will end at the same temperature (the equilibrium temperature you are trying to find). In other words, ΔT(w) = ΔT(al).
