Can 3 forces of 9N, 4N, and 6N be in equilibrium?
In summary, the mass is initially in equilibrium, but is suddenly forced to accelerate due to the removal of the 9N force.
MattDutra123
A mass of 3kg is acted upon by three forces of 4.0 N, 6.0N, and 9.0N and is in equilibrium. The 9N force is suddenly removed. Determine the acceleration of the mass.
F=ma.
My main problem with this question is that I cannot think of any situation in which these three forces would be in equilibrium. The question does not specify in which direction the forces are in or any angles (in the case of an inclined plane). How can these forces possibly be in equilibrium?
Welcome to the PF.
Well, 4+6=10 > 9, so it should be possible. Just think of ways that the sum of the x-components and the sum of the y-components can both be zero. Draw a diagram and write the two equations, and see if you can solve for the relevant angles... Please show us your sketch (use the UPLOAD button) and write out your equations. Thank you. :smile:
You could think of it in terms of the 4 and the 6 acting together to cancel out the 9. Is that possible?
Suppose the 4 N and the 6 N act together in the same direction. What is their resultant force? What happens if you use that force to oppose the 9 N force?
Suppose the 4 N and the 6 N act in directly opposite directions. What is their resultant force? What happens if you use that force to oppose the 9 N force?
If the 4 N and 6 N are at an angle relative to each other, the situation will be in between those two situations.
You can the law of cosines to compute what angle the 4N and 6N need to be relative to each other to make a resultant of 9N.
Just to point out that this is not necessary to solve the problem.
The main thing, as has been pointed out is that the forces can be in equilibrium given appropriate angles between them. What does this tell you about the resultant of the 4 N and 6 N forces?
Are you familiar with a "triangle of forces" in equilibrium? Can you draw a triangle with sides of those lengths?
Likes MattDutra123, Charles Link and berkeman
You are thinking too hard. If the system is in equilibrium, then a = 0. You also know F = 0 and F is the sum of the forces. So if you remove one force you should be able to calculate the new sum of forces and therefore the acceleration.
Likes MattDutra123
I've never studied forces beyond high school, so I've never encountered problems like this but, unless I miss my guess, this seems to require nothing more than basic arithmetic.
That is the neatest way to solve the given problem, yes, but the OP's question in the forum is a little different.
1. Can you explain what equilibrium is?
Equilibrium is a state in which all forces acting on an object are balanced, resulting in a net force of zero and no change in the object's motion or position.
2. How do you determine if three forces can be in equilibrium?
To determine if three forces can be in equilibrium, we must calculate the vector sum of the forces. If the sum is equal to zero, then the forces are in equilibrium.
3. What happens if the three forces are not in equilibrium?
If the three forces are not in equilibrium, there will be a net force acting on the object, causing it to accelerate in the direction of the net force.
4. Can the magnitude of the forces affect whether or not they can be in equilibrium?
Yes, the magnitude of the forces can affect whether or not they can be in equilibrium. If the forces are not equal in magnitude, they may not be able to balance each other out and result in a net force.
5. Is it possible for three forces of different directions to be in equilibrium?
Yes, it is possible for three forces of different directions to be in equilibrium. As long as the vector sum of the forces is zero, they will be in equilibrium, regardless of their directions.
