Can grandpa understand the Bell's Theorem?
In summary, the Bell's Theorem has a correlation between results that is explained by quantum mechanics.
  • #386
miosim said:
I don’t fully understand |H> and |V> polarization and the difference between Type I PDC and Type II PDC. I need to do some homework on my own prior to continue.
|H> and |V> just refer to the orthogonal (i.e. perpendicular) directions "horizontal" and "vertical", which are always the two basis states for polarization. What changes is the starting angle in the laboratory frame. In other words, you can say that 0º in the lab frame defines |V>, then 90º defines |H> ... if 25º defines |V>, then 115º will define |H>, and so on .. just as long as they are always perpendicular. The way I used them in my last post .. |H> and |V> were the polarization basis for the photons as they came out of the source. As I indicated, that defines a basis that is "special" in the case of your gedanken #2, but is essentially irrelevant for gedanken #1.
Check Dr. Chinese's site for study materials on PDC crystals, and the rest of this stuff.
  • #387
miosim said:
If I understand you correctly, the correlated (vs polarization-entangled) photons in the gedanken experiment #2 do NOT follow the cos^2 correlation while per my understanding of EPR phenomenon they SHOULD follow the cos^2 correlation. This could mean that the gedanken experiment #2 may falsify the Bell’s theorem. Do you think that it is worth to try this experiment?
The EPR state IS the entangled state. There is no difference. What you specify in your #2 is completely different because you specified they are NOT polarization entangled. If they are not polarization entangled, they are not in an EPR state on that basis.
And of course this experiment HAS been performed many many times*. I doubt anyone would bother to write up such a result for fear of being laughed at, but who knows? (You are certainly welcome to try it yourself.)
*How do I know this? Every scientist who uses Type I entanglement MUST do it when properly aligning the crystals. They start with 1 crystal (which is your #2) and then add the second (which is your #1). The stats change as they are getting the second in place.
  • #388
Just to be completely clear, the case we have been discussing for case #2 has a source with the following characteristics: (I was assuming type II PDC, but I don't think that changes the argument).
1) It emits counter-propagating beams of paired (i.e. time-coincident) photons A & B that are NOT entangled
2) The polarization of photon A is always randomly chosen to be |H> or |V>
3) The polarization of photon B is always guaranteed to be anti-parallel to that of A
I don't think such a source has been created. I believe that the type I PDC with only a single crystal produces a pair of photons with a single, known polarization relationship (i.e. |HA>|HB>). In other words, every pair of photons has that relationship between their polarizations. If you choose a different orientation for the crystal, you could also get all pairs having |VA>|VB>, but you never get a mixture of the two, so that is not quite the same thing as we were discussing. Right?
As I commented earlier, I don't think a source corresponding to the properties 1-3 can be created without generating entangled photons ... it might be theoretically possible, but I don't think the time coincident property in point 1 can be guaranteed unless the photons are generated in the same process, and are therefore entangled.
  • #389
miosim has an incorrect idea of what an EPR state is, which is leading to the problem here. We will need to assist in him gaining this understanding.
miosim: The EPR state is defined as follows: "if, without in any way affecting Alice, you can predict an outcome of any (polarization) measurement on Alice with certainty..." Does this make sense to you?
In other words: if the polarization is known, then you cannot have the EPR state. (Well, I guess you could if we lived in a universe with different physical laws.) That is because when you have HH>, for example, you do NOT have H'H'> except where H' is either V or H. So, at H' = 45 degrees, there is only random correlation between Alice and Bob. Obviously, in such case you cannot predict Alice's outcome with certainty. You would just be guessing, and that is not what EPR specified as being an element of reality.
  • #390
DrChinese said:
… The EPR state is defined as follows: "if, without in any way affecting Alice, you can predict an outcome of any (polarization) measurement on Alice with certainty..." Does this make sense to you?
This is the deterministic and as I think the misleading interpretation of EPR. However to defend my point Iit may take a separate thread. Instead I will refer to J. Bell’s “Bertlmann’s Socks and the nature of reality” where he mentioned that “… There is a widespread and erroneous conviction that for Einstein … determinism was always the sacred principle….”
It is why I prefer to use the interpretation of EPR as it was stated in the original paper (1935) according to which correlated particles after separation:
“… are no longer interact, no real change can take place in the second system in consequence of anything that may be done to the first system… thus it is possible to assign two different wave functions… to the same reality …”
  • #391
miosim said:
...It is why I prefer to use the interpretation of EPR as it was stated in the original paper (1935) according to which correlated particles after separation:
And that was a wrong statement from EPR, as we now know (but was NOT clear then). For particles in a state of superposition, there is only one wave function. Please recall that the whole point was that the results must be predetermined (FAPP) if Alice and Bob get the same answers to the same questions every time (with "certainty") without otherwise communicating.
  • #392
Isn't "predetermined" a special, limiting case of "determinism"? As we know from Bell's "Bertlmann's socks", perfect certainty is not claimed and determinism is not the essential point. The essential point is locality, as EPR also stated.
  • #393
SpectraCat,
I took some time to better undersatnd the following post.
SpectraCat said:
I would like to verify that I understand you correctly prior to continue. I think that now I am on the same page with you regarding therminology of CORRELATION and ANTI-CORRELATION that applies to the SAME or OPPOSITE (90 deg shift) polarisation. Also, the “cos^2” isn’t a correlation (as I called it before) but the “joint detection probability” that allows to calculate the “correlation coefficient.”
SpectraCat said:
…you CAN get the cos^2 correlation for gedanken #2, but ONLY for one choice of detection basis, namely the original polarization basis for the photons. In other words, if you keep the A detector set at 0º relative to the original polarization basis (the |H> and |V> polarization defining the entangled state as it was emitted from the source), then you will get cos^2 as you rotate the B detector angle from 0º to 90º.
Do you mean that in this case we simply abserve the Malus’ law?
SpectraCat said:
…However, if you start with A and B both at the same random angle (say 79º) with respect to the original polarization basis, and then rotate B from 79º to 169º then you will not get a simple cos^2 relation anymore.
Is it beause in the gedanken experiment #2 the photons are unentangled (polarisation corelated but fully independent)?
  • #394
miosim said:
SpectraCat,
I took some time to better undersatnd the following post. I would like to verify that I understand you correctly prior to continue. I think that now I am on the same page with you regarding therminology of CORRELATION and ANTI-CORRELATION that applies to the SAME or OPPOSITE (90 deg shift) polarisation. Also, the “cos^2” isn’t a correlation (as I called it before) but the “joint detection probability” that allows to calculate the “correlation coefficient.”
Yes.
Yes, for measurements in the polarization basis in which the non-entangled pair was initially generated, and for that basis ONLY, you can get the Malus' Law relationship. On the other hand, for entangled photons, you see the Malus' Law relationship in whatever measurement basis you choose. That was the experimental observation of Aspect which led to the Bell's inequality violation, which has subsequently been re-tested and improved upon by other groups.
Yes, precisely.
  • #395
http://plato.stanford.edu/entries/qt-epr/#1.3 (Einstein's versions of the EPR argument):
“… The central point of EPR was to argue that in interpreting the quantum state functions the real states of spatially separate objects are independent of each other …”
  • #396
SpectraCat,
According to you, in the gedanken experiment #2 we will not get a simple cos^2 correlation coefficient because their photons are non-entangled. According to my prediction the gedanken experiment #2 does produce the cos^2 correlation coefficient, because in my interpretation this result is nothing to do with entanglement (influence over distance). This is why this experiment questions a role (and probably the existence) of the influence over distance that is the most important conclusion of the Bell theorem. This what I mean by saying that the gedanken experiment #2 can falsify the Bell's theorem.
  • #397
miosim said:
SpectraCat,
Well, with all due respect, I can only say that is because you do not understand the underlying mathematics. There is simply no way that the observed cos^2 dependence can be reproduced (for arbitrary choice of measurement basis), by photons that are not entangled. Your prediction above is not even consistent with classical physics, let alone quantum mechanics. It would be fairly straight forward to set up an experiment with polarized light beams to demonstrate that .. I don't even think you need coincidence counting. Just have two independent sources with polarizers .. one polarizer is set to 0º and the other is set to 90º, and have them synchronized to flip their orientations at random time intervals. Then set up the A & B measurement stations with independent polarizers and simple intensity detectors (much cheaper than the single photon counters used for experiments with entangled photons).
Such a setup is basically identical to your gedanken #2, because you claim that the photons are independent, so being able to pair specific photons by coincidence counting won't make any difference. Comparison of the angle-dependent intensities at detectors A and B will reproduce the local realistic predictions for unentangled photons. You certainly will not see a cos^2 relationship that depends only on the relative angle between A and B. If you think differently, please explain why in the context of this experiment, which is much easier to understand and analyze.
  • #398
It is true that I do not understand the underlying mathematics of the cos^2 correlation coefficient predicted by the QM.
However I treat QM as an empirical theory that predicts the outcome of the measurements; everything else is interpretation. In this particular examples, the claim that cos^2 correlation coefficient is caused by entanglement is just an interpretation of this result.
Can you rule out that it is possible to produce the same prediction (cos^2 correlation coefficient) using the QM model of the two independent wave functions?
I don’t expect that my prediction is consistent with classical physics, because, as I understand, Gedanken experiment #2 is within QM domain (regardless that I am not in an agrement with the traditional views on the wave function collapse).
SpectraCat said:
It would be fairly straight forward to set up an experiment with polarized light beams... I don't even think you need coincidence counting. Just have two independent sources with polarizers ... one polarizer is set to 0º and the other is set to 90º, and have them synchronized to flip their orientations at random time intervals…
Agree.
SpectraCat said:
… Then set up the A & B measurement stations with independent polarizers and simple intensity detectors (much cheaper than the single photon counters used for experiments with entangled photons). Such a setup is basically identical to your gedanken #2, because you claim that the photons are independent, so being able to pair specific photons by coincidence counting won't make any difference. Comparison of the angle-dependent intensities at detectors A and B will reproduce the local realistic predictions for unentangled photons. You certainly will not see a cos^2 relationship that depends only on the relative angle between A and B. If you think differently, please explain why in the context of this experiment, which is much easier to understand and analyze.
In general I agree with you. I do expect that the simple intensity detectors may be enough. However, because I don’t understand the underlying mathematics, I can’t be confident that the intensity measurement is equivalent to a correlation coefficient. It is why in my gedanken experiment #2 I try to limit the difference between Aspect’s and my experiments to the entanglement only.
  • #399
P.S.
Actually in the setup you described, if the source of photon beam is polarized, the intensity at each detectors will follow the cos^2 of the angle of the corresponding detectors, independently of the detector angle on other side. But this wouldn't prove anything.
  • #400
Yes, that was their incorrect argument.
  • #401
miosim said:
SpectraCat,
Basically, you are making an incorrect prediction for an experiment that has already been performed and yielded different results. Also, yours is NOT the classical prediction. It is just something you made up out of thin air with not the slightest justification or mathematical derivation. You may as well claim that your prediction is .758401 and state that performing the experiment will falsify Bell. Which it wouldn't. It would "only" falsify QM.
  • #402
Can you collaborate about disprove of EPR argument?
DrChinese said:
Basically, you are making an incorrect prediction for an experiment that has already been performed and yielded different results…
Can you please describe this experiment?
DrChinese said:
… Also, yours is NOT the classical prediction.
What does classical prediction mean? …
My prediction is based on the same mathematical derivation as prediction for Aspect's experiment, but on the different interpretation of events; in my interpretation the cos^2 correlation coefficient is nothing to do with non-local interactions.
Can you demonstrate that this mathematical derivation is based on non-local interactions?
  • #403
miosim said:
Can you collaborate about disprove of EPR argument?Can you please describe this experiment?
This has already been done many times in this circular thread. After 400 posts, if you don't know that Bell's Theorem is a disproof of EPR, I really don't know what to tell you. As to the experiment, I have told you previously that I don't have a reference and don't know any reason there would be one. Maybe you will be the first to write up this null result.
  • #404
SpectraCat said:
[tex]\Psi=(|H_A>\otimes|V_B> + |V_A>\otimes|H_B>)[/tex]
Is there anywhere online where I could get an introductiton to that notation? (or if not online, a good introductory text?) I had one professor that called it "bra" "ket" notation, and usually <A|, the "bra" represented an operator, and |B> represented a "ket" which was some numerical value or vector or matrix.
But I can't find anything under "bra ket notation," so I guess that terminology isn't in common usage.
Anyway, when I last posted to this thread, I was wondering whether somehow the [tex]|H_A> , |H_B>[/tex] notation referred somehow to matrices, for instance
|H_A>=\begin{pmatrix}
cos(\theta_A )\\
sin(\theta_A)
\end{pmatrix}?
But with the multiplication [tex]|H_A> |H_B>[/tex] of course, matrices can't be multiplied that way, but you introduced a new operator here: [tex]\otimes[/tex] which might resolve it?
  • #405
cos(\theta_A )\\
sin(\theta_A)
\end{pmatrix}?
It is called Dirac notation, or bra-ket notation. The wikipedia page is a decent place to start for an intro. The [itex]\otimes[/itex] is just used to indicate that the state is composed of two "kets" (i.e. vectors) from different vector spaces. For example, if you treat a molecule in the Born-Oppenheimer approximation, you could write it's total wavefunction as a composition of the electronic and vibrational wavefunctions (there are other contributions which might also be important), which are solved independently.
It does not make sense to write the product of two kets from the same vector space (i.e. |m>|n> is non-sensical), so the [itex]\otimes[/itex] is useful to make explicit that the two states come from different vector spaces. Note that the notation for the dot product of a bra and a ket vector (<m|n>) does NOT combine vectors from the same space. The space of bra vectors is "dual" to the space of "ket" vectors, but is not identically the same. For example, you might write the position space representation of some ket |n> as the wavefunction [itex]\psi_n(x)[/itex] ... in that case, the position space representation of the bra <n| that is dual to |n> would be the complex conjugate of the same wavefunction ... i.e. [itex]\psi_n^*(x)[/itex].
Hope this helps.
  • Quantum Physics
  • Quantum Interpretations and Foundations
11K
  • Quantum Physics
  • Quantum Physics
25
30K
  • Quantum Physics
