Does Heat Truly Get Trapped in the Earth's Atmosphere?
In summary, the atmosphere traps heat from the sun, and the further up in altitude you go, the colder it gets.
mtanti
172
Here is my theory:
Once heat radiation enters our atmosphere from the sun and gets absorbed by the material inside, it is emmitted back as conduction/convection. In order for this heat to travel it needs a medium such as air. Now isn't it true that once this heat reaches the border between atmosphere and space it stops?
Therefore this would be an explanation for global warming since most of the heat entering the atmosphere gets blocked inside, regardless of carbon dioxide. It would also explain why the further up in altitude you go the colder it becomes, because the density of air goes down the higher you go. Therefore there would be less possibility for heat to travel upwards since the space between 2 neighbouring air molecules increases.
Am I correct?
Science news on Phys.org
Besides conduction and convection, there is radiation as an energy transport mechanism.
mtanti said:
Here is my theory:
You are already contradicting yourself. How do you think the heat from the sun reaches the earth?
IR radiation also transfers heat. Since it is an electromagnetic spectrum, it requires no medium. Any body that has any heat content will radiate in the IR region.
Zz.
Yes but once it is absorbed by a body it will release the heat as conduction. No? Would there be more radiation than conduction?
It doesn't matter, and it depends on the situation. In any case, anybody with heat content WILL radiate, so there is heat loss even in vacuum, which is sufficient to falsify your idea.
Zz.
That's an improperly worded sentence anyway. "release the heat as conduction" is wrong. Heat is transferred through conduction... and also through radiation.
The atmosphere, through the "greenhouse effect", does indeed trap heat: the sun's radiated heat is centered around the visible to UV part of the spectrum (not sure where exactly) and that radiation mostly passes right through the atmosphere to the ground. When it is re-radiated, it is in the infrared part of the spectrum and the atmosphere is largely opaque to IR radiation. All that said, after eons, the Earth reached a reasonably stable equilibrium temperature.
Think of visible light. Visible light obviously reaches us from the sun. For a long time scientists assumed light must propagate like sound, through a medium. They (usually) called this medium "aether". Relativity was kind of the final blow for aether-theory. Turns out light (a type of electromagnetic radiation) doesn't need a medium. In fact http://physics.uoregon.edu/~jimbrau/BrauImNew/Chap03/FG03_09.jpg" parts of the spectrum). A great deal of this energy becomes heat (how exactly is beyond my understanding - someone else care to fill in?). So Earth is a hot object and like all hot objects will in turn radiate EM (mostly in the infrared band).
No heat energy is lost through conduction.
So once an object receives EM heat, it won't transform it into conductive heat? It will return it back as EM heat (of lower frequency perhaps)?
mtanti said:
(snip)Am I correct?
In a word, "No."
russ_watters said:
(snip)The atmosphere, through the "greenhouse effect", does indeed trap heat: the sun's radiated heat is centered around the visible to UV part of the spectrum (not sure where exactly) and that radiation mostly passes right through the atmosphere to the ground. When it is re-radiated, it is in the infrared part of the spectrum and the atmosphere is largely opaque to IR radiation.
See Rohsenow & Hartnett, 15-76; or, in another word, "No."
Earth's atmosphere has been divided into four layers for convenience in analyses of its physical interactions with the solid, or liquid, surface, solar radiation, and the CMB: these are the troposphere, a convective layer extending from the surface to an altitude of 3-10 km; the stratosphere, a vertically non-convective layer extending from the upper boundary of the troposphere (tropopause) to 30-40 km; the mesosphere (ionosphere); and the exosphere. The temperature gradient in the troposphere is from high, surface T, to low, ca. 200 K at the tropopause, and maintained by adiabatic cooling of rising air masses in convection cells driven by surface heat; the temperature gradient in the stratosphere is from low at the tropopause to high at greater altitudes (plus a few odd inflections, wrinkles, and local minima); the mesosphere and exosphere are low enough in density that we're going to ignore them for heat transport purposes.
Conduction of heat through the stratosphere proceeds from high altitudes to the tropopause; conduction and convection of heat proceed in the troposphere from the surface to the tropopause. That is, heat absorbed from solar radiation at high altitude is conducted to the tropopause, and heat absorbed at the surface is conducted and convected to the tropopause, and some fraction is radiated either to the troposphere, or through the troposphere. Heat convected to the tropopause returns to the surface through adiabatic compression in the downward regions of convection cells; that's what makes the temperate climate zones livable.
Everyone "clear" on the fact that the heat transfer problem is NOT as simple as the kindergarten greenhouse model?
Well ok but still if heat inside the Earth was only conductive than no matter what the atmosphere does, the heat cannot escape it. So is heat absorbed by matter as radiation transferred back to the air as conduction or as another radiation? Which of the two is most?
Heat is heat. It does not come in flavors. It is transferred by convection, conduction, and radiation. If there is NO convective path, it can only be transferred by conduction and radiation. If there are NO convective or conductive paths, it can only be transferred by radiation. So long as an object, or construct (black body cavity) contains heat, it is above absolute zero temperature, and it radiates heat.
"Which is most?" Either --- it depends upon the physical properties of the system you're analyzing (emissivities, heat capacities, thermal diffusivities, expansivities, viscosities) and of its surroundings.
1. Can heat escape the Earth's atmosphere?
Yes, heat can escape the Earth's atmosphere through a process called radiation. This is when heat energy is emitted in the form of infrared radiation into space.
2. Does the Earth's atmosphere trap heat?
Yes, the Earth's atmosphere acts like a blanket and traps heat from the sun, known as the greenhouse effect. This helps to regulate the Earth's temperature and keep it habitable for living organisms.
3. What happens to heat when it reaches the top of the atmosphere?
When heat reaches the top of the atmosphere, it is either reflected or absorbed by the Earth's surface. Some of this heat is then radiated back into space, while the rest is trapped by greenhouse gases in the atmosphere.
4. Can heat from the Earth's surface travel through the atmosphere?
Yes, heat from the Earth's surface can travel through the atmosphere in the form of conduction and convection. These processes transfer heat energy from one place to another through direct contact or the movement of fluids, respectively.
5. What would happen if heat could not exit the Earth's atmosphere?
If heat could not exit the Earth's atmosphere, the planet would become increasingly warmer and eventually become too hot for life to survive. This is known as the runaway greenhouse effect and is a concern for the future of our planet if greenhouse gas emissions are not reduced.
  • Astronomy and Astrophysics
  • Thermodynamics
9K
  • Thermodynamics
  • Classical Physics
