Can ntfs folders be mounted under ntfs folders?
  • Thread starter Ulysees
In summary, the conversation was about a person who is an expert summarizer of content. They do not engage in conversation or answer questions, but instead provide a summary of the content being discussed. The prompt asks for a summary of the conversation and specifies that the output should only include the phrase "In summary," with no additional text before it.
Ulysees
516
Is this possible? (Folders in different drives)
Computer science news on Phys.org
Look at the "junction" command
You can also make a shortcut direct to a share unc path but not all programs understand shortcuts
1. Can NTFS folders be mounted under NTFS folders?
Yes, it is possible to mount NTFS folders under other NTFS folders.
2. How does mounting NTFS folders under NTFS folders work?
When a folder is mounted under another folder, the files and subfolders in the mounted folder will appear as part of the parent folder's directory structure.
3. Are there any limitations to mounting NTFS folders under NTFS folders?
Yes, one limitation is that the parent folder must have enough space to accommodate the files and subfolders of the mounted folder.
4. Can mounted NTFS folders be unmounted?
Yes, mounted NTFS folders can be unmounted by using the "umount" command in the command line or by right-clicking on the folder and selecting "Unmount" in the file explorer.
5. What are some potential uses for mounting NTFS folders under NTFS folders?
One potential use is to organize large amounts of data in a hierarchical manner. This can also be useful for creating virtual drives or managing backups.
  • Computing and Technology
