Homework Help: Can some verify this problem?
  1. Oct 23, 2007 #1
    The problem has to do with laws of cosines/sines.
    "The baseball player in center field is playing approximately 330 feet from the television camera that is behind home plate. A batter hits a fly ball that goes to the wall 420 feet from the camera. The camera turns 6 degrees to follow the play. Approximate the distance the center field has to run to make the catch."
    The diagram given looks roughly like this:
    http://img151.imageshack.us/my.php?image=fieldbu9.jpg
    2. Relevant equations
    There are 3 equations relating to the Laws of Cosines:
    1. a^2 = b^2 + c^2 - 2bccos(A)
    2. b^2 = a^2 + c^2 - 2accos(B)
    3. c^2 = a^2 + b^2 - 2abcos(C)
    3. The attempt at a solution
    At this point the case of this problem is SAS (side side angle). So I know that laws of cosines has to be used here.
    I then labeled the diagram like this:
    http://img525.imageshack.us/my.php?image=field2uv3.jpg
    Givens:
    b=420
    c=330
    A=6 degrees
    a = ?
    a is what needs to be solved.
    I then used equation one since it has the most related givens
    a^2 = 420^2 + 330^2 - 2(420)(330)cos6
    a = [tex]\sqrt{420^2 + 330^2 - 2(420)(330)cos6}[/tex]
    a = 98.07ft
    Thats my approximate answer. Can someone verify it?
  3. Oct 23, 2007 #2
    EnumaElish
    The expression in the root is correct.
  4. Oct 28, 2007 #3
    So is everything correct?
  5. Oct 28, 2007 #4
    Since you are taking the root of a number it should be +-. But negative distance doesn't make sense, but it is something to keep in mind.
Loading...
