Can someone check my lab?
  1. May 9, 2005 #1
    A) A student places a light bulb 30 cm in front of a concave mirror. A real image of the bulb is found 6 cm in front of the mirror. What is the focal length of the mirror?
    my answer was 5 cm
    Given
    do=30cm
    di=6cm
    f=?
    f=dodi/do+di
    f=30*6/30+6
    =5
    B) If a light bulb is place 12 cm in front of a concave mirror with a focal length of 3 cm. How far in front of the mirror will the real image of the light bulb be found?
    my answer was 4 cm
    Given
    do=12cm
    f=3cm
    di=?
    di=dof/do-f
    di=12cm*3cm/12cm-3cm
    =4
    H) How did the location of the image change as you moved the object (light bulb) toward a mirror?
    increased
    I) how did the size of the image change as you moved the object toward the mirror?
    increased in size
    A) A student places a light bulb 12 cm in front of a double convex lens. A real image of the bulb is found 3 cm on the other side of the lens. What is the focal length of the lens?
    my answer was 2.4 cm
    Given
    do=12cm
    di=3cm
    f=?
    f=dodi/do+di
    f=12*3/12+3
    =2.4
    B) A light bulb is place 30 cm in front of a double convex lens with a focal length of 6 cm. How far on the other side of the lens will the real image of the light bulb be found?
    my answer was 7.5 cm
    Given
    do=30cm
    f=6cm
    di=?
    di=dodf/do-f
    di=30*6/30-6
    =7.5
    H) How did the location of an image change as you moved the object (light bulb) toward a lens?
    decreased
    I) How did the size of the image change as you moved the object toward the lens?
    it also decreased in size
    thanks
  3. May 9, 2005 #2
    bump, please I need this checked
  4. May 9, 2005 #3
    please help me out and check
  5. May 9, 2005 #4
    Last bump for the night, hopefully someone helps
  6. May 9, 2005 #5
    ill bump for u
  7. May 9, 2005 #6
    Thanks, hopefully someone sees this.
