Can someone check my Lagrangian ?
  • Thread starter kala
Write down the Lagrangian for a cylinder mass m, radius R an moment of inertia I, that rolls without slipping straight down an inclined plane which is at an angle a from the horizontal. Use as your generalized coordinate the cylinder's distance x measure down the plane from its starting point. Write down the Lagrange equation and solve it for the cylinder's acceleration.
I tried to find the Lagrangian, this is what i have so far, is it right?
i said that T=1/2mv2+1/2Iw2
and U= -mgxsina so my Lagrangian would be
L=1/2mv2+1/2Iw2+mgxsina.
I think this is correct, but I'm not positive. If it is right then should i write I and w (omega) differently? and then continue with the partial differentiation?
Answers and Replies
Everything is correct, except that you must express all the dynamical variables (v, w) in terms of x and its derivatives, as the problem tells you. Also you can explicitly specify the value for I, since you know the shape of the body.
so if i remember right v=x' but i am not sure what I and w are in terms of x and derivatives. doesn't I have something to do with R, the radius?
w is the angular velocity, which for non-slipping case is given by
[tex]\omega = \frac{v}{R} = \frac{\dot{x}}{R}[/tex]
and I hope you can figure out the moment of inertia I yourself.
I= 1/2 m R2?
Just checking before I go on with the partial derivatives.
Yes, for a uniformly filled cylinder.
Related Threads on Can someone check my Lagrangian ?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
