Explaining Approximate pH of a 1 M Solution of NH4Br
  • Thread starter a.a
  • Tags
    Explain
Kb = -log (Kb) is a measure of the strength of a base. In summary, the approximate pH of a 1 M solution of NH4Br can be calculated using the dissociation constant Kb(NH3) = 1.8 x 10-5. By solving for Ka, we can determine the concentration of H+ ions and calculate the pH to be 4.63. The 10^-14 in the equation represents the equilibrium constant for water, and the terms pKa and pKb are measures of acid and base strength, respectively, based on the Bronsted-Lowry theory.
a.a
127
The approximate pH of a 1 M solution of NH4Br [Kb(NH3) = 1.8 x 10-5] is___
Ka(NH4) = 10^-14 / 1.8 x 10^-5 =
=5.5555 x 10^-10
therefore, 5.5555 x 10^-10 = [NH3][H+]/[NH4+]
Since 1 H+ forms for every NH3 that forms and that [NH3] + [NH4+] = 1,
5.5555 x 10^-10 = [H+][H+]/(1-[H+])
Since Ka is small, 1-[H+] approximately = 1
[H+] = 2.357 x 10^-5
ph = 4.63
where did the 10^-14 come from and why are we saying this:
10-14 is Kw.
The other part is about Bronsted-Lowry theory. NH4+ is a Bronsted-Lowry acid. Expression that you have listed is its dissociation constant.
what exactlly is pKa and pKb?
pKa = -log (Ka)
1. What is the approximate pH of a 1 M solution of NH4Br?
The approximate pH of a 1 M solution of NH4Br is around 5.6. This is considered slightly acidic.
2. How is the pH of a solution calculated?
The pH of a solution is calculated by taking the negative logarithm of the concentration of hydrogen ions in the solution. This is represented by the formula pH = -log[H+].
3. Why is NH4Br considered slightly acidic?
NH4Br is considered slightly acidic because it is a salt that is formed from the reaction of a weak acid (NH4OH) and a strong acid (HBr). This results in the solution having a higher concentration of hydrogen ions, making it more acidic.
4. Can the pH of a 1 M solution of NH4Br change?
Yes, the pH of a solution can change depending on factors such as temperature, concentration, and the addition of other substances. However, in a 1 M solution of NH4Br, the pH will remain relatively constant due to the equilibrium between the weak acid and its conjugate base.
5. How does the pH of a 1 M solution of NH4Br compare to other solutions?
The pH of a 1 M solution of NH4Br is relatively low compared to neutral solutions (pH 7) and basic solutions (pH above 7). It is also lower than other ammonium salts, such as NH4Cl, due to the stronger acidity of HBr compared to HCl.
