Can a Fish Move a Ball in Water?
  • Thread starter Immelmann
  • Tags
    Ball
In summary, the conversation discusses the possibility of a fish making a ball roll by swimming in a closed system. It is suggested that if the fish has the same mean density as water, the hamster method will not work, but theoretically it could induce a flow that could spin the ball via friction on the inner walls, resulting in rolling. Other scenarios, such as the fish pointing its nose at a point on the bottom of the ball and swimming vigorously downwards, are also considered. Overall, it is determined that the fish could potentially generate a small net force in one direction, but it would not be a significant enough force to make the ball roll.
  • #71
thanx guys. did not think this was such an involved question. lol. you all went over my head with your techo-language! had to go google some of those words! lol
  • #72
Immelmann said:
not here to think buddy, just get an answer
Ah. Then you have come to the wrong forum. We're not really a Q&A type forum. We take it to be more helpful to teach people how to think on their own rather than spoon feeding them answers. If you really want to just ask a question instead of learning how to figure it out for yourself, there are Q&A forums that will be more effective for you.
Here is a perfect example of what you can expect on this forum:
https://www.physicsforums.com/threads/question-about-pulleys.975458/
Likes davenn, Vanadium 50, Dale and 2 others
  • #73
  • #74
.Scott said:
And what does that have to do with this thread? This thread is about a full sphere, not a half-full one
  • #75
This is basically the same problem as "If a bunch of birds are sitting in a closed container and then start flying around, does the weight of the container change?"
  • #76
Thread has gone somewhat tl;dr but the fish can make part of the water rotate in one direction and the rest of the whole ball rotate in another direction, yes. So it can make the bowl roll.
  • #77
One last idea... The fish is simplified to a powered (both extension and contraction) 2-part telescoping rod of constant volume and same density as water. The fish starts in a contracted state against the “side” of the glass ball 90 degrees from the ball’s contact point with the ground. The fish has constant mass but adjustable frontal area, drag coefficient, and the water’s fluid density is adjustable as well (in different scenarios). A list of the bodies involved are: the glass, the water, the front part of the rod, the back part of the rod and the ground. At 0 time, the back part of the rod, the glass and the water comprise mass #1. The front part of the fish is mass #2. During powered extension of the rod utilizing a certain amount of energy/work against the glass, the front part of the rod acquires kinetic energy relative to the ground. The change in kinetic energy over time of the front part of the fish relative to the ground depends on the front part and rear part of the fish’s mass, acquired velocity relative to ground, frontal area, drag coefficient and the fluid density. If the frontal area and drag coefficient are arbitrarily small, an arbitrarily small amount of energy over time (power) is transferred to the water. Since the front part of the fish acquires kinetic energy relative to ground, and the rear part is extending directly against the glass, as mentioned before rear part of rod, glass and water are M1 and front part of rod is M2. Since M2 acquires momentum in the rod extension M1 acquires momentum in the opposite direction as well via:
##M_1V_1=M_2V_2##
Since the ball (##M_1##) has friction with a point on the ground, the ball can’t slide it must roll instead. If the ball were resting in a tiny dimple at the top of a ramp, perhaps this small initial inpulse might be enough to intiate a roll down the ramp where at the bottom a rocky outcrop beside the ocean offers the fish a potential route of escape from the ball...
  • #78
If the fish changes shape and/or position, the water is constrained to do so as well. The center of mass of the two together does not change. Accordingly, the total momentum of the two together does not change. All of the invocations of kinetic energy and of momentum and all of the equations you may write down do not change this.
Let us formalize a proof.
The ball is full of water with a fish in it. No air bubbles. No voids. The water and fish are of uniform and equal density. The ball is spherically symmetric and also of uniform density. Assume that the ball starts at rest on the floor with the contents also at rest.
If the ball does not leak, it is clear that the center of mass of the fish plus water is always located at the center of the ball. The center of mass of the ball alone is also always located at the center of the ball.
Let ##v_b## be the velocity of the ball and ##v_c## be the velocity of the center of mass of the contents. The fact that they are always co-located allows us to write down an equation:
$$v_b=v_c$$
Suppose that there is no net external force on the ball plus contents. Then momentum of the ball+contents system is conserved.
$$m_b v_b+m_cv_c = 0$$
But since ##v_b## and ##v_c## are equal, we can substitute in one for the other yielding
$$m_b v_b + m_c v_b = 0$$
$$(m_b + m_c) v_b = 0$$
Unless both ball and contents are massless, it follows that ##v_b = 0## and then that ##v_c = 0##.
Conclusion: The only way the ball moves is if you can contrive to get an external force to move it. This is do-able as has been described earlier.
Likes Vanadium 50
  • #79
Isn’t the force M1 transfers to the water defined by ##F=(1/2)C_d*rho*A_f*V^2## meaning you can adjust it by reducing the frontal area and/or drag coefficient?
  • #80
No, it's not.
Likes russ_watters
  • #81
It's all a connected system. Every force you can think of between fish, ball and water is internal to the system. You cannot get a net input of momentum using internal forces. That's Newton's third law in action.
  • #82
Ahhh. I interpreted "filled" as "filled normally" vs. "filled completely".
That makes it much more difficult. The fish can swim in circles - leaving the water to flow in the opposite direction. The friction between the water and the bowl would push the ball forward. But when the fish stopped, the ball would stop rolling as well - and it would brake to a stop.
Angular momentum must be conserved - but not the angular position. So a displacement in the position of the ball is possible.
  • #83
In the system as previously described, if the telescoping rod pushes with enough work/energy, with low enough frontal area and drag coefficient, there are scenarios in which it can "coast" across the entire glass ball and bump into the other wall after pushing off from the opposite side.
If the ball doesn't roll, and the fish gets enough momentum relative to the ground pushing off the wall to coast horizontally to the other side of the ball, and the fish didn't push off the ground, then what mass acquired momentum in the opposite direction to satisfy ##M_1V_1=M_2V_2##?
(I specify that during the coasting phase, all of the fish's kinetic energy relative to ground is not transferred to the water or ball until it bumps into the other side)
  • #84
A.T. said:
If the fish has the same mean density as water, the hamster method will not work. But theoretically it could induce a flow that could spin the ball via friction on the inner walls, resulting in rolling.
Just like a kid on a swing can go from rest to max swing just by moving his legs.
  • #85
##M_1V_1=M_2V_2##
  • #86
The water, of course. You pushed off against the wall. The wall rigidly encloses the water.
The fish's momentum is transferred immediately to ball and water. It is equal and opposite to the sum of the other two at all times. Kinetic energy is not a conserved quantity. It does not have to be transferred anywhere.
Likes Dale
  • #87
Im having a great difficulty distinguishing any difference in the following 2 scenarios (except that the fish will run into the wall after a certain amount of time in the scenario on the left)...
(In both scenarios the fish uses their tail fin to push directly off the glass)
  • #88
The scenario on the left is incorrect because the fish cannot make the ball move by pushing on it. All it can succeed in doing is making the water within the ball flow backward just enough to match its forward momentum.
  • #89
  • #90
Surely it is easier to ask whether a fish can be made to move in a ball of water by spinning the ball?
I reckon if you roll a ball along the ground full of water , the water and the fish would start spinning. Ergo, the fish just has to swim to oppose that motion, which I am sure they can do, and if so then that would have the counter effect and decelerate the ball, i.e. can move it.
I think the transfer function of momentum between the fish's swimming strokes and ball would be quite limited though (through viscous effects between water and ball), they'd probably get exhausted quickly to get anywhere and if it was filled up completely to avoid the question of a half-filled ball, then they'd suffocate without a supply of re-oxygenated water.
So I'd say, yes ... but don't expect your fish to survive a roll around the garden with you.
  • #91
metastable said:
[nothing but a drawing]
It is not clear what point you are trying to make.
  • #92
I believe this one may be more clear.
I believe you are saying the depiction on the left is not possible if the fish pushes off the glass (all fish water balls are floating in water in the following diagram). So what about the two depictions on the right? On top, the fish pushes off the glass, the fish accelerates, the glass doesn't move at all during the coasting phase of the fish. The energy transferred to the water by the fish per second can be stated (where rho is the fluid density of the water) ##W=(1/2)*C_d*rho*A_f*V^3##, and the fish retains some of the kinetic energy it acquired in the push when it hits the opposite wall. On the bottom right, The energy transferred to the water by the fish per second can also be stated (where rho is the fluid density of the water) ##W=(1/2)*C_d*rho*A_f*V^3##, but there is a hole for the fish to escape and so the glass ball acquires momentum via ##M_1V_1=M_2V_2##.
Is the scenario on the bottom right valid?
  • #93
metastable said:
I believe you are saying the depiction on the left is not possible if the fish pushes off the glass.
Correct.
That one is fine. The ball never moves. Not during the push off. Not during the coasting phase. Not at impact. Never.
There is a hole through which the fish escapes. You have accounted for that momentum flux.
Through that hole water enters. You have not accounted for that momentum flux.
In the external environment there may be pressure changes associated with the circulation that accompanies the motion of fish and displaced water. You have not accounted for that momentum flux.
  • #94
In the depiction on the top right the ball is floating freely except for viscous forces and it isn't connected to the ground. The fish acquires momentum pushing off the glass (not from directly pushing off the water molecules as in typical fish swimming). The fish arrives at the opposite side retaining most of the kinetic energy it had immediately after separation of contact with the glass. Assuming the fish is almost as long as the ball is wide, only a tiny amount of water is displaced on the fish's journey to the opposite side. Since the fish's kinetic energy isn't converted entirely to motion in the water before it hits the other side, then the kinetic energy of the reaction force from the push must have gone somewhere else. The only other place the energy can go is the glass, which can then transfer to the bulk water since there are no voids and water is considered incompressible. Since the glass isn't rigidly attached to the ground it can move. What step in this logic is flawed?
  • #95
All of it. Kinetic energy is not a conserved quantity. You should be working with conserved quantities if you want to reason about where a quantity has to go. Momentum is a conserved quantity.
You also need to be quantitative. "only a tiny amount of water" is not quantitative. If you were working with momentum, it would be obvious that the momentum of the water and of the fish are equal and opposite.
Likes Dale
  • #96
So if the glass has 50% of the mass, the fish has 49.9% of the mass, the water has 0.1%, the fish is long enough that it only moves 0.1% of the ball width to get to the other side (& the water mass is insignificant). The mass of the fish acquires momentum relative to the glass during the push. Suppose the fish has a hole through it so the displacement of the water as it travels through the fish is insignificant compared to the displacement of the fish. So if the fish acquires momentum, and the water mass and displacement during the push is insignificant, what else acquires momentum to satisfy ##M_1V_1=M_2V_2## if not the glass (until the fish reaches the other side)?
  • #97
metastable said:
the water mass is insignificant.
Don't just say it. Show it. Hint: you cannot.
Likes Vanadium 50
  • #98
I struggle to see how it's any different from the following scenario:
2 flatbed train cars, one with a open topped fish aquarium secured to the deck, the other has a crane arm, with a robotic water density fish on a water density pole that can reach over and position the tail of the fish against a side of the aquarium on the other carriage, then the crane arm is locked in position on the other carriage. A special cover and seal on the top of the aquarium ensures the robotic arm can move through the water without significantly displacing the water surface. The robotic fish delivers a push on the side of the aquarium on the other car. Both cars move briefly in opposite directions until the fish crashes into the opposite side of the aquarium. During the time both cars are in motion, why is it not equivalent to the fish pushing directly off the wall inside the ball causing the ball to roll a brief and limited distance in the opposite direction as the motion of the fish?
  • #99
metastable said:
Snip Rube Goldberg scenario.
You have a robotic arm applying a force to a fish in a tank and you do not see that this is an external force?!
  • #100
The batteries and motor are within the fish and equivalent to the fish's muscles.
  • #101
If the arm extends outside the tank then you have an external force. At this point, your responses are going well past tiresome and silly into the arena of obnoxious.
  • #102
The point was the center of mass within the tank doesn't change but both carriages still derive thrust. Changing the center of mass within the tank isn't necessary for both carriages to move in opposite directions.
  • #103
The fish swims in a circle near the middle of the bowl. To balance the angular momentum, the remainder of the water and bowl turns in the opposite direction.
  • #104
metastable said:
Changing the center of mass within the tank isn't necessary...
Nobody says it is. See post #5 and #103. They show how to do this with a closed rigid container without changing the center of mass relative to the container.
But your robotic arm violates the closed rigid container condition, so it's trivial.
  • #105
metastable said:
...the fish crawls with its fins along the edge of the glass, applying tangential force directly to the glass via the friction with its fins. the “normal force” holding the fish against the glass in this case would the fish’s forward velocity combined with the curvature of the glass...
jbriggs444 said:
This is a workable mechanism. Simplify and turn the fish into an octopus that attaches its tentacles to the wall and pulls itself along. The result is that we have the fish (and water due to viscous drag) rotating one way and a resulting torque tending to rotate the ball the other.
It's already been acknowledged that the fin action on the right circled in red (applying tangential force directly to the glass via the friction with its fins) causes the ball to roll.
Can someone explain why the fin action circled on the left (applying direct force with its fin against the left side of the ball) is not exactly equivalent to applying tangential force via friction with its fin at the top of the ball?
  • Mechanics
