Can a 747 Take Off on a Conveyor Belt?
  • B
  • Thread starter RandyD123
  • Tags
    Plane
In summary: The plane will take off. Wheel speed is not even relevant as long as there is sufficient engine thrust to push the plane forward with respect to the air. The plane doesn't even need wheels, pontoons will do just as well.
  • #106
sophiecentaur said:
... but I read it as ...
The whole thread in five words.
Likes jbriggs444
  • #107
But I, personally, have been declaring how I read it. I think many of the loopy contributions have not ever stated their full case. 'It stands to reason' is never a full case.
I think we should demand that answers should include how the OP has been actually understood by the contributor and, where appropriate, some reference of book work. Some of the assumptions in this thread have been so 'intuitive'.
  • #108
If you chase back the sub-thread to which you responded, you will find.
willem2 said:
Actually, If you accelerate the conveyor fast enough, it can stop the plane!
@willem2 proceeded to perform a computation containing actual physics and arrived at a figure for how fast the conveyor would need to accelerate rearward so that the friction required to spin up the wheels to match the conveyor speed would match the forward thrust of the aircraft engines.
I then responded with agreement that..
jbriggs444 said:
result is in the right ballpark and results in the wheels reaching their rated max speed in a fraction of a second.
To which you responded that you did not see how it followed.
Looks to me like it follows.Now @willem2 did not quote the post to which he was responding, but his post immediately followed one by @TurtleMeister:
Barring obvious physical constraints, such as tire maximum ratings, the conveyor direction and speed has no bearing on whether the plane can take off or not.
@willem2's post seems to be on-point in a rebuttal of this claim. [Arguably a rebuttal which was already accounted for under the "obvious physical constraints" exception].
Edit to add a final clarification:
None of this should be read as disagreement with your (@sophiecentaur) sound advice to state assumptions first and calculations after.
  • #109
We are clearly at cross purposes here. I realize you are not a total loony (just enough to want to contribute as regularly as I do on PF!) by the sentence:
RandyD123 said:
The conveyor best is designed to exactly match the speed of the wheels, but run in the opposite direction
If you are suggesting that means to drag the wheels back so fast that they lock up and drag the plane backwards then what you are claiming will follow.
But I do not understand what 'matching' means, in your interpretation.
The way the original question uses 'matching', surely implies that the linear speed of the conveyor would be equal and opposite to what would be the tangential speed of the wheel if it were on the ground. That is actually equal and opposite to the instantaneous speed of the plane over the ground. I have made that clear more than once. Are you saying that is the wrong interpretation? The wheels are free to rotate - just as if it were on ice, in an ideal case. No force (lateral) is exerted on the plane, even if you move the ice backwards.
  • #110
I think that sub-thread you reply to is not about guessing what "matching" means anymore, but simply asking what would the belt have to do, in order to stop the plane based on rotational inertia of the wheels.
Likes jbriggs444
  • #111
Sorry, I missed this last line of the post.
But I still take issue with the requirement to accelerate things in a fraction of a second. The air speed of the plane is the variable that determines what the conveyor needs to be doing.
  • #112
A.T. said:
I think that sub-thread you reply to is not about guessing what "matching" means anymore, but simply asking what would the belt have to do to stop the plane, based on rotational inertia of the wheels.
That could be true but what a fruitless conversation, in the light of almost absolute ignorance of the values of all the variables involved. I would totally agree that the experiment is a nonsense but it is scaled down very easily with a low speed prop aircraft and the Physics point is proved.
Like I said earlier, how easy is it to stop a bicycle by back-pedalling with a freewheel hub?
  • #113
Here's the op:
RandyD123 said:
Imagine a 747 sitting on a large conveyor belt, as long and as wide as the runway.
The conveyor best is designed to exactly match the speed of the wheels, but run in the opposite direction.
CAN THE PLANE TAKE OFF?
The op is not clear, and in my opinion, is the cause of the confusion. So here is my interpretation, the way I think it should be stated:
Imagine a 747 sitting on a large conveyor belt, as long and as wide as the runway. The conveyor belt is designed to match the normal takeoff speed of the aircraft but in the opposite direction. Can the plane take off?
I think this is the interpretation used in the Myth Busters video.
  • #114
The tire wheel speed is not really related to what the plane needs to fly; over 100mph of wind to make the lift. The plane will have no care for tire wheel speed. If there was a gale of 160mph, then it would be possible for the 747 to hover over a fixed position with respect to the ground. Planes don't have care for ground speed, but rather air speed is what they crave.
Likes sophiecentaur
  • #115
Reductio Ad Absurdum.
You persist in arguing against the perceived conclusion (the absurd requirement) instead of the real conclusion (that the interpretation that led to that requirement was unintended or that the problem is badly posed).
Likes sophiecentaur
  • #116
sophiecentaur said:
From OP:
How does that follow? The wording in the OP is a bit vague but I read it as meaning that "match" means the conveyor surface always goes backwards at the same speed as the wheels are going forward (i.e. the bearings and the rest of the plane).
The problem I have with that interpretation of the intent of the question is the equivalent of asking that if you put a car on a treadmill that travels backwards at the same speed as the car is moving forward relative to the ground, can the car move forward? It is a bit nonsensical, because the car moves forward as one of the initial postulates of the problem. It just seems more reasonable that the problem is assuming that the treadmill moves backwards at the same speed as the tread of the wheels move relative to the car or plane. Now you can reasonably ask whether or not the car or plane can move forward.
  • #117
But it isn't th3e same thing at all. In the car scenario, the motion of the car is determined entirely by the power delivered via the wheels. Forces on the wheels are an essential part of the propulsion. If the 'road' moves backwards at the tangential speed of the wheels, the car goes nowhere. That is just not the case with an aeroplane.
You can't include them in the same model. What drives the car forward? What drives the plane forward?
I suggested earlier that people in doubt should draw a free body diagram. Is the force on the plane in any way dependent on the wheels (in the absence of friction losses)?
I was all ready to drop this and I read your post. It's just not right.
Likes Nidum and jbriggs444
  • #118
But isn't that point? In the case where the treadmill moves at the same speed as ground speed, the results are the same for car and plane. When it's the same speed as tangential speed of the wheel, then obviously the car doesn't move relative to the ground as it is propelled by the wheels. The plane is not propelled by its wheels and the problem becomes more reliant on the constraints applied. Since the intent of the question is to present a perceived conundrum. It does not seem likely that the scenario with the trivial answer is what was meant
  • #119
This is just more over analysis. You can keep changing the goalposts for another 119 posts but who will it help? The original question was obviously about the simplest case. Why not deal with just that?
Likes Nidum
  • #120
I can't believe this is still under discussion.
It doesn't matter what the wheels are doing - it's not a car.
A plane gets its forward motion via the air, using props or jets.
Once the thrust of the engines rises, the plane will accelerate with respect to the air - and eventually gain lift via air, as usual - no matter what the wheels are doing.
You can do whatever you want with the conveyor - move it as fast as you want - till the wheels blow, and the landing gear is worn down to nubs - the plane is still going to move forward, given sufficient thrust.
Full stop.
Likes sophiecentaur, Nidum and boneh3ad
  • #121
Full stop.
To clarify, it would matter slightly if only because the faster the wheels are turning, the more rolling friction the plane would likely experience, but this would only affect the rate at which the plane accelerates and would be very small compared to the overall thrust. I'd imagine that the wheels would simply catch fire and melt long before they moved fast enough to provide enough frictional force to stop the plane moving forward.
So yes, I fully agree (as I stated like 5 pages ago) that the rotation of the wheels is largely irrelevant because the engines, and therefore the forward force, really don't care what the wheels are doing. They only care about the air.
I feel like this thread has jumped the shark.
Likes Nidum
  • #122
Lol... all in fun... :oldbiggrin:
OCR said:
Now...
Carry on.
[Edit to add a final clarification:]
"If you’re desperate to tell me that I’m wrong on the internet, don’t bother.
I’ve snuck onto the plane into first class with the #5 crowd and we’re busy finding out how many cocktails they’ll serve while we’re waiting for the treadmill to start.
God help us if, after the fourth round of drinks, someone brings up the two envelopes paradox." [1]
1[Source attribution]
Oh, and BTW... has anybody looked here ? [COLOR=#black]...[/COLOR]
OCR said:
[End of edit to add a final clarification:]
Now...
Carry on.
  • #123
+25
Yes - it's that simple .
  • #124
DaveC426913 said:
...till the wheels blow, and the landing gear is worn down to nubs - the plane is still going to move forward, given sufficient thrust.
But... but... with a landing gear worn down to nubs, will the thrust be sufficient to reach take off speed within the length of a normal runway?
  • #125
Yes you CAN! This is PF :wink:
Likes davenn
  • #126
Then we no longer have wheels and the question no longer applies.
Likes DaveC426913
  • #127
Oh my stars & garters - XKCD has a forum??
Where have you been all my life?
Likes sophiecentaur
  • #128
OCR said:
Oh, and BTW... has anybody looked here ? ...
And with that, I think we can call this thread done. Thanks for helping out, folks. :smile:
Likes sophiecentaur
  • Other Physics Topics
  • Classical Physics
  • Mechanical Engineering
