Can We Move Earth? Physics Explored
  • Thread starter Gughanath
  • Tags
    Earth
In summary, the recent 9.0 earthquake near Thailand altered the Earth's orbit by a tiny amount (shift in the center of gravity of the earth). Like Jeff stated; it is possible to move the Earth a tiny bit by simple movments, but the Earth will gradually move back to the original orbit.
Gughanath
118
This might be a weird question, but hey, that's what physics is all about!
Say everyone in the whole world jumped as high as they could at the same time, would the Earth move??
A little
Assuming the people who did the jumping were more or less in one hemisphere and NOT equally distributed , I suppose the answer is yes but it would certainly not be much and it is not permanent.
Imagine someone standing on the Earth on a plate under which is a powerful spring. The spring is triggered and the person accellerates upwards -- the Earth also accellerates downwards ( in the sense of opposite). But due to the mass of the Earth it moves a lot less -- At some point if the person does not reach escape velocity , then the very same force which the spring overcame will bring them together again - but when he hits the Earth all the energy of the spring will be dissipated as heat , in which case everything returns to normal except the original stored energy in the spring has gone in a slight gain in local temperature .
At least that's my Holiday theory.
Ray.
The Earth's motion would indeed be affected because the Earth's rotational inertria would change. But you don't even have to have a situation as elaborate as all that. It's also a fact that you alter the motion of the Earth simply by walking! When you walk a frictional force develops between the Earth and the bottom of your feet. The force exerted on you by the Earth propels you forward, and the equal and opposite force exerted on the Earth by your foot pushes the Earth backwards (it also exerts a torque about the center, to complicate matters even further).
Tidal actions from the ocean are slowing down the Earth's rotation.
The recent 9.0 earthquake near Thailand altered the Earth's orbit by a tiny amount (shift in the center of gravity of the earth).
This is true, unless we where to be hit so hard that the Earth actually detacthed from the orbit. Isn't it also true that a butterfly landing on a tree moves all particles around it and causes a domino effect therefor moving all of the matter in the universe?
:approve: :approve: :approve: :approve: :approve: :approve: :approve: :approve: :approve: :approve: :approve: :approve: :approve: :approve:
I like the thought. The only thing is will the butterfly have an affect on anything that will change the course of the univeres' destiny, or was this the destiny predetermined and the butterfly could not have not land on the tree?
And the Earth can be moved but moving it either way will do one thing, just by two different paths, kill us.
path A We go on a path straight into the sun (well the path will still orbit the sun)
path B We go on a path and freeze as we leave the only orbit around the sun that it is hot but not to much as we travel away from the sun
So why would it matter if we could or couldn't. Let us not try to find out. OK!
1. Can we physically move the entire Earth?
Technically, yes, we can move the Earth. However, the amount of energy and resources required to do so would be astronomical and far beyond our current capabilities. It would also have severe consequences for the planet's orbit and rotation, making it an unfeasible and dangerous idea.
2. What would be the impact of moving the Earth on its orbit and rotation?
Moving the Earth would have significant consequences on its orbit and rotation. The planet's orbit around the sun and its rotation on its axis are delicately balanced, and any significant changes could result in devastating effects on the climate, weather patterns, and life on Earth.
3. Is there a way to move the Earth without causing harm?
Currently, there is no known method to move the Earth without causing harm. Even small changes to the planet's orbit or rotation can have severe consequences, so any attempts to move the Earth would likely result in significant damage and disruption to the planet's systems.
4. Can we use technology to move the Earth?
While technology has advanced significantly, it is not yet at a level where we can move the Earth. The amount of energy required to move such a massive object is currently beyond our capabilities, and there are no known technologies that could achieve this feat without causing serious harm to the planet.
5. Are there any potential benefits to moving the Earth?
There are no known benefits to moving the Earth. In fact, attempting to move the Earth would likely have disastrous consequences for the planet and all life on it. It is essential to focus on preserving and protecting our planet rather than trying to move it.
  • Sticky
  • Other Physics Topics
11K
  • Mechanics
17K
