Can you factor this?
  1. Apr 11, 2005 #1
    sqr(sqr((1-v^2/c^2)^2)) * ((1-v^2/c^2) / sqr((1-v^2/c^2)^2))
    There is a purpose in this equation, but it is way to long. I know this can be factored becase there are a lot of "like terms" If you want to, change the square roots to ^.5 instead of sqr(x) you can use x^.5
    Thank you in advanced
  3. Apr 11, 2005 #2
    matt grime
    Why dont' you start by replacing 1-v^2/c^2 with some letter, such as x and make your life easier.
  4. Apr 11, 2005 #3
    arildno
    Dearly Missed
    [tex]\sqrt{\frac{\sqrt{\gamma^{2}}\gamma}\sqrt{\gamma^{2}}}}=\sqrt{\gamma},\gamma=1-(\frac{v}{c})^{2}[/tex]
  5. Apr 11, 2005 #4
    Zurtex
    Your expresion cancels down to:
    [tex]\sqrt{1- \frac{v^2}{c^2}}[/tex]
    I think, you'll need to check it though.
  6. Apr 11, 2005 #5
    [tex](Sqrt\\((1-v^2÷/c^2)\)^5\ = (Sqrt\ \((c-v)\)^5\\((c+ v)\)^5\)÷/c^(10)\)[/tex]
  7. Apr 11, 2005 #6
    Zurtex, it does not cancel down to sqr(1- v^2 / c^2)
    huan.conchito, are you saying it factors to (sqr((1-v^2/c^2)^5 ?
    And sorry but I am not to good at Latex. And I am not quite sure what gamma^2 is :confused:
  8. Apr 11, 2005 #7
    arildno
    Dearly Missed
    Well, then write your original expression properly; both Zurtex and I found by our best efforts of decoding that what you had written, reduced to [tex]\sqrt{1-(\frac{v}{c})^{2}}[/tex]
    (That's [tex]\sqrt{\gamma}[/tex] in my notation)
    Maybe we were wrong, but what you've actually written, certainly looks like that.
  9. Apr 11, 2005 #8
    Zurtex
    Actually I'm lazy and just copied this in to mathematica, replaced the sqr with Sqrt[ and the appropriate ) with ] and got it to display it better and simplify it a little.
  10. Apr 11, 2005 #9
    roflmfao
    Would you like me to mathematically prove to you it cannot be factored to
    sqr(1- (v/c)^2 )
  11. Apr 11, 2005 #10
    Zurtex
    Would you like me to show you screen shots of me copying and pasting what you've put up in to mathematica and it showing you the answer? Please be more clear and less rude to people trying to help you.
  12. Apr 11, 2005 #11
    matt grime
    eNathan, your notation was at best "confusing", so i dont' think you ought to make posts like that. you didn't even clearly bracket yuour expression or try and set it in latex to make it easier. People have tried to decode it and two people have independently got the same thing, when it really ought to be your job to sort it out.
  13. Apr 11, 2005 #12
    im sure my answer is right, i did it the reverse too
  14. Apr 11, 2005 #13
    Zurtex, don't get all emotional on me. I was simply asking you if you want me to show you the math. Yes, I can see why you got your answer, but it is not 100% the same as mines. So I will show you the math right here.
    matt grime, I'm sorry if it was too confusing for you to understand. It is a little hard for me to.
    understand.huan.conchito I was sure too.
    Ok, here is the math, pay close attention and please tell me who is wrong, google or mathematica
    With my long equation, when v = .6 and c = 1 the result is 0.8 You can clarify this at
    http://www.google.com/search?client...qr((1-+0.6+^2/+1.0+^2)^2))&btnG=Google+Search
    Again, let v = 0.6 and let v = 1. With the factored form -- that is using the equation [itex]sqr(1-v^2/c^2)[/itex] -- the result is 0.8 everything is fine right :) Again, to clarify this go to
    http://www.google.com/search?client..._s&hl=en&q=sqr(1-.6^2/1^2)&btnG=Google+Search
    But, lets try this equation when v > c
    With my equation, when v = 1.6 and c = 1, the result is -1.2489996 You can clarify this at http://www.google.com/search?hl=en&...^2)+/+sqr((1-+1.6+^2/+1.0+^2)^2))&btnG=Search
    Again, let v = 1.6 and c = 1. With your equation [itex]sqr(1-v^2/c^2)[/itex] the result is 1.2489996 i to clarify this go to
    http://www.google.com/search?hl=en&...-US:official_s&q=sqr(1-1.6^2/1^2)&btnG=Search
    Now, notice that my equation is capable of resulting in a negative number when v > c, while your "factored" version gives an imaginary number (positive), or in other cases you simply get a division by 0 error.
    But with my form of the equation, there is no division by 0 error, and there are no imaginary numbers. You can get both a positive and negative number respectively, while your "factored" version cannot. :surprised
    Do you see how my equation serves a different purpose than your's?
  15. Apr 11, 2005 #14
    You are correct; their simplification is wrong, although this seems to have occured because the brackets in your original equation were difficult to read.
    However, your equation does not eliminate any divide by zero error. In fact, it introduces one. You probably haven't noticed that because google doesn't handle division by zero correctly, giving a result of zero and not undefined.
    A good simplification would be:
    [tex]\mathrm{sgn}(1-\tfrac{v^2}{c^2})\sqrt{\lvert 1-\tfrac{v^2}{c^2}\rvert}[/tex]
  16. Apr 12, 2005 #15
    Zurtex
    First of all did you mean:
    [tex]\sqrt{ \sqrt{ \left(1-\frac{v^2}{c^2}\right)^2 } } \frac{1-\frac{v^2}{c^2}}{\sqrt{\left(1-\frac{v^2}{c^2}\right)^2}}[/tex]
    Because if you hadn't noticed your way of expressing it is at best messy, also if you think you know how to express it better why have you bothered asking us?
    Now, next really depends how you take the square root sign, however you seem to be taking it as a function rather than something that simply undoes the square sign (like we were taking it as), so carrying on:
    [tex]\sqrt{\left|1-\frac{v^2}{c^2}\right|} \frac{1-\frac{v^2}{c^2}}{\left|1-\frac{v^2}{c^2}\right|}[/tex]
    [tex]\sqrt{\left| \frac{1}{1-\frac{v^2}{c^2}}\right|} \left( 1-\frac{v^2}{c^2} \right)[/tex]
    [tex]\sqrt{\left| \frac{c^2}{c^2-v^2}\right|} \left( 1-\frac{v^2}{c^2} \right)[/tex]
    [tex]\frac{|c|}{\sqrt{\left| c^2-v^2\right|}} \left( 1-\frac{v^2}{c^2} \right)[/tex]
    [tex]\frac{|c|}{\sqrt{\left| c^2-v^2\right|}} \left( \frac{c^2 - v^2}{c^2} \right)[/tex]
    [tex]\frac{1}{\sqrt{\left| c^2-v^2\right|}} \left( \frac{c^2 - v^2}{|c|} \right)[/tex]
    [tex]\frac{c^2 - v^2}{|c|\sqrt{\left| c^2-v^2\right|}}[/tex]
    [tex]\text{sign}\left(c^2 - v^2\right)\frac{ \sqrt{ \left| \left(c^2 - v^2\right)^2 \right| }}{|c|\sqrt{\left| c^2-v^2\right|}}[/tex]
    [tex]\text{sign}\left(c^2 - v^2\right) \frac{ \sqrt{ \left| c^2 - v^2 \right| }}{|c|}[/tex]
    Spot any mistake in my workings? It's the same as the answer above by the way.
  17. Apr 12, 2005 #16
    arildno
    Dearly Missed
    I still see no unconditional apology from enathan for the complete and utter mess he first posted.
    Your disgustingly rude behaviour towards me, matt grime and Zurtex belongs nowhere.
  18. Apr 12, 2005 #17
    I cant belive I have to quote myself
    The first think I say to Zurtex is to "not get all emotional on me". This was a joke, but I said it because he though I was being rude to him, when I was merely asking him if he wants to see my results of the math. I tell matt grime that I am sorry if it was confusing. Now, if I am not mistaken "sorry" is somewhat of an apology. And I even tell him that it's a little hard for even me to read the equation. I know my typeset is horrible, and I am not too good at Latex. And can you please tell me where I was rude to you? The only answer you have me was "[tex]\sqrt{1-(\frac{v}{c})^{2}}[/tex]" I'm sorry if I did not thank you for that??? All I did was point out how your version's and my version are not identical. I was simply explaining something to you, and you think I was insulting your mathematica skills?
    And master_coda, I will look into your simplified version later I am in school right now hehe :smile:
  19. Apr 12, 2005 #18
    arildno
    Dearly Missed
    What the f**k do you think this is then?
    And no, no one besides you here regards algebraic manipulations as "difficult" or "confusing".
    It is trivial; being able to handle this is the most elementary skill a person with even marginal mathematical competence should master.
    The sole confusion here is yours, and your inability to present a problem correctly.
    PS:
    Have you thought of street-sweeping as an alternative career path?
    I think you would do well there.
  20. Apr 12, 2005 #19
    Ok, let me break down the English here. I asked Zurtex if he would like to mathematical show him why those two equations are not the exact same. He asked me if I would like a print screen. And yes, I was right (although, you cant really blame Zurtex for it). Their is no need to say "F**K" here, we are debating math not cursing at each other. You seem to be very mad at me for some reason, and I hope you don't cause this thread to be closed. I am using the equation in a programming language, so I presented it in the form which I would use it.
    PS.
    I plan to go to college and be a carpenter of a physicists. One pays more, and one I like doing more.
    So stop insulting people here. You are the only one doing this, not me. I think you cannot accept the fact that I did show everyone why those two equations are not identical in post #13. So please just stop running your mouth about how I cause confusion and I insult everybody.
    And Zurtex I am going over your math....
  21. Apr 12, 2005 #20
    Zurtex
    Actually like I pointed out before, it's a matter of how you treat the square root sign, when I see:
    [tex]\sqrt{1 - \cos^2 x} = \sin x[/tex]
    I see nothing wrong with it, however if you are using the square root as a function and not something that simply undoes squaring then it should be:
    [tex]\sqrt{1 - \cos^2 x} = |\sin x|[/tex]
    Guys, please don't get edgy, eNathan I'm sorry but you didn't really come off as polite to people helping you, saying "Would you like me to mathematically prove to you it cannot be factored to..." just comes off as rude. You don't offer any of your own workings and people are just trying to help you.
