Homework Help: Cancellation Limit
  1. Jul 25, 2010 #1
    Find the limit.
    [tex]\lim_{x\rightarrow0}\frac{\frac{1}{x+1}-1}{x}[/tex]
    2. Relevant equations
    3. The attempt at a solution
    I have to do this analytically. Although, I know that the limit is supposed to be -1 from a graphing approach. When you substitute in 0 for x you get 0/0. How do I get this function into a determinate form? I cant factor and I'm not sure what to multiply the top and bottom by.
    I tried [tex]\frac{\frac{1}{x+1}+1}{\frac{1}{x+1}+1}[/tex]
    and I got
    [tex]\frac{1-(x^2+2x+4)}{x(x+1)(x+2)}[/tex] which is still in indeterminate form.
  3. Jul 25, 2010 #2
    eumyang
    I wouldn't do that. Try multiplying the original fraction by
    [tex]\frac{x+1}{x+1}[/tex]
    instead. Something should eventually cancel.
    69
  4. Jul 25, 2010 #3
    Mute
    Do you know, or can you use, L'Hopital's rule?
    In this case, L'Hopital's rule would take the form
    If
    [tex]\lim_{x\rightarrow a} \frac{f(x)}{g(x)} = \frac{0}{0}[/tex]
    but
    [tex]\lim_{x\rightarrow a} \frac{f'(x)}{g'(x)} = L[/tex]
    where L is a finite number,
    then
    [tex]\lim_{x\rightarrow a} \frac{f(x)}{g(x)} = \lim_{x\rightarrow a} \frac{f'(x)}{g'(x)} = L[/tex]
  5. Jul 25, 2010 #4
    You can get a common denominator with the terms in the numerator and simplify, then you should get a fraction that's not indeterminate anymore.
  6. Jul 25, 2010 #5
    No I dont, I'm just starting calculus, but that looks interesting. I'm sure I'll learn it later.
    Thanks, that works perfectly. I know where I went wrong.
