Cancellation property of addition of natural numbers
For example, to prove that 3 + 2 = 5, I would say that 3 + 2 = 2 + 3 = 1 + 1 + 1 + 1 + 1 = 1 + 1 + 1 + 2 = 1 + 1 + 3 = 1 + 4 = 5. I don't know how you can do anything without using such basic facts. And if you use such facts, then you are using induction. But maybe I'm missing something...In summary, the conversation discusses the problem of proving that for all natural numbers k, m, and n, if m+k = n+k, then m=n. The
zcdfhn
23
I have to prove that for all k,m,n [tex]\in[/tex] [tex]N[/tex] that if m+k = n+k, then m=n.
The problem mentions that I must prove this by induction.
I did the base case k = 0: If m+0 = n+0, by identity m=n.
Then I attempt to show that m+1 = n+1 implies m=n, but I am stuck, I don't see how induction can be used to prove this and then next predicate that m+k = n+k implies m=n.
Any help would be greatly appreciated, and thanks in advance.
"show that m+1 = n+1 implies m=n"
Can you subtract 1 from both sides? Not sure if that's allowed in this step of the proof. It's less general than subtracting k from both sides of the original question, but not by much...
The problem didn't say you had to induct on k, though.
As an aside... doesn't
m+k = n+k implies m = n​
follow straightforwardly from
m+1 = n+1 implies m = n​
What is your definition of addition for natural numbers?
I just don't get this. This is exactly the problem I have with some of the "proofs" that I am given to construct in textbooks, they are obvious before the fact, and that is a horrible way to teach a concept.
m + k = n + k | -k
m = n
Of course that is true! there is no natural number k so that 3 + k = 4 + k!
I have a mental block or something which prohibits me from learning a method by examples where I don't actually need to use the method to get the desired result!
End-of-rant
k
If you're allowed to, use the fact there is an ordering on the natural numbers.
i know what you mean kenewbie, I'm struggling with the same issue on analysis proofs... but there in lies the twist, if you can't prove something that appears obvious, how can you prove something less obvious, that probably relies on your obvious friend?
i think its about breaking it right down to what actually is assumed eg. your axioms... and what follows as a logical consequence from those axioms alone. Otherwise seemingly simple assumptions could get swept up in your reasoning without a concrete base for them
probably wrong place to hijack somones question to discuss it, but interested on anyone else's thoughts on this
Well, your first example uses k = 0. Your next step you said that your k was 1 greater than your previous value of k, k = k + 1. If you prove that this next step is also true and that this process of getting to the next natural number is valid, then you just proved it, I think. I haven't done much of this kind of problem.
I asked before, what definition of addition are you using? I don't see how you can prove anything about addition of natural numbers without using the basic definition.
1. What is the cancellation property of addition of natural numbers?
The cancellation property of addition of natural numbers states that if a, b, and c are natural numbers such that a + b = a + c, then b = c.
2. How is the cancellation property of addition of natural numbers helpful?
The cancellation property allows us to simplify and solve equations involving addition of natural numbers more easily. It also helps us to prove mathematical theorems and properties.
3. Is the cancellation property of addition of natural numbers always true?
Yes, the cancellation property always holds true for natural numbers. It is one of the fundamental properties of addition in mathematics.
4. Can the cancellation property be applied to other operations besides addition?
No, the cancellation property only applies to addition of natural numbers. It does not hold true for other operations such as subtraction, multiplication, or division.
5. How can the cancellation property be used in real-life situations?
The cancellation property can be used in many everyday situations, such as splitting a bill among friends or calculating change when making a purchase. It is also used in more complex applications, such as in computer programming and financial calculations.
  • Precalculus Mathematics Homework Help
