Cannon Question: Loose Cannon Velocity
  • Thread starter JessGold
  • Tags
    Cannon
In summary, a cannon of mass 5.80 x 10^3 kg fires an 85.0-kg shell horizontally with an initial velocity of +551 m/s. When the cannon is unbolted from the Earth, the velocity of a shell fired by this loose cannon will still be 551 m/s, assuming that the burning gunpowder imparts the same kinetic energy to the system. Conservation laws regarding mass and velocity are at play here.
JessGold
A cannon of mass 5.80 x 10^3 kg is rigidly bolted to the Earth so it can recoil only by a negligible amount. The cannon fires an 85.0-kg shell horizontally with an initial velocity of +551 m/s. Suppose the cannon is then unbolted from the Earth and no external force hinders its recoil. What would be the velocity of a shell fired by this loose cannon? (Hint: In both cases assume that the burning gunpowder imparts the same kinetic energy to the system.)
Two conservation laws apply here. One of them is already implicitly mentioned in the hint. The other one has to do with the masses and velocities.
The velocity of a shell fired by the loose cannon can be calculated using the conservation of momentum principle. Since the burning gunpowder imparts the same kinetic energy in both cases, the initial momentum of the cannon-shell system when bolted to the Earth will be equal to the final momentum when the cannon is loose.
Using the equation for conservation of momentum, we can write:
m1v1 = m2v2
Where m1 and v1 are the mass and velocity of the cannon-shell system when bolted to the Earth, and m2 and v2 are the mass and velocity of the cannon-shell system when the cannon is loose.
Substituting the given values, we get:
(5.80 x 10^3 kg)(551 m/s) = (5.80 x 10^3 kg + 85.0 kg)(v2)
Solving for v2, we get:
v2 = 552.9 m/s
Therefore, the velocity of the shell fired by the loose cannon would be 552.9 m/s. This is slightly higher than the initial velocity when the cannon was bolted to the Earth due to the negligible recoil of the cannon.
1. What is a loose cannon velocity?
A loose cannon velocity refers to the speed at which a cannonball is fired from a cannon that is not securely mounted or stabilized. This can result in a less accurate and consistent trajectory of the cannonball.
2. What factors affect the velocity of a loose cannon?
The velocity of a loose cannon can be affected by several factors, including the weight and size of the cannonball, the amount and type of gunpowder used, the angle at which the cannon is fired, and any external forces such as wind or friction.
3. How is the velocity of a loose cannon measured?
The velocity of a loose cannon can be measured using a device called a ballistic chronograph, which uses sensors to track the speed of the cannonball as it travels through the air. Other methods include using mathematical calculations based on the weight and trajectory of the cannonball.
4. Can the velocity of a loose cannon be controlled?
Yes, the velocity of a loose cannon can be controlled by adjusting the amount of gunpowder used, the angle of the cannon, and other factors. However, it is difficult to achieve a consistent velocity with a loose cannon, which is why cannons are often secured and stabilized before firing.
5. Why is it important to consider the velocity of a loose cannon?
The velocity of a loose cannon is important to consider for safety reasons. A loose cannon can be unpredictable and dangerous, potentially causing harm to those operating it or nearby. It is also important for accuracy and effectiveness in military or historical reenactment scenarios, as a consistent velocity is necessary for hitting a target with precision.
  • Mechanics
12K
21K
