How can I input formulas and images on Physics Forums?
  • Thread starter Overberg
  • Tags
    Trajectory
In summary, the conversation discusses the proper guidelines for asking for help on PF, including typing out work instead of relying on images and providing clear explanations of questions. There is also mention of deciphering a formula, which appears to be incorrect due to the discrepancy between a vector on the left hand side and a scalar on the right hand side. Additionally, there is a brief mention of how to type in formulas on PF using LaTeX.
Overberg
A cannon fires a ball at 140 m/s
at an angle of 35 degrees above
the horizontal.
• Find the position of the ball 9.25
seconds after launch.
• Find its velocity 9.25 seconds after
launch.
• Is the ball on its way up or down?
• How long does it take the ball to
arrive at the same level as it was
launched?
• What is its velocity when it arrives at
the same level as it was launched?
• What is the angle at which it arrives
at the same level as it was launched?
v_x=v_xi
x-x_i=v_xi(t)
𝑣𝑦 = 𝑣𝑦𝑖 − 𝑔t
𝑦 − 𝑦𝑖 = 𝑣𝑦(t)-1/2gt^2
Hello Ovreberg, :welcome: !
Please read the guidelines: if you expect helpers to decipher things like
you did not understand them. Either type your work (preferred) or post a very clear picture with textual explanation what you do.
What is your question ?
I can decipher a ##\vec v = \sqrt{...}## which can't be right: LHS is a vector and RHS is a scalar !
Hello!
It is easy to type in formulas on PF, have a look on how it is done:
https://www.physicsforums.com/help/latexhelp/Images if necessary are better seen, if it is the only focus. But mspaint and an upload will do in many cases.
1. What is the cannonball trajectory problem?
The cannonball trajectory problem is a physics problem that involves calculating the path of a cannonball when it is launched from a cannon at a certain angle and velocity.
2. What factors affect the trajectory of a cannonball?
The trajectory of a cannonball is affected by factors such as the initial velocity, angle of launch, air resistance, and gravitational force.
3. How is the trajectory of a cannonball calculated?
The trajectory of a cannonball is calculated using the principles of projectile motion, which takes into account the initial velocity, angle of launch, and the acceleration due to gravity.
4. What is the difference between the maximum height and range of a cannonball?
The maximum height is the highest point the cannonball reaches during its flight, while the range is the horizontal distance it travels. These values are dependent on the initial velocity and angle of launch.
5. How does air resistance affect the trajectory of a cannonball?
Air resistance, also known as drag, reduces the speed of the cannonball and changes its trajectory. It is affected by the shape and size of the cannonball, as well as the air density and speed.
