Homework Help: Can't solve double integral
  1. Jun 25, 2014 #1
    ∫∫D√(9x2+4y2) dx dy
    D is the region: x2/4+y2/9=1
    My understanding is that i have to integrate the function of a density to calculate the mass of plate which is ellipse. Problem is i cant and shouldnt be able to integrate this integral at my level, so am i missing some way of simplification?
  3. Jun 25, 2014 #2
    Orodruin
    Staff Emeritus
    2017 Award
    Have you considered a change of variables (or two)?
  4. Jun 25, 2014 #3
    to polar cordinates?
  5. Jun 25, 2014 #4
    Orodruin
    Staff Emeritus
    2017 Award
    Try getting the coordinates to a form where making the change to polar coordinates make more sense first. Hint: An ellipse does not give the simplest boundary condition in polar coordinates.
  6. Jun 25, 2014 #5
    Zondrina
    Why not let ##x = 2u## and ##y = 3v##.
    Then switch to polar.
  7. Jun 25, 2014 #6
    i do not understand how this will help.
    can please someone solve the problem for me im desperate
  8. Jun 25, 2014 #7
    Orodruin
    Staff Emeritus
    2017 Award
    Why don't you try doing it? It will be much more instructive than if we solve it for you.
  9. Jun 25, 2014 #8
    Zondrina
    There's a theorem you should be familiar with, it should be along the lines of:
    ##\int_R \int f(x,y) dxdy = \int_{R'} \int f(u,v) |J| dudv##.
    Where ##|J|## is the Jacobian matrix of the transformation, ##R## and ##R'## are the regions. You have an integral, which looks like the left side of the above theorem. The theorem tells you that you can change the region and co-ordinates of a double integral, and get the same answer.
    So making the substitution I noted in an earlier post, what happens to the region ##D##? It gets mapped to some region ##D'## through an invertible map. What is the result of plugging the substitution into the integral on the right?
  10. Jun 25, 2014 #9
    ∫∫R'√(36u^2+12v^2) J du dv
  11. Jun 25, 2014 #10
    Zondrina
    No, the integral becomes ##36 \int \int_{D'} \sqrt{u^2 + v^2} |J| dudv##. Where of course ##dx = 2du## and ##dy = 3dv##.
    The region ##D → D' := u^2 + v^2 = 1##. Notice this is the equation of a circle with radius 1.
    The Jacobian is the matrix of partial derivatives of the transformation. Can you compute it?
    For reference: http://en.wikipedia.org/wiki/Jacobian_matrix_and_determinant
  12. Jun 25, 2014 #11
    Orodruin
    Staff Emeritus
    2017 Award
    What is ##4\times 3^2## and what is the expression for ##J##?
    If you are not familiar with jacobians, try the following instead: what is ##du## if ##u = x/2##? (It is ok to use this type of reasoning as long as you are making parameter transformations of the type considered here, i.e., u = f(x) and v = g(y))
  13. Jun 25, 2014 #12
    Orodruin
    Staff Emeritus
    2017 Award
    ##\sqrt{36} = 6## ...
  14. Jun 25, 2014 #13
    ok, i understand a little now.
    J=6 ?
  15. Jun 25, 2014 #14
    is the final solution 36pi?
  16. Jun 25, 2014 #15
    Orodruin
    Staff Emeritus
    2017 Award
    Yes, J=6 (or rather |J|=6) in the first variable change.
    What is the area element ##du\, dv## expressed in polar coordinates?
  17. Jun 25, 2014 #16
    24pi
  18. Jun 25, 2014 #17
    Zondrina
    Don't forget ##dx## and ##dy##.
  19. Jun 25, 2014 #18
    Orodruin
    Staff Emeritus
    2017 Award
    I would have agreed if you did not still have the jacobian in your expression.
  20. Jun 25, 2014 #19
    Orodruin
    Staff Emeritus
    2017 Award
    What are your integration limits in polar coordinates? (The answer is the same as I get by doing it in my head, which I do not trust at 1am, but I just want to make sure you've got it right)
  21. Jun 25, 2014 #20
    r=(0,1)
    fi=(0,2pi)
  22. Jun 25, 2014 #21
    Orodruin
    Staff Emeritus
    2017 Award
    :thumbs:
    I am assuming you got 36π by forgetting the r in the area element? (du dv = r dr dθ, i.e., |J|=r for the change to polar coordinates)
  23. Jun 25, 2014 #22
    Zondrina
    Whoops, my bad. Didn't notice that while typing.
  24. Jun 25, 2014 #23
    your assumption is correct
    thank you guys 100x times
  25. Jun 25, 2014 #24
    Orodruin
    Staff Emeritus
    2017 Award
    Copy and Paste, the source of 98% of all typos in published papers - also 73.4% of all statistics you will read are made up on the spot ;)
  26. Jun 26, 2014 #25
    ehild
    What is the shape of the region bounded by the line ##\frac{x^2}{4}+\frac{y^2}{9}=1## ?
    You can rewrite the square root in the integrand as ##\sqrt{9x^2+4y^2}=6\sqrt{x^2/4+y^2/9}=6##, so you have the integral ##\int _D{dxdy}## which is the area of the shape bounded by the line ##\frac{x^2}{2^2}+\frac{y^2}{9}=1##.
    ehild
Have something to add?
Draft saved Draft deleted
