Can't watch youtube vids , Help
In summary: When you go to YouTube to watch videos, it may say that you either have JavaScript turned off or an old version of Adobe's Flash Player. But, I have met both of those requirements and it still won't let me watch videos. There can be only three possibilities: 1) something is wrong with YouTube, 2) something is wrong with your cache, or 3) something is wrong with your Flash. The solution is to exit YouTube (but not your web browser), then clear your "cache" of all its "TIFs", "cookies", and "history". After that, shutdown and reboot.
cragar
2,552
When I go to you tube to watch videos it says that I either have JavaScript turned off or an old version of Adobe's Flash Player.
But I have met both of those requirements and it still won't let me watch videos .
Does anyone know how to fix this or have any ideas ? Anything would be appreciated .
What are you using ? Can you describe your system ?
don't waste your time looking all over the place for where JavaScript is supposed to be
and whether it's enabled or not. I can tell you with certainty that your JavaScript is "on".
And don't bother trying to download and reinstall the "latest Flash" over and over again.
You will get absolutely nowhere doing that because that's really adding to the problem.
There can really be only 3 possibilities:
1) YOUTUBE
Your problem may fix itself within a couple hours, or by the
next day, because YouTube often "shuts down" a bunch of
their own servers every single day without warning anybody,
in order to update all kinds of stuff. During those occasions,
it's really YouTube's data transmissions of "Java" or "Flash"
that are poor -- not your reception of it.
2) CACHE
If the following day your YouTube is still stuck and showing
you those awful "JavaScript" and "Flash Player" messages,
it's possible that your sub-directories of "temporary internet
files" and "cache" memory are full, and can't take anymore.
This typically results in videos being totally unable to buffer
and make it onto your computer screen.
"Temporary internet files" are 1000s of tiny bits of websites
permanently put on your computer's hard-drive. They'll stay
there forever and ever, gradually plugging up your computer
much like hair slowly clogs a sink drain, until you get rid of
them once and for all (or at least everytime things go awry).
Because your computer now has such little space in which
to "cache" a video, YouTube will mistakenly think that your
JavaScript is off or that your Flash player (unable to absorb
any more videos) is old -- meaning Flash 7 or older.
The solution to all that is to exit YouTube (but not your web
and "history". (See below.) After that, shutdown and reboot.
3) FLASH
Nothing about watching YouTube has really changed in the
past 2 years. (Technically, you could still even use Flash 8
if you wanted to.) It looks like the newest Flash players are
causing many YouTubers a whole lot of grief, especially all
8 variations of version 10.
It's absolutely nuts that there's 10.0.525, 10.1.218, 10.2.26,
10.2.54, 10.12.10, 10.12.36, 10.15.3 and 10.22.87. Usually
most updates are good for only 1 thing:...software conflicts.
I have never strayed away from 9.47, and there are a bunch
of "flashers" who still live by 9.45. Think of those 2 Flashes
like Windows XP compared to Vista. Please have a look at
the "Asker's" response to this other "Best Answer" of mine:
http://answers.yahoo.com/question/index?…
If that seems interesting to you, here is the appropriate link:
http://www.oldapps.com/flash_player.php?…
Note 1: if you've got Google Web Accelerator or something
similar to it...dump it, burn it, trash it, disable it, uninstall it,
-- do everything you can to get rid of it. GWA conflicts with
YouTube. Clicking "Don't Accelerate This Website" will not
help you whatsoever. Also, most "Messenger" applications
have a way of mucking up YouTube.
Note 2: longer videos may require "Flash" and "Shockwave"
in order to play properly.
Note 3: a very odd fix that once worked for me was altering
the URL from "www.youtube.com" to simply "youtube.com"
(or you could even try "ca.youtube.com").
Note 4: there's always the strange possibility that you may
have gone through the whole process of downloading Flash,
BUT DID YOU ACTUALLY INSTALL IT? If you have Firefox,
did you "enable" the Flash "add-on"?
I hope that my information proves to be quite helpful to you.
Internet Explorer 6:
→ Tools → Internet Options
→ Delete Cookies → OK
→ Delete Files → OK
→ Clear History → Yes
→ OK
Internet Explorer 7:
→ Tools → Internet Options → Delete...
→ Delete files → Yes
→ Delete cookies → OK
→ Delete history → OK
→ Close (browsing history window)
→ OK
Mozilla Firefox
→ Tools → Clear Private Data
[x] Browsing History
[x] Download History
[x] Saved Form and Search History
[x] Cache
[x] Cookies
→ Clear Private Data Now
thank-you very much it worked .
If anyone else stumbles on this thread days/months/years from now. Note that I have had problems on a 64-bit machine using one version of internet explorer or the other. It seems that the normal version works fine while the 64bit version does not.
It may be our fantastic IT guys, but just a note.
... snip
This is copied and pasted from a number of websites. I've seen it from Yahoo Answers to some jewelry site. You should still cite your source when you do this.
so wat
at least i helped him!
muhammad680 said:
so wat
So it isn't plagiarism.
muhammad680 said:
so wat
It's also for your benefit. If you don't acknowledge your sources whenever you post something someone else wrote, as you have posted above, it would typically be thought to be your work. But when it's learned that you didn't write something you posted, people will generally not take you as seriously, and in some cases may outright ignore you.
Just make it a habit to include a link to anything you "borrow." People will still be as thankful for your assistance and would be just as likely to turn to you for help.
1. Why can't I watch YouTube videos on my device?
There can be several reasons why you are unable to watch YouTube videos on your device. It could be due to a slow internet connection, outdated browser or software, or issues with your device's hardware. It is also possible that YouTube might be experiencing technical difficulties.
2. How can I fix the issue of not being able to watch YouTube videos?
There are a few troubleshooting steps you can try to fix the issue. Firstly, make sure your internet connection is stable and fast enough to stream videos. Then, try clearing your browser's cache and cookies, updating your browser or software, and restarting your device. If the issue persists, you can contact YouTube's support team for further assistance.
3. Why do I keep getting an error message when I try to play a YouTube video?
The error message could be due to various reasons, such as an outdated browser or software, a poor internet connection, or a problem with the video itself. It is also possible that the video is restricted in your country or region. Try updating your browser or software, clearing your cache and cookies, and checking your internet connection. If the issue persists, you can report the error to YouTube.
4. Can I watch YouTube videos offline?
Yes, you can watch YouTube videos offline by using the "Save Offline" feature available on the YouTube mobile app. This allows you to download videos and watch them later without an internet connection. However, not all videos are available for offline viewing, and you can only access them through the YouTube app.
5. Is there a way to fix the issue of not being able to watch YouTube videos on a specific device?
If you are experiencing issues with watching YouTube videos on a specific device, try updating the device's software, clearing its cache and cookies, and restarting it. You can also try accessing YouTube on a different browser or updating the YouTube app on your device. If the issue persists, you can contact the device's manufacturer for further assistance.
  • Computing and Technology
  • Materials and Chemical Engineering
  • General Discussion
