Finding Max Load for Cantilever Beam of AlN
In summary, the conversation was about an undergraduate student starting their research and trying to find the maximum load that could be applied to a cantilever beam made of aluminum nitride without it breaking. However, without a failure criterion and the ultimate tensile strength of the material, it is impossible to accurately calculate the breaking point. The student is advised to ask the grad student why they need this information and to consider allowable stresses and factors of safety in real-world applications.
Physics_wiz
228
I'm an undergrad. student trying to do research. Today was my first day working with grad students and one grad student gave me something to find. We have a cantilever beam made of aluminum nitride (AlN). The only things known about the beam are the dimensions and young's modulus. He wants to find the max load that could be applied to the free end of the beam without the beam breaking. I looked in my mechanics of materials book and found a formula for the displacement of the free end but I don't know how to find the max load. I don't even know if this problem is doable given that we only know the material's young's modulus. I'll try to find some online information and read some more in the mechanics of materials book. In the mean time, any help would be greatly appreciated.
Ok, I congrat you for starting your researching career!. When sometime passes, you will laugh at these first steps!.
1) You need a failure criterion. Usually, it is considered for engineering purposes that if in any section of the beam is reached the plasticity stress, then the beam gets into technical failure. There are another criterions such as Von-Mises and Tresca.
2) Once you have the maximum stress your beam can deal, you have to look for the section in which it will be probably reached. This question is left for you, try to think of it and solve on your own.
3) Knowing the beam dimensions and the Young modulus, you can obtain the displacement which causes that maximum stress in the section chosen, and then the load which should be applied for failure.
Good luck.
EDIT: changed "fracture" by "failure".
Thanks for the reply.
1) Is that a property of the material? If I don't have it, do you know what tests or resources it could be obtained from?
2) I'm guessing the max stress will happen in the middle top part.
3) The equation to use is: Max stress = (Young modulus) (change in length/original length). Right? I have the max stress from (1) and young's modulus and the original length of the beam (top part). The change in length is the horizontal change in length of the whole beam (top part) right? After that is found I have to find the max downwards displacement of the free end and plug it in the equation in my book to get the max force. Did I get all that right? Also, if I know the change in length of the top part of the beam, how do I find the max downward displacement of the free end?
Thanks again.
Hmmmm I take number 2 back. The max stress occurs at the fixed end where the moment is maximum. I don't think I know how to find #3 yet though.
Hey physics_wiz. Calculating the stress in a cantalivered beam is one thing. Calculating the load required to break the beam is a different issue because to break the beam, things must happen that are not easily calculable. In a typical beam, deformation occurs along the fibers farthest from the neutral axis because the tensile stress is linearly proportional to the distance from the neutral axis. This can be seen from the equation for stress:
S = Mc/I
Where S = stress
M = Moment
c = distance from neutral axis
I = moment of inertia
As the beam deforms, the stress no longer remains linearly proportional as the equation suggests. As the beam yeilds, the stress in the outermost fibers remains almost constant and stretches, while the fibers at a lesser distance to the neutral axis begin to yield. It would be easier to draw a picture here, but those are the limitations of a message board.
A second issue also needs attention. If the beam is long in relation to the depth, the moment does not increase linearly with increased force. That's because the distance between the wall where the beam is mounted and the force decreases as the beam bends.
Taking these two factors into account, one has a very difficult time determining the breaking point.
But if your beam is relatively short and your material relatively brittle (aluminum nitride is very brittle), it could be a bit easier to determine. Unfortunately, you don't have enough information to determine the breaking point of the beam. You need the ultimate tensile strength. Without that, you have no way of doing this. You could look up textbook data for the material, but I wouldn't trust that to within 20%, even if you know everything about the material, so you can assume the calculation you will perform will be off by a fairly large margin.
If I were you, I'd ask the grad student why he wanted to know what load can be applied before breaking. Because that load should never be even close to being applied under normal use. If the beam is being used for something, there are allowable stresses that should never be exceeded in the material. Those allowable stresses are below yield stress by some factor of safety. So you need to find out what the yield and ultimate tensile strength is to work that out.
Just a final note, aluminum nitride is a type of ceramic. See this reference:
http://www.accuratus.com/alumni.html
If the beam is a conventional structural support, I'd be very surpised if it were made from aluminum nitride. Beams aren't generally made from that material. There are aluminum beams, but they are typically aluminum alloy of some type, not aluminum nitride. I'd suggest you verify the material before going any farther.
Yes it's aluminum nitride. I forgot to mention that this was for a micro switch kindda thing. They're working on nano stuff now (I really don't know what it's for...yet) but this is a part of what they're doing. The Beam will actually deflect by applying a voltage to the fixed end (don't know how that works either...yet). That's what I understood from the guy.
Ah - ha.. <lightbulb goes on> That makes a lot more sense now.
If someone wants an estimate of the load needed to break the beam, use the flexure strength to estimate the stress it will break at with the equation I gave above.
If someone wants to know what load can safely be applied, chose a factor of safety below that estimated load. I'd suggest a factor of safety of 3 to 5. (ie: don't exceed a load of 1/3 to 1/5 that which will break the beam) You could use a smaller value, but that should really only be done after you and the others understand what benefits you can get from increasing stress and what possible reprecussions there will be if the beam breaks.
If this beam is under a fatigue load, that's a different story altogether.
So before you go any farther, you'll need to look into material properties. I wouldn't use textbook data if you don't have to. Find out where the beam came from and see if the supplier can give you more accurate strength data.
Better yet, if you have a whole bunch of these things laying around, try breaking them and use that data!
1. How do you determine the maximum load for a cantilever beam made of AlN?
The maximum load for a cantilever beam of AlN can be determined through various methods, such as analytical calculations, numerical simulations, and experimental testing. Analytical calculations involve using equations and models to calculate the maximum load based on the material properties and beam dimensions. Numerical simulations use computer software to simulate the behavior of the beam and determine the maximum load. Experimental testing involves physically testing the beam under different loads to determine the maximum load it can withstand.
2. What factors affect the maximum load of a cantilever beam of AlN?
The maximum load of a cantilever beam of AlN is affected by several factors, including the material properties of AlN, such as its Young's modulus and yield strength, the dimensions of the beam, such as length, width, and thickness, and the boundary conditions, such as the type of support and loading applied to the beam. Other factors that can affect the maximum load include the temperature and environment in which the beam is operating.
3. How does the shape of the cantilever beam affect its maximum load?
The shape of the cantilever beam can greatly affect its maximum load. A thicker beam will have a higher maximum load compared to a thinner beam of the same material and dimensions. Similarly, a longer beam will have a lower maximum load compared to a shorter beam. The shape of the cross-section of the beam can also affect its maximum load. A beam with a rectangular cross-section will have a higher maximum load compared to a beam with a circular cross-section of the same area.
4. What is the typical range of maximum load for a cantilever beam made of AlN?
The maximum load for a cantilever beam made of AlN can vary depending on the factors mentioned earlier. However, on average, the maximum load for an AlN cantilever beam can range from a few hundred to a few thousand Newtons. This range can also vary based on the application and the specific requirements of the beam.
5. How can the maximum load of a cantilever beam of AlN be increased?
The maximum load of a cantilever beam of AlN can be increased by altering its dimensions, such as increasing the thickness or decreasing the length, to make it stiffer and capable of withstanding higher loads. Using a different material with higher strength properties, such as AlN composites, can also increase the maximum load. Additionally, optimizing the beam's design and shape can help increase its maximum load. However, it is important to note that these changes should be made carefully and with consideration of the beam's intended use and application.
  • General Engineering
13K
