• Support PF! Buy your school textbooks, materials and every day products Here!
Capacitance in circuit
~christina~
1. Homework Statement
Assume that [tex]C_1= 10.0 \mu F[/tex], [tex]C_2= 5.00\mu F[/tex], and[tex] C_3= 4.00\mu F[/tex]. A potential difference of [tex]V[/tex]= 100V is applied across this network of capacitors.
1st picture is original (after that is when I simplified the circuit or tried to anyhow)
a) find the equivalent capacitance of this circuit
b) find the potential difference across capacitor 2
c) what is the charge on this capacitor?
d) how much energy is stored by this capacitor?
http://img397.imageshack.us/img397/4125/21107020ai0.th.jpg [Broken]
2. Homework Equations
[tex]C_{eq}= C_1+C_2+C_3...[/tex]
[tex]\frac{1} {C_{eq}} = \frac{1} {C_1} + \frac{1} {C_2} + ...[/tex]
3. The Attempt at a Solution
well I broke down the circuit into series and parralel sort of. (in the picture)
not sure if I arranged it correctly first of all. (by breaking it down in to series and parallel) because I only came up with one step for breakin it down which seems incorrect
would I calculate it at the begining as if it was parrallel or series??
Help please.
Thanks
Answers and Replies
Nabeshin
Your breakdown of the capacitors looks fine to me. What seems to be the problem here? Not sure what you mean when you say, "
would I calculate it at the begining as if it was parrallel or series??"... perhaps some elaboration on that point would help clear up your question?
~christina~
okay. (I was just confused as to what was series and what was parallel)
but I think I get it now.
a) find the equivalent capacitance of the circuit
C1 and C2 are in series so:
[tex]1/C_{12}= 1/C_1 + 1/C_2 [/tex]
[tex]1/C_{12}= 1/10\mu F + 1/5.00\mu F [/tex]
[tex]C_{12}= 3.33\mu F [/tex]
[tex]C_{eq}= C_{12} + C_{3} [/tex]
[tex]C_{eq}= 3.33\mu F + 4.00\mu F [/tex]
[tex]C_{eq}= 7.33\mu F [/tex]
I think this is fine.
not sure how to find this though.
Thanks
Nabeshin
Well, a total of 100V is applied to the circuit, so you should be able to use the knowledge that voltage is the same in parallel and the sum of the voltage drops in series is equal to the total voltage drop to break it down more... After that, the equation Q=CV should solve most of your woes.
454
You also need that capacitors in series will have the same charge. (if they started out with the same charge before connecting the voltage source)
~christina~
okay I still am not sure how to find it but only on one part I think
Since C1 and C2 are in series then:
[tex]\Delta V_{total}= \frac{Q} {C_{eq}} [/tex]
but if this is so then
would it be this?
[tex] V_{tot}= \frac{1} {C_1} + \frac{1} {C_2} [/tex]
but if so then how would I find the individual V across 2?
I know that [tex] \Delta V_{tot}= \Delta V_1 + \Delta V_2 [/tex]
~christina~
am I correct in my thinking? anyone?
Nabeshin
Your thinking is correct, but what I left out is what kamerling so kindly said. Charge on series capacitors is also the same. Therefore C is the same in that first equation you have. Try to use a ratio to get the exact voltage drop :)
~christina~
not really getting what your saying but..lets see:
since charge on series capacitors is the same then
Q1=Q2
Do I do this?
solve for Q
[tex]Q= \Delta V_{total} C_{eq}[/tex]
then I would plug that into
[tex]Q/C_{eq}= Q_1/C_1 + Q_2/C_2 [/tex]
but I don't know C1
and solve for [tex]Q_2/C_2[/tex] ??
Nabeshin
Hrm.. I'm not quite sure what you're doing to be perfectly honest, lol. What I meant by my ratio comment was this:
[tex]V_{1}[/tex]+[tex]V_{2}[/tex]=[tex]V_{tot}[/tex]
Because voltage drop in parallel will be equal.
We also know [tex]Q=CV[/tex] for individual capacitors, and [tex]Q_{1}=Q_{2}[/tex]
So [tex]Q_{1}=C_{1}V_{1}[/tex] and, because of the above [tex]Q_{1}=C_{2}V_{2}[/tex]
I'm going to leave the rest to you, but hopefully you can see the ratio here, and use the first equation provided. Hope this helps to clarify
~christina~
is the ratio because
[tex]Q_{1}=C_{1}V_{1}[/tex] &
then plugging into the equation
[tex]V_1 + V_2= V_{total} [/tex]
I willl get
[tex]\frac{Q_1} {C_1} + V_2= V_{total} [/tex]
but I still don't understand how If I don't have Q then how will I find the V2 ?
so I think that V total will be 100V
thus the equation would be
[tex]\frac{Q_1} {10.00\mu F} + V_2= 100V [/tex]
but would Q1 be Vtotal(Ceq)= Q1 ??
so Q1= 100V(7.33x10^-6 F) = 7.33x10^-4 C ?
Nabeshin
Yes this is correct. Set the first equations equal to eachother, and you can solve for [tex]V_{1}[/tex] in terms of [tex]V_{2}[/tex]! Then use the other equation, and your only unknown is [tex]V_{2}[/tex].
~christina~
oh...
[tex]C_1V_1= C_2V_2 [/tex]
[tex]V_1= \frac{C_2V_2} {C_1} [/tex]
then
[tex]\frac{C_2V_2} {C_1} + V2 = V_{total} [/tex]
d)find the total energy is stored by the capacitor
hm..
[tex]U= \frac{Q^2} {2C}= \frac{1} {2} Q\Delta V= \frac{1} {2} C( \Delta V )^2 [/tex]
Nabeshin
Yep. :)
~christina~
which of the equations should I use??
and is Delta V, for the whole circuit? or do I calculate it in parts and etc. (Q, C)
~christina~
I'm still not sure as to what number to use for the total energy stored in the capacitor.
what Q do I use? and what C do I use? or what change in potential do I use for the equation?
C would be Ceq right but as for the rest..not so sure.
Thanks
Related Threads for: Capacitance in circuit
  • Last Post
  • Last Post
  • Last Post
17K
