1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Capacitance Problem
  1. May 4, 2008 #1
    [SOLVED] Capacitance Problem
    A parallel-plate air capacitor is made by using two plates 16 cm square, spaced 4.7 mm apart. It is connected to a 12-Volt battery.
    What is the capacitance?
    2. Relevant equations
    [tex]|C = \epsilon_r\epsilon_0\frac{A}{d}[/tex]
    3. The attempt at a solution
    [tex]\epsilon_r[/tex] = 1.00059
    [tex]\epsilon_r = 8.85*10^{-12}[/tex]
    A = 0.0016m
    d = 0.0047m,
    And inserting into the formula, I get:
    [tex]|C = (1.00059)(8.85*10^{-12})frac{0.0016}{0.0047}[/tex]
    Which is 3.01*10^-12, which is apparently incorrect.
    Any uides where I have have gone wrong?
  3. May 4, 2008 #2
    Staff: Mentor
    Check your cm/mm to m conversion.
  4. May 4, 2008 #3
    4.7mm = 0.0047m,
    16 cm squared = 0.0016 square meters
    so it can't be the mm/cm converions?
  5. May 4, 2008 #4
    Staff: Mentor
    Sorry, missed that squared thingy, looked at 16 cm -> 0.0016 m and it didn't look right... That's what happen when you don't pay attention to units.
    OTOH - why do you think 3 pF is wrong?
  6. May 4, 2008 #5
    I entered the equation into Mastering Physics, and it just said it was wrong?
  7. May 4, 2008 #6
    Staff: Mentor
    No idea how these things work in physics, in the chemistry I would tell watch significant digits...
  8. May 4, 2008 #7
    In MP, you can enter the formula and it calculates it for you, so I entered:
    And MP Calculated it to be 3.01*10^-12, I have also had 3.02 and 3.00 (Both *10^-12), and none of these answers are accepted!!!?
    Any other ideas?
  9. May 5, 2008 #8
    Any ideas will be greatlt appreciated since there are at least three more parts related to this question, and the next one is:
    What is the charge on each plate?
    To which I need the capcitance to use the formula:
    [tex]C = \frac{Q}{V}[/tex]
    So without the correct capacitance, I can't finish the questions!
    So, Any help will be very much greatly appreciated,
  10. May 5, 2008 #9
    What is Mastering Physics,some software for technical computing?
    And how exactly does it say that the result is wrong?
    Where did you get that value of [tex]\varepsilon_r=1.00059[/tex],in text of the problem?
  11. May 5, 2008 #10
    Mastering Physics is online Coursework Software - it basically is online homework:
    The Value I gotfrom the corresponding text book, Young and Freedman, 12th Edition, which accomapnies the Mastering Physics
    All Mastering Physics Says is
    "Try Again;"
    So far I've tried 3.00, 3.01, 3.02, all x10^-12, none are correct?
  12. May 5, 2008 #11
    Sorry,I didn`t saw that it is an air capacitor.So maybe there is an error in program,althought probably not,but...
  13. May 5, 2008 #12
    Hey TFM,
    I have the same assignment and I was having the same problem. It seems it is an error in the language used by MP. The area isn't 16cm[tex]^{2}[/tex], it's 0.0256m[tex]^{2}[/tex]. The 16cm refers to the side length. Just to save you from entering the wrong answer too many times my value is (using your formulae);
    4.8*10^-11 F
  14. May 5, 2008 #13
    Thaks for the info, Vuldoraq, Silly Mastering Physics :rolleyes:
    One small query further on,
    "The battery is disconnected and then the plates are pulled apart to a separation of 9.4 mm.
    What is the charge on each plate in this case?"
    I have already calculated the Capacitance, but wasn't sure how to work this one out, Q=CV doesnt work with 12V for this one.
  15. May 5, 2008 #14
    Your welcome.
    With the battery disconnected, and no new circuit made, the capacitor is unable to discharge. Therefore it retains the charge previously given to it.
  16. May 5, 2008 #15
    Indeed it is, Thanks
    Thanks to all those who helped,
Have something to add?
Similar Discussions: Capacitance Problem
  1. Capacitance Problem (Replies: 6)
  2. Capacitance Problem (Replies: 2)
  3. Capacitance Problem (Replies: 5)
  4. Capacitance Problem (Replies: 4)
