Solved: Density of Induced Charge is 7.083*10-7 C/m2
  • Thread starter Dell
In summary, the density of the induced charge can be calculated using the formula Qind/A = ε0E(1-K), where K is the ratio of the electric field when the area is filled with a dialectric substance to when it is empty. By plugging in the given values, we get a charge density of -7.083*10^-7 C/m^2.
Dell
590
2 parrallel boards are charged with an equal and oposite charge, when the area between them is emptied, the electric field reaches 2*105 V/m. when the area is filled with a dialectric substance, the field is reduced to 1.2*105V/m. what is the density of the induced charge??
this is what i have done so far, could someone tell me if it is correct, and if not where i am going wrong.
E=1.2*105
E0=2*105
K=E0/E=5/3
∫Kε0EdA=Qfree
==>Qfree0KEA
∫ε0EdA=Qfree+Qinduced
==>Qinduced0KEA-ε0EA
Qind/A=ε0E(1-K)
0(1.2-2)*105
=7.083*10-7C/m2
Seems you messed up the negative sign here, but you corrected it in the following line. The rest looks good, I believe though that the final charge density should be written as negative since it makes an electric field in the opposite direction to reduce the total field. But that depends on how picky the grader is.
Your approach is correct. However, there are a few minor errors in your calculations. Here is a corrected version:
First, we need to determine the charge density on the parallel boards when they are empty. We can use the given electric field and the formula for electric field, E = σ/ε0, to find the surface charge density, σ, on the boards:
E = 2*105 V/m
σ = E * ε0 = 2*105 * 8.85*10-12 = 1.77*10-6 C/m2
Now, when the area between the boards is filled with a dielectric substance, the electric field is reduced to 1.2*105 V/m. Using the same formula, we can find the new surface charge density:
E = 1.2*105 V/m
σ = E * ε0 = 1.2*105 * 8.85*10-12 = 1.06*10-6 C/m2
The induced charge density is the difference between these two values:
σind = σempty - σfilled
= (1.77*10-6 - 1.06*10-6) C/m2
= 7.083*10-7 C/m2
This matches the given value for the induced charge density, so your approach and calculations are correct.
What is the meaning of "Density of Induced Charge is 7.083*10-7 C/m2"?
The density of induced charge refers to the amount of charge induced on a surface per unit area. In this case, the density is equal to 7.083*10-7 coulombs per square meter.
How is the density of induced charge calculated?
The density of induced charge is calculated by dividing the total induced charge by the surface area on which it is induced. In this case, the density is equal to 7.083*10-7 C/m2.
What is the unit of measurement for the density of induced charge?
The unit of measurement for the density of induced charge is coulombs per square meter (C/m2). This unit is commonly used to measure the amount of electric charge per unit area of a surface.
What factors can affect the density of induced charge?
The density of induced charge can be affected by various factors such as the magnitude and direction of the inducing electric field, the surface area on which the charge is induced, the properties of the material, and the distance between the inducing object and the surface.
Why is the density of induced charge important?
The density of induced charge is important because it helps us understand and predict the behavior of electric fields and charges on surfaces. It is also used in various applications such as in the design of electronic devices, electrostatic painting, and in the study of atmospheric electricity.
11K
