Homework Help: Capacitor PE
  1. Jan 23, 2009 #1
    The following 3 step process refers to a simple RC circuit with a battery and an initially open switch:
    1- the switch is closed, allowing the capacitor to charge;
    2- after the capacitor has charged, a slab of dielectric material is inserted between the plates of the capacitor and time passes;
    3- the switch is opened, and the dielectric removed.
    Q(capacitor)=CV(capacitor)
    PE(capacitor)=1/2 CV^2
    I said that: delta(PE)1>0; delta(PE)2>0; delta(PE)3<0
    correct?
  3. Jan 23, 2009 #2
    LowlyPion
    When you are putting the dielectric in the capacitor, you are effectively increasing the capacitance by the relationship that C/Co = ε the dielectric constant for the material, where ε > εo
    As to your answers, I don't really know what the question is.
    I would point out in step 3 that since the charge remains the same, but the capacitance is now influenced by εo instead of the higher ε of the removed dielectric, that the voltage will drop across the cap.
  4. Jan 23, 2009 #3
    My question is whether or not the change in PE of the capacitor would reflect my "answer:" delta(PE)1>0; delta(PE)2>0; delta(PE)3<0 (the numerals are respective of the steps)
  5. Jan 23, 2009 #4
    LowlyPion
    I guess I don't really understand your notation.
    I just described what happens.
  6. Jan 23, 2009 #5
    epenguin
    :confused: You decrease ε so you increase V according to pion's equation and physical intuition - you would need a higher voltage to establish that charge without the dielectric!?
  7. Jan 23, 2009 #6
    yeah, that is what my answer shows right? a drop in V means a drop in PE. so PE final - PE initial < 0 ???
  8. Jan 23, 2009 #7
    LowlyPion
    That's correct. I misstated it in typing it.
    Thanks for catching that.
  9. Jan 23, 2009 #8
    soooooo, i am correct?
  10. Jan 23, 2009 #9
    LowlyPion
    No. I misstated my original description.
    The equations were right. My English description was wrong.
  11. Jan 23, 2009 #10
    ay.... i don't understand what happens then. this is my logic:
    1- capacitor is charging (PE final is greater than PE initial therefore deltaPE>0)
    2- capacitor has dielectric inserted (PE final is greater than PE initial because dielectric allows more capacitance therefore deltaPE>0)
    3- capacitor no longer charging and dielectric is removed (PE final is less that PE initial because capacitor is now able to discharge therefore deltaPE<0)
  12. Jan 24, 2009 #11
    epenguin
    3 does not correspond to 3 of your first post. Switch stays open, the charge has to stay there ideally. Yes, if the switch is then closed the capacitor will largely discharge.
  13. Jan 24, 2009 #12
    yes 3 is the same on both posts:
    3 (first post): the switch is opened, and the dielectric removed.
    3 (last post): capacitor no longer charging [the switch is opened] and dielectric is removed
    I am restating my logic. Is this correct? Anyone!
    delta=final-initial; numerals correspond to the steps.
