1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Capacitor Question
  1. Jul 8, 2013 #1
    A circuit contains a single 250 pF capacitor hooked across a battery. It is desired to store three times as much energy in a combination of two capacitors by adding a single capacitor to this one. How would you hook it up, and what would its value be?
    2. Relevant equations
    PE = (1/2) CV^2
    3. The attempt at a solution
    PE(final) = 3PE(initial)
    so then:
    (1/2)CV^2 = 3 * (1/2) CV^2
    Not sure where to go from here? I would think that if it is three times as much energy, then it should be 3 times the capacitance 3C = 3 * 250 pF = 750 pF but this isn't correct
  3. Jul 8, 2013 #2
    berkeman
    Staff: Mentor
    I would call the initial capacitor C1, and the cap you add could be C2. That will make your equation make more sense.
    And you have the right idea, but the question asks what size capacitor should you *add* to make the total energy storage 3x the initial storage on C1. How does that change your answer? :smile:
  4. Jul 8, 2013 #3
    Ok so then it's:
    (1/2)C2V^2 = 3 * (1/2)C1V^2
    When you say "add", does this mean C2 will be in parallel with C1?
    OOH....so if it's parallel, then It's C1 + C2 but is C1 = C2? If it is, then C = C1 + C2 = 250 + 250 = 500 pF
    But how do you know that both capacitors are 250 pF?
  5. Jul 8, 2013 #4
    berkeman
    Staff: Mentor
    If you add C2 in parallel, what should you have written instead on the lefthand side (LHS) of your equation:
    "(1/2)C2V^2 = 3 * (1/2)C1V^2"
    Your LHS is incorrect as written.
  6. Jul 8, 2013 #5
    Do you mean LHS for C2 = C1 + C2?
  7. Jul 8, 2013 #6
    berkeman
    Staff: Mentor
    Yes, the LHS should be the sum of C1+C2, not just C2. Your intuition has been correct all along. What value do you now get for C2?
  8. Jul 8, 2013 #7
    Ok I got it:
    (1/2)*(C1 + C2)*V^2 = 3 * (1/2)C1V^2
    C1 + C2 = 3C1
    C2 = 3C1 - C1 = 2C1 = 2 * 250 = 500 pF
    Thanks! :)
Have something to add?
Draft saved Draft deleted
Similar Discussions: Capacitor Question
  1. Capacitor Question (Replies: 1)
  2. Capacitor Question (Replies: 6)
  3. Capacitor question (Replies: 2)
  4. Capacitor Question (Replies: 9)
  5. Capacitor Question (Replies: 5)
Loading...
