Capacitors and Dielectric Oil: Calculating Electric Displacement and Field
In summary, the electric field within the capacitor is proportional to the dielectric material's linearity, and the capacitance is proportional to the dielectric oil's density.
teme92
185
(a) Calculate the Electric displacement of parallel plate capacitor of with a thickness d (in z), and length L (in x), and a width W (in y). Within the capacitor is a dielectric oil with a dielectric constant –εr , and the charge on the plates is ± q.
(b) Using the definition of Electric displacement, what is the Electric field within the capacitor?
(c) Calculate the capacitance? (
d) If the capacitor is turned sideways so that the width W is vertical, while the length L and thickness d are horizontal, how much oil will remain within the capacitor? (provide either a volume or a length) Assume that the density of the dielectric oil is ρ . (Warning: your final solution may not be closed form and if so, need not be fully solved)
(a) Used Gauss' Law:
[itex]\int D{\cdot}da = Q[/itex] where [itex]\int D{\cdot}da = 2DA[/itex].
Therefore: [itex]D = \frac{Q}{2A} = \frac{\sigma}{2}\hat{z}[/itex]
(b) D is proportional to electric field as dielectric material is linear:
[itex]E = -\frac{\sigma}{2\epsilon_r}[/itex]
(c) Used the formula:
[itex]C = \epsilon_r\epsilon_0\frac{A}{d}[/itex]
(d) Have no idea how to begin this part even. Any help in the right direction would be greatly appreciated.
The middle part is a scalar, the right side is a vector, those cannot be equal.
I don't think it helps to introduce new variables here, especially if you don't give a definition of them.
(d): Oil will move down until the height reaches some value h. At this height, removing more oil from the bottom does not release energy any more as moving oil out of the electric field takes energy, so no more oil moves out. You can calculate this height h.
The problem statement could be a bit clearer here - if you would try this with a real capacitor various other effects will lead to completely different results. You have to put the capacitor on top of an oil bath to get the same result in a real experiment.
Likes teme92
Ok thanks for the help, I'm working through and I'll get back to you if I need any more help.
1. What is a capacitor?
A capacitor is an electronic component that stores electrical energy in the form of an electric field. It typically consists of two conductive plates separated by a dielectric material.
2. What is dielectric oil?
Dielectric oil, also known as insulating oil, is a type of liquid used as a dielectric medium in high voltage equipment, such as capacitors. It has high electrical insulating properties and is able to withstand high voltages without breaking down.
3. How does a capacitor work?
A capacitor works by storing electric charges on its plates. When a voltage is applied to a capacitor, electrons build up on one plate and flow onto the other plate. This creates an electric field between the plates and causes the capacitor to store energy.
4. What is the role of dielectric oil in a capacitor?
The dielectric oil acts as an insulating medium between the plates of a capacitor. It prevents the plates from coming into direct contact with each other, allowing the capacitor to store more energy without short-circuiting.
5. What are the common uses of capacitors and dielectric oil?
Capacitors and dielectric oil are commonly used in high voltage equipment, such as power transmission systems, to regulate and store electrical energy. They are also used in electronic devices, such as computers and televisions, to filter out unwanted signals and stabilize voltage levels.
