Calculating Capacitor Charges with Dielectric Insertion
  • Thread starter jehan60188
  • Tags
    Capacitors
In summary, a dielectric is inserted between the plates of two capacitors, fully filling the available space. Next, the charges on each capacitor are calculated. The system still retains the same voltage, but the effective capacitance changes.
jehan60188
203
A 24 V battery is used to charge two identical capacitors CL = CR = 6 µF, in parallel
so Q(CL) = Q(CR) = 0.000144 C
the battery is removed, and the energy stored in the system is .003456 J
Next a dielectric with k = 1.4 is inserted between the plates of CR, fully filling the available space. (The dielectric carries zero net charge.)
Calculate the new values of the charges on each capacitor.
C=Q/V (capacitance = charge/electric potential)
C_new = C*k (capacitance = capacitance in a vacuum times K)
capacitors in parallel add (C = c1 + c2)
capacitors in series add their inverses (C =(1/C1 + 1/C2)^-1)
the capacitance of the system is (1/8.4 + 1/6)^-1 = 3.5 uF
since the charge doesn't change, it's still 0.000144*2 C
voltage over either capacitor is the same
V*CL + V*CR = Q
things break down from here. any pointers?
thanks!
V*CL + V*CR = Q
thanks!
I can see two ways two solve this. Neither involves considering that the capacitors are in series.
One is to consider the two capacitors to be in parallel, both while being charged, and also while the dielectric is being inserted.
The effective capacitance changes in this case, but the charge remains the same. You can then find the potential difference across the plates.​
The other is to consider the capacitors separately, realizing that after the dielectric is inserted, the extra charge, q, gained by CR is equal to the amount of charge lost by CL. The voltage across one is equal to the voltage across the other.
still lost, but I'm going to poke at the problem some more.
would love clarification and/or further information!
how much charge is gained by CR?
i figured it out
the charge in the system remains the same
the (now) 8.4 uF capacitor is responsible for 100 * 8.4/(6+8.4) percent of the charge, so i take the total charge (2*.000144) and multiply it by 8.4/(6+8.4)
thanks!
1. What is a capacitor with a dielectric?
A capacitor with a dielectric is a type of capacitor that uses a non-conductive material, called a dielectric, between its plates to increase its capacitance. This dielectric material helps to store more charge and increase the overall efficiency of the capacitor.
2. How does a capacitor with a dielectric work?
A capacitor with a dielectric works by storing electrical energy in an electric field. The dielectric material, which is an insulator, reduces the electric field between the plates of the capacitor, allowing it to hold more charge. As a result, the overall capacitance of the capacitor increases.
3. What are the benefits of using a capacitor with a dielectric?
There are several benefits of using a capacitor with a dielectric. Firstly, it allows for a higher capacitance in a smaller physical size, making it more compact. Additionally, it can increase the efficiency and stability of the capacitor, making it more suitable for use in electronic devices.
4. What are some common materials used as dielectrics in capacitors?
Some common materials used as dielectrics in capacitors include ceramic, paper, plastic, and mica. Each material has different properties that make it suitable for different types of capacitors. For example, ceramic is often used in high-frequency capacitors, while plastic is commonly used in low-frequency applications.
5. How do you choose the right capacitor with a dielectric for a specific application?
Choosing the right capacitor with a dielectric for a specific application depends on several factors, including the required capacitance, voltage rating, operating frequency, and physical size. It is important to carefully consider these factors and select a capacitor with a dielectric that meets the specific requirements of the application to ensure optimal performance.
