Homework Help: Car Accelerating
  1. Sep 2, 2014 #1
    Hello all, here is my problem:
    A car accelerates, starting from rest, with a speed that is given by:
    v(t)=vm(1-e-at)
    a) What is the top speed of the car? Explain why.
    b) How far does the car travel in time t?
    c) Suppose the car can accelerate from 0 to 60 mph in 2.9s, and has a top speed of 195 mph. Imagine a mile-long race between two of these cars, with the same finish line, but with a different starting line: One drives along the ground towards the starting line at a point one-mile away, while the other is dropped out of a plane one mile above the ground. Which one reaches the finish line first? (ignore any air resistance for the falling car).
    That is the entire problem. I just need help getting started.
    First, what does the vm represent in the speed equation?
    Second, how exactly do I calculate the top speed?
    I also suppose that I will need the position and acceleration equations which I derived from speed equation for b and c respectively.
    I got:
    x(t)=vm*((e-at)/a+t)
    v(t)=vm*(1-e-at)
    a(t)=vm*(ae-at)
  3. Sep 2, 2014 #2
    Doc Al
    Staff: Mentor
    Think of it as a constant. Once you answer part a, the notation will make more sense.
    You won't be able to get a numerical value, if that's what's throwing you off. Answer in terms of the constants given.
    You are given the speed as a function of time. If you graphed it, what would that function look like? What's its maximum value?
  4. Sep 2, 2014 #3
    I know I won't get a numerical value as the top speed. I just do not know what path to take to manipulate v(t) to get top speed.
  5. Sep 2, 2014 #4
    Doc Al
    Staff: Mentor
    Does the speed increase or decrease as time increases?
    What's the maximum value of 1-e-at ?
  6. Sep 2, 2014 #5
    Increase in time=Increase in speed.
    Max value of 1-e-at = 0
  7. Sep 2, 2014 #6
    Doc Al
    Staff: Mentor
    Good!
    Really? So the car doesn't even move? (Think that one over. :wink:)
  8. Sep 2, 2014 #7
    CWatters
    Are you sure?
  9. Sep 2, 2014 #8
    Nevermind. Duh. I was thinking something completely different. So what is the a in the exponent? Acceleration due to gravity? If so then the max value would be 1, but that doesn't make sense.
  10. Sep 2, 2014 #9
    Doc Al
    Staff: Mentor
    Treat 'a' as just another constant.
    Makes sense to me. At what time will the car have max speed? What is that max speed?
  11. Sep 2, 2014 #10
    So what I'm getting is that:
    v(t)=vm(1-e-at)
    We've said that the max value for (1-e-at) = 1
    So that means at max v(t)=vm
    In order to get that t=∞.
  12. Sep 2, 2014 #11
    Doc Al
    Staff: Mentor
    Perfect! As time goes on, the speed gets closer to the maximum value of vm.
    Perhaps now you can guess what the 'm' stands for.
  13. Sep 2, 2014 #12
    I figured that's what it stood for I seem to have a habit of jumping to conclusions like that early on in the problem and confuse my self because I get determined to make that scenario be the case (right or wrong.)
    So part a is understood. Part b would be the distance equation setting t=∞?
  14. Sep 2, 2014 #13
    Doc Al
    Staff: Mentor
    They don't want the distance at infinite time, but at time "t". (You've already solved that one in your first post.)
  15. Sep 2, 2014 #14
    See what I mean? Get ahead of myself and flustered and try to make a certain scenario fit. Then for part c I am given acceleration, the time for that acceleration, and top speed. Plug and chug then. Very helpful Al.
  16. Sep 2, 2014 #15
    Doc Al
    Staff: Mentor
    Correction: You've almost solved it. Don't forget about the constant of integration.
Have something to add?
Draft saved Draft deleted
