Calculating Final Velocity of a Car Using Uniform Acceleration
In summary, a car enters the freeway at a speed of 6.4 m/s and accelerates uniformly for 3.2 km in 3.5 minutes. Using the equation DeltaX=1/2(vi+vf)(DeltaT), we can find the final velocity. However, the attempt at a solution did not account for different units and resulted in a negative value for the final velocity. It is important to convert all units to the same before performing calculations.
CTech2015
A car enters the freeway with a speed of 6.4 m/s and accelerates uniformly for 3.2 km in 3.5 minutes. How fast in m/s is the car moving after this time?
Displacement=1/2(initial velocity + final velocity)(Time interval)
3.2=1/2(6.4+x)(3.5)
x=-4.6
? Why is this negative? What is the final velocity?
It is important to be aware of which units you are using!
What do you mean? Do we need to convert the km to m first?
You need to convert everything into the same units, It only makes sense to add/subtract/cancel units which are the same.
For example, if I'm traveling 50 miles per hour, in 1 second will I have traveled 50*1=50 miles?
Of course not, because seconds are not the same as hours. (This is essentially what you did wrong.)
1. What is car acceleration problem?
Car acceleration problem refers to any issues or difficulties a car may have with accelerating or gaining speed. This can manifest in various ways, such as slow acceleration, hesitation or jerking movements when pressing the gas pedal, or a complete failure to accelerate.
2. What are the common causes of car acceleration problems?
There are several potential causes of car acceleration problems, including issues with the fuel system (such as a clogged fuel filter or faulty fuel injectors), problems with the engine (such as spark plug or ignition coil issues), or transmission problems (such as a worn-out clutch or faulty sensors).
3. Can car acceleration problems be dangerous?
Yes, car acceleration problems can be dangerous as they can lead to loss of control over the vehicle and increase the risk of accidents. It is important to address any acceleration issues promptly to ensure the safety of the driver and others on the road.
4. How can I diagnose and fix car acceleration problems?
The best way to diagnose and fix car acceleration problems is to take the vehicle to a certified mechanic. They will be able to run diagnostic tests and identify the specific cause of the issue. Depending on the problem, the mechanic may recommend repairs or replacements for certain parts to resolve the acceleration problem.
5. Can regular maintenance prevent car acceleration problems?
Yes, regular maintenance and servicing can help prevent car acceleration problems. This includes changing the oil and filter regularly, replacing spark plugs and other engine components as needed, and keeping the fuel system clean. It is important to follow the manufacturer's recommended maintenance schedule to keep the car in good working condition and prevent potential issues with acceleration.
