How do brakes bring a car to rest?
In summary, the conversation discusses how brakes are able to stop a car's motion, despite only external forces being able to change an object's state of motion. It is explained that the friction between the brakes and wheels converts kinetic energy into heat, and the friction between the wheels and the road causes a retarding force. It is also mentioned that the same principle applies when a car accelerates from rest. The conversation then delves into a related question about the greatest retarding force exerted by the road when the brakes are applied, and it is determined that the correct answer is when the acceleration is the least, as indicated by the speed beginning to change.
sparkle123
175
If only an external force can change the state of motion of a body, how can the internal force of the brakes bring a car to rest?
I think that it may be because friction between brakes and wheels converts kinetic energy into heat. Or perhaps friction between brakes and wheels somehow (?) leads to friction between wheels and the road, causing a retarding force.
Thank you!
Your last statement about wheels and road is the important thing.
Brakes stop wheels going round they do not stop the wheel moving along the ground... think about brakes and car on ice... does it stop?
Thanks technician!
So Brakes lock wheels? I thought that was decrease the amount of friction since coefficient of kinetic friction is usually lower.
Essentially, the wheels push against the road and the road pushes back on the wheels - that's the external force. The wheels don't need to lock; just a matter of some resistance to turning so there is a push against the road.
The same thing happens in reverse when a car accelerates from rest. It's wheels push on the road and the road pushes back on the car, causing it to accelerate.
Thanks Delphi51!
Say the car is moving to the right. When it brakes, is it just that the rightward force from road decreases or is there actually a leftward force from the road?
Thanks again!
There is no (horizontal) force at all when the car is moving at constant speed.
Yes, when it decelerates, there is a leftward force causing the deceleration.
The car pushes on the road and the road pushes back with an equal and opposite force.
Newton's Third Law.
OH! Thank you! :)
I have a related question:
When the brakes of an automobile are applied, the road exerts the greatest retarding force:
A) while the wheels are sliding
B) just before the wheels start to slide
C) when the automobile is going fastest
D) when the acceleration is least
E) at the instant when the speed begins to change
I think the brakes eventually lock for this question. Aren't C and E the same (as soon as brakes are applied)? And why isn't C/E the right answer? Thanks!
It is related to the fact that the kinetic coefficient of friction is smaller than the static one.
The road has a better grip on the car in one case than in the other.
That would eliminate choice A, but how would you determine the correct answer among the remaining choices?
Thank you!
There is no retarding force when in constant motion (implied in C).
At minimum acceleration (D), the road/car force is minimum according to F=ma
(E) "speed begins to change" indicates small acceleration because acceleration doesn't change instantly. There will be a smooth downturn in the speed vs time graph and its slope (acceleration) will initially be near zero.
Thank you! :)
1. What is the purpose of the internal force in car brakes?
The internal force in car brakes is responsible for slowing down or stopping the vehicle by creating friction between the brake pads and rotors. This friction converts the kinetic energy of the moving car into heat energy, which dissipates into the surrounding air.
2. How does the internal force in car brakes work?
The internal force in car brakes is generated by the brake pads pressing against the rotating brake disc or rotor. This creates friction, which in turn slows down the rotation of the wheels and the car. The brake system also includes a hydraulic system that multiplies the force applied by the driver to make the stopping process more efficient.
3. What are the different types of internal forces in car brakes?
The two main types of internal forces in car brakes are static friction and kinetic friction. Static friction occurs when the brake pads are in contact with the rotor but are not moving, while kinetic friction occurs when the brake pads and rotor are moving against each other. Additionally, there is also rolling resistance, which is the force needed to overcome the friction between the tires and the road surface.
4. Can the internal force in car brakes fail?
Yes, the internal force in car brakes can fail due to various reasons such as worn out brake pads, low brake fluid, or malfunctioning brake calipers. It is important to regularly check and maintain the brake system to ensure its proper function and prevent any potential failures that could compromise safety.
5. How does the internal force in car brakes affect the overall driving experience?
The internal force in car brakes has a significant impact on the overall driving experience as it directly affects the car's ability to slow down and stop. A well-functioning brake system with adequate internal force can provide a smooth and controlled braking experience, while a faulty system can lead to unexpected stops or difficulty in stopping, compromising the safety of the driver and passengers.
