Car Cliff Equation: Distance to Ground from Base
  • Thread starter billybobay
  • Tags
    Car
In summary, you used one of many equations which were given in your book to solve for the car's trajectory.
billybobay
A car drives off a 50 m high cliff with a horizontal velocity of 20 m/s. How far from the base of the cliff will the car strike the ground? Assume there is no air resistance and the ground is level at the base of the cliff.
20 m
50 m
64 m
100 m
20 m/s = square root -9.8/(2)(-50 m)
64.5 m
20 = (.31)(64.5)
20 = 20
the car will strike the ground 64.5 or 64 meters away from the base of the cliff.
would that be correct and did I use the proper formulas?
I agree with your final answer to 2 digit accuracy.
I have no idea what formulas you used. You never wrote any.
Certainly "20 m/s = square root -9.8/(2)(-50 m)" is not a correct statement. The right side evaluates to 15.7, not 20.
I used one of many equations which were given in my book. And changed my numbers from theirs to mine. They were using the equation to find the velocity so I just filled my velocity given to me in my question in and found for the change of x which in their equation they filled in. You would agree that it would be 64 meters though? What equation would you suggest would be a clearer one to use?
You are supposed to tell me what equations you used first! Always write an equation first, then fill in the numbers so your reader can tell what principle you are using and follow your work!
For horizontal and vertical motion problems, I always make two headings for horizontal and vertical. Under horizontal, there is no acceleration so I write the d = vt from grade 10 physics. Under vertical, there is the constant acceleration of gravity so I write the constant acceleration formulas V = Vi + at and d = Vi*t + ½at² from grade 11. Then I fill in every letter I can with the given numbers. If I find one of the 3 equations has only one unknown, I solve for it. Then use that value in the other equations as needed. Once in a while none of the three has only one unknown, so you have to solve two of the equations as a system of 2 equations with 2 unknowns. You can solve any trajectory problem this way.
Sorry about lecturing; it is late at night here. I taught this stuff for 30 years so it just falls out like a lecture. I will be impressed if you can write out a complete solution that a grade 11 student can follow. Then you can be a physics teacher, too.
Your attempt at a solution is close, but there are a few mistakes. Let's break down the problem and solve it step by step.
First, we need to identify the given information and what we are trying to find. We are given the height of the cliff (50 m) and the horizontal velocity of the car (20 m/s). We are trying to find the distance from the base of the cliff where the car will strike the ground.
Next, we need to identify any relevant equations that can help us solve the problem. In this case, we can use the kinematic equation for distance, which is d = v0t + 1/2at^2. Since we are looking for the distance from the base of the cliff, we can set the initial position (v0) to 0. We also know that the acceleration due to gravity is -9.8 m/s^2.
Now, we can plug in our values into the equation and solve for t (time). The equation becomes 50 m = 0 + 1/2(-9.8 m/s^2)t^2. Solving for t, we get t = √(50/4.9) = 3.19 s.
Finally, we can use the formula for distance again, but this time plug in our known values for time and velocity. The equation becomes d = (20 m/s)(3.19 s) + 1/2(-9.8 m/s^2)(3.19 s)^2. Solving for d, we get d = 64.5 m.
Therefore, the car will strike the ground 64.5 meters away from the base of the cliff. Your attempt at using the formulas was close, but it seems like you may have made a calculation error. It is always important to double check your work and make sure you are using the correct formulas for the given problem. Keep up the good work!
1. What is the Car Cliff Equation?
The Car Cliff Equation is a mathematical formula used to calculate the distance between the base of a cliff and the ground below, given the initial velocity and angle of a car driving off the cliff.
2. How is the Car Cliff Equation derived?
The Car Cliff Equation is derived from the principles of projectile motion and the laws of physics, specifically the equations of motion and the trigonometric functions sine and cosine.
3. What factors affect the distance to ground in the Car Cliff Equation?
The main factors that affect the distance to ground in the Car Cliff Equation are the initial velocity of the car, the angle at which the car leaves the cliff, and the acceleration due to gravity.
4. Can the Car Cliff Equation be used for any type of vehicle?
Yes, the Car Cliff Equation can be used for any type of vehicle as long as the initial velocity and angle of departure are known. However, it is important to note that the equation assumes a perfectly flat and horizontal ground surface.
5. Are there any limitations to using the Car Cliff Equation?
Yes, the Car Cliff Equation has some limitations. It does not take into account air resistance, which can significantly affect the distance traveled. It also assumes a constant acceleration due to gravity, which may not be accurate in all scenarios. Additionally, the equation does not account for any obstacles or changes in terrain that may affect the trajectory of the car.
