Car Crash Analysis: Analyzing Friction & Speed
In summary, a consulting agency with expertise in physics has been subpoenaed to provide expert testimony in a civil court case involving an automobile accident between a Ford Escort car and a tractor-trailer truck. The police department has determined that the coefficient of kinetic friction between the tires and road for the car was 0.638 and for the truck was 0.447. The car skidded at a speed of 13.88 m/s and the truck at 5.09 m/s after the collision. Using conservation of momentum, the pre-crash speed of the car was found to be 93.63 m/s and the truck was 7
Billy12Banana
Your consulting agency, with its extensive knowledge of physics, has been subpoenaed to provide expert testimony at an automobile accident case in civil court. The case involves a crash between a Ford Escort car and a tractor-trailer truck.
1. The police department determined that the force required to drag a 130 N (29 lb) car tire across the pavement at a constant velocity is 83 N. Specifications from the truck s manufacturer claim that (for technical reasons) the effective coefficient of friction for truck tires is only 70% that of car tires. What was the coefficient of kinetic friction between the tires and the road for both the car and truck? (Include FBD)
2. After collision, the truck and car skidded at the angles shown in the diagram. The car skidded a distance of 49.8 ft before stopping while the truck skidded 9.5 ft before stopping. (1 ft=.305m) The weight of the car is 13, 600 N and the weight of the truck is 69,700 N. What was the speed of each vehicle just after the collision?
3. The pre-crash angle between the velocities of the truck and car was 90 degrees. What was the speed of each vehicle just before the collision?
4. At this intersection, the truck driver had a flashing yellow light while the car driver had a flashing red light.
a.) The car driver claims to have made a full stop at the light before entering the intersection. He also claims that the truck driver did not see him until after the collision. This would make the truck driver partially liable.
b.) The truck driver claims that the car ran the flashing red light. He also claims to have begun braking in anticipation of a collision; traveling at only 6.7 m/s (15 mph) at the moment of impact.
c.) Police measurements show that the distance for the car from the traffic light to the collision point was 13.0 m(42.5 ft) and the distance for the truck from the traffic light to the collision point was 32.8 ft (1ft=.305 m).
d.) Ford Motor Corporation specifications indicate that the maximum acceleration of a comparably loaded Ford Escort is about 3.0 m/s^2, and the maximum acceleration given for the truck is 1.2 m/s^2.
Who is at fault and why?
f=mu(N)
w=fd
1. I got .638 and .447 for the coefficients of f for the car and truck respectively.
2. I got 13.88 m/s and 5.09 m/s for v of car and truck respectively.
Don't know how to do 3 and 4.
For 3 I thought it was a conservation of momentum question and tried mv+mv=mv+mv but I really don't know. Please help, thanks! Visual of crash is attached.
Good.
And I get the same.
Let's chase down the conservation of momentum argument. You have the velocities and masses of the car and truck after the collision. You also know the angles. Momentum is a vector quantity. You can write down equations for the x and y components separately. Can you do that and show us what you get?
So for #3:
1360v=1360(13.88sin40)+6970(5.09sin10)
v=93.63 m/s for the car
6970v=1360(13.88cos40)+6970(5.09cos10)
v=7.08 m/s for the truck
Is this correct?
Yes.
Far too much. Try that again.
It's always a good idea to do a sanity check, just a mental approximation of the answer: v ~ 14 sin(40)+(697/136) 5 sin(10) ~ 14/√2 + 5 (10/57) [because 57 degrees to a radian, and this a small angle] ~ 10 + 1 = 11.
That might look difficult, but with practice it gets easier.
Yes, but I think 7.09 is closer.
13.45 for car.
I'm confused as to how to figure out who was at fault using this information and the information in #4 of the problem.
Billy12Banana said:
13.45 for car.
You have found e.g. the speed of the car at impact. The driver claims to have moved off from rest at the light. What does that tell you about the car's acceleration?
Apply the same to the truck.
So since the driver made a full stop, he had to accelerate for 0m/s to 13.45 m.
The truck driver claimed to be braking in anticipation of the collision meaning his acceleration has to be negative.
According to my calculations, the truck's velocity before the collision was 7.09 and 5.09 after. And the truck driver claims to have been traveling at 6.7 m/s at moment of impact. Since 6.7 is between 7.09 and 5.09, it seems like what the truck driver claimed is true.
Is this correct?
In order to utilize parts c and d of #4, do I need to do kinematics?
If the car driver had stopped as claimed, he
would have had to accelerate from 0 m/s to 13.45 m/sec over a span of 13.0 meters in order to collide at 13.45 m/sec as observed.
Can you show that this is implausible?
The truck driver is talking about deceleration prior to impact. You are talking about a reduction in velocity during the impact. Two different things.
Also, there is a difference between a statement being plausible and a statement being true.
Can you also explain why, for these two equations from #3, there is only one "mv" on the left side? Like just 1360v or 6970v on the left? I know I ended up with the right answers but I was confused while doing it. I used mv+mv=mv+mv. I think I just assumed the initial velocity for the other vehicle was zero because I didn't know how else to do it, but why is it zero?
There are two different directions. Each equation relates to motion in one of the two, and in each, one vehicle has no prior velocity.
1. What is car crash analysis?
Car crash analysis is the process of studying and understanding the dynamics of a car crash in order to determine the cause and contributing factors. This includes analyzing the speed, friction, and other variables involved in the crash.
2. How is friction involved in car crashes?
Friction is a force that resists the motion of two surfaces in contact with each other. In car crashes, friction plays a crucial role in slowing down or stopping the vehicle. It also affects the stability and control of the car during a crash.
3. What is the importance of analyzing speed in car crashes?
Speed is a major factor in car crashes as it directly affects the force of impact. The higher the speed, the greater the force of impact, which can result in more severe injuries and damage. Analyzing the speed of a car crash helps determine the severity of the crash and can provide insights into the cause.
4. What methods are used to analyze car crashes?
There are several methods used to analyze car crashes, including mathematical models, computer simulations, and physical crash tests. These methods help scientists and engineers understand the dynamics of a crash, including the forces involved, the role of friction, and the effects of speed.
5. How can car crash analysis help improve car safety?
By studying and analyzing car crashes, scientists and engineers can identify patterns and trends that can help improve car safety. This includes developing new safety features, improving the design and construction of vehicles, and implementing regulations and laws to reduce the number of car crashes.
11K
