1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Car Suspension, coupled ODE
  1. Oct 1, 2009 #1
    http://img27.imageshack.us/img27/2193/matlapassig2fig.jpg [Broken]
    http://img132.imageshack.us/img132/7126/matlapassig2.jpg [Broken]
    2. Relevant equations
    My impulse response is entirely different which make me believe that i have messed up my ODE. I have taken the laplace tranform to get it into the from of y to f
    3. The attempt at a solution
    [tex]m_{s}\frac{d^{2}y}{dt^{2}}-c(\frac{dy}{dt} - \frac{dy1}{dt}) + k(y - y1)=0[/tex]
    [tex]m_{u}\frac{d^{2}y1}{dt^{2}}+c(\frac{dy1}{dt} - \frac{dy}{dt}) + k(y1 - y) +k_{t}(y1-f(t))=0[/tex]
    Laplace Transform:
    Rearranging First Eqn:
    So to get the transform from y to f we want this right?
    When substituting the values in from the question my impulse response done through matlab doesnt look anything like the one given in the question...
    Have i done something wrong?
  3. Oct 1, 2009 #2
    Hey, at first look, I found these equations to be fishy: is the f(t) a force being applied on the sprung mass m_s? If so, then shouldn't the expression f(t) appear in the equation of motion of m_s as opposed to m_u as you have formulated?
  4. Oct 1, 2009 #3
    I did think of that, but being a car suspension system, it will be traveling on a road which will have the forces acting on m_u. So i put f(t) as the reaction force due to the road...
    much like this
    Mind you, i am not strong in mechanics, so there could be other flaws in it too
  5. Oct 1, 2009 #4
    Even so, the way you have used f(t) in the expressions, it appears to be the road displacement rather than a road reaction force. If that is the case then your formulation seems correct. If however, f(t) is a force on the sprung mass (like you showed in your first illustration), then f(t) should just appear as a force in the first equation.
  6. Oct 1, 2009 #5
    So, with that being said
    [tex]m_{s}\frac{d^{2}y}{dt^{2}}-c(\frac{dy}{dt} - \frac{dy1}{dt}) + k(y - y1)=f(t)[/tex]
    [tex]m_{u}\frac{d^{2}y1}{dt^{2}}+c(\frac{dy1}{dt} - \frac{dy}{dt}) + k(y1 - y) +k_{t}(y1)=0[/tex]
    I will see how this spans out in the impulse response latter but just as a check, do those new ODE's seem correct?
  7. Oct 1, 2009 #6
    Ok so assuming downward direction as positive and also assuming that the spring damper push the sprung mass upwards(i.e. the spring gets compressed), here are the ODEs:
    [tex]F = ma[/tex]
    [tex]f(t)-k(y - y1)-c(\frac{dy}{dt} - \frac{dy1}{dt}) = m_{s}\frac{d^{2}y}{dt^{2}}[/tex]
    [tex]c(\frac{dy}{dt} - \frac{dy1}{dt}) + k(y - y1) -k_{t}(y1)=m_{u}\frac{d^{2}y1}{dt^{2}}[/tex]
    So your equations are correct except for the sign on the damper force in the first equation.
  8. Oct 1, 2009 #7
    doing what i did before i gte the transfer function to be
    plugging in the values i get an unstable system and the impulse response is exponentially increasing
    for k = 30 N/mm (and also kt) i put in the value of 30*10^-3 right ?
    I have tried it both with 30 and 30*10^-3 and it is still the same response...
    and i thought this was going to be a simple question...
  9. Oct 6, 2009 #8
    k (and kt) are in N/mm so their values in SI units would be 30N/mm or 30x10^3 N/m
