Why Does a Car Traveling at Constant Velocity Still Do Work?
You can solve for the two final velocities. The golf ball will have a higher velocity, but the bowling ball as a greater mass will have a greater momentum.
Cpt. Bob
Im studying on my own and don't have the benefit of input from an instructor, so any help with these few questions would be very appreciated.
1. If a car traveling at a constant velocity has a net force of 0, why can it be said that work is being done on the car when Work equals force multiplied by distance?
2. A golf ball is thrown at and bounces off a very massive bowling ball that is initially at rest. Which ball, after impact has greater momentum, and which has greater kinetic energy?
On question two, I think the answer is the bowling ball has greater momentum, since the golf ball changed velocity double what it would have relative to the bowling ball if it had not bounced, and since momentum is conserved, twice the momentum would be imparted into the bowling ball in order for net momentum = 0. And since KE=.5mv^2, I would think the golf ball would have more kinetic energy, having a much higher velocity. Am I correct here, or am I missing something. Thanks.
In the real world, there is air resistance to the motion of a car. That is a force against the motion, and so an additional force has to be supplied by the engine to make up for it. Seperately, the two forces do work on the car. The work done by the air is negative, and the work done by the engine is positive. For zero net force, the work done by each force has precisely the same magnitude, so they add up to zero.
I would do this explicitly.
Let:
m=mass of golf ball
M= mass of bowling ball
vi=initial velocity of golf ball
vf=final velocity of golf ball
V=final velocity of bowling ball
Conservation of Momentum:
mvi=mvf+MV
If the collision is elastic, then we also have...
Conservation of Kinetic Energy:
(1/2)mvi2=(1/2)mvf2+(1/2)MV2
You have two equations and two unknowns (vf and V).
1. When a car is traveling at a constant velocity, there is no change in its speed or direction. This means that the net force acting on the car is equal to 0, since there is no acceleration. However, even though the net force is 0, work can still be done on the car. This is because work is defined as the product of force and distance, not just force alone. So, even though there is no net force, the car is still moving and covering a certain distance, which means work is being done on it.
2. Your understanding of the situation is correct. The bowling ball, being more massive, will have a greater momentum after the impact. This is because momentum is directly proportional to mass. And as you correctly stated, since momentum is conserved in a collision, the golf ball will transfer twice its momentum to the bowling ball. However, when it comes to kinetic energy, the golf ball will have a greater amount. This is because kinetic energy is directly proportional to the square of velocity, and the golf ball will have a higher velocity after the collision due to the elastic nature of the collision. So, the golf ball will have a greater kinetic energy compared to the bowling ball.
1. What is car velocity?
Car velocity is the speed at which a car is moving in a particular direction. It is typically measured in miles per hour (mph) or kilometers per hour (km/h).
2. How is car velocity different from car speed?
Car velocity and car speed are often used interchangeably, but they are actually different concepts. Car speed refers to the rate at which a car is moving, while car velocity includes both the speed and direction of the car's motion.
3. How is car velocity calculated?
Car velocity is calculated by dividing the distance traveled by the amount of time it took to travel that distance. For example, if a car travels 60 miles in 1 hour, its velocity would be 60 miles per hour.
4. What factors can affect car velocity?
Several factors can affect car velocity, including the car's engine power, road conditions, and air resistance. Changes in these factors can cause the car's velocity to increase or decrease.
5. Why is it important to know a car's velocity?
Knowing a car's velocity is important for several reasons. It can help drivers stay within the speed limit and drive safely. It also allows scientists and engineers to study and improve car performance and design.
