Homework Help: Carbon half life
  1. Feb 15, 2015 #1
    A sample containing carbon-14 has 16000 decays per minute. If the half life of carbon-14 is 5730 years. Aproximately how many decays per minute would be occurring after another 50 000 years.
    Answer: approximately 40 decays per minute.
    2. Relevant equations
    N= No x e^-λt
    T=in2/λ
    A= λN ( A is the decay rate of sample I.e number of decays per second)
    3. The attempt at a solution
    Calculated the value of λ first from in2/5730 and got 1.2 x 10^-4.
    Then tried to plug it into A= λN and tried to get the value of N by substituting the first activity of 16000.
    From here I am stuck because I realised even if I find N and plug it back into the formula I'll be getting the same result. Which makes me confused about the whole question because I would have thought that the decay rate would be constant for a particular sample.
    Any help would be greatly appreciated. Thanks in advance.
  3. Feb 15, 2015 #2
    Hi,
    Examining your given data, you are given a time rate of change, a half-life, and you want another time rate of change after a finite amount of time.
    It looks like your first plan of action should be to find the initial amount of carbon-14 present, since that is a rather integral part of your equation. I'm not sure what mathematics you have covered, but the derivative of your function N(t) with respect to t will give you an expression for the rate of change at any time t (that's what your third equation looks to be, but with time set to 0).
    Hope that helps!
  4. Feb 15, 2015 #3
    BvU
    2017 Award
    Hello Wing, and a belated welcome to PF :smile:
    "decay rate would be constant for a particular sample" may need some more explanation: what is constant is the probability that one single carbon-14 nucleus decays in a given time. The greater that probability, the more active a sample of a radioactive material. But the activity of a sample also depends on the number of carbon-14 nuclei in the sample, and that number decreases by 1 with every decay. So we write a differential equation for the decay rate (the number of decays per unit time) $${dN\over dt} = -\lambda N$$with the solution you indicate:$$N(t) = N_0 e^{-\lambda t}$$This can also be written as ##N(t) = N_0 e^{- t/\tau}## with ##\tau = 1/\lambda##, or as $$N(t) = N_0 \;2^{- t/\tau_{\scriptscriptstyle 1\over 2}}$$
Have something to add?
Draft saved Draft deleted
Loading...
