Homework Help: Card Probabilities
  1. Dec 14, 2012 #1
    I need some help solving this homework problem.
    If you were to randomly select a card one at a time without replacement from a shuffled deck until only face cards remain in the deck, what is the probability that the king of hearts remains in the deck? Assume there are 16 face cards in a 52 card deck.
  3. Dec 14, 2012 #2
    jim mcnamara
    Staff: Mentor
    IF you have already removed all of the "non" face cards, you now have a deck of sixteen cards. How many of those remaining cards are the king of hearts?
    The probability is: [how many king of hearts cards remain] / [cards left in the small deck]
  4. Dec 14, 2012 #3
    I think the problem with your logic is that you don't necessarily have sixteen cards left in the deck.. it could be any number of face cards. Im having trouble trying to figure out how many face cards are left.
  5. Dec 14, 2012 #4
    My two cents: Jim McNamara logic is sound.
    The problem with your logic is that - if you assume that the tricky side of your problem is not in the way in which it is written, but in some mathematical content - then you have to consider the possibility that you take the 16 face cards from the first sixteen selections... (remote but possible - if you want it's easy to get the probability of that kind of shot).
    On the contrary I agree with jim mcnamara: it seems that the tricky side is in the way in which the problem is written down. It gives you an info that it's basically not relevant, while as a solver you should focus only on the fact that in the end you have to compute the probabilities of getting the king of hearts out of the 16 face cards.
  6. Dec 14, 2012 #5
    Ray Vickson
    There is something wrong with the problem statement. Sometimes all cards would be removed, because the very last card is non-face. So, does the problem mean to ask for a conditional probability that, given only face cards left, the K of hearts is present, or is it asking for the probability that some face cards (but no others) are left, and that one of these is the K of hearts?
  7. Dec 14, 2012 #6
    haruspex
    I disagree with all other responders so far, radically so with Mcnamara and Kolmin :biggrin:.
    It's fairly clear that there is a nonzero chance that you will have no cards left, and that this simply constitutes one of the "HK not in remaining deck" cases.
    Try thinking of it working up from the bottom of the deck. See if you can get a recurrence relation on the probability the HK will be in the remaining deck given that the last r cards are other face cards.
  8. Dec 14, 2012 #7
    Suppose we think of the cards as being laid out from left to right, corresponding to top to bottom of the deck. The king of hearts will remain in the deck if and only if all the non-face cards are to its left; the locations of the other face cards are irrelevant. So...
  9. Dec 14, 2012 #8
    haruspex
    Ha!, there's a much easier way. Think about where the HK needs to be in relation to the non-face cards.
  10. Dec 14, 2012 #9
    I'm interested in the solution to this problem too since I'm taking an AP Stats course.
    Can it be the probability of not drawing the king of hearts when randomly selecting cards from the deck?
    (1 - 51/52)
    Because there can be the possibility of having only one card left that is the face card.
    I'm not sure whether the question is stating that all of the face cards are left.
  11. Dec 15, 2012 #10
    haruspex
    No, it's a fair bit higher than that. Try my hint.
    No, only that the HK and any number of other face cards are left, but no face cards.
  12. Dec 15, 2012 #11
    Wait, sorry I'm confused.
    'But no face cards' ?
    You stated that only 'the HK and any number of other face cards are left'
  13. Dec 15, 2012 #12
    haruspex
    Sorry, I meant no non-face cards.
  14. Dec 15, 2012 #13
    Oh, okay.
    Is this your hint?
    "Try thinking of it working up from the bottom of the deck. See if you can get a recurrence relation on the probability the HK will be in the remaining deck given that the last r cards are other face cards."
    I don't know what recurrence relation means.
    is it the probability of picking face cards? (16/52) * (15/51) * (15/50) ...
  15. Dec 15, 2012 #14
    haruspex
    No, I meant my later post: Think about where the HK needs to be in relation to the non-face cards.
  16. Dec 15, 2012 #15
    I'm not sure how one would count all possibilities of finding the HK among the only-face-cards recursively. I'd go about this as follows:
    At some point you've removed all 36 non-face cards, plus some number k of face cards (0 ≤ k ≤ 16). You know that card number (36+k) must have been one of the 36 non-face cards, that k of the 15 non-HK face and the remaining 35 non-face cards must be distributed among the first (35-k) places, and that the HK plus (15-k) face cards are distributed among the final (16-k) positions.
    Add the resulting expression for 0 ≤ k ≤ 16, divide the sum by 52!, and that should be the probability you're looking for.
  17. Dec 15, 2012 #16
    I suppose HK would need to be in the old deck?
    I think he meant 12 face cards in a deck.
    So, if I removed all of the face cards except for the HK, the probability of HK being in the old deck would be 1/(52-11)? Couldn't I also have removed the HK?
  18. Dec 15, 2012 #17
    jim mcnamara
    Staff: Mentor
    I agree that the problem statement is confusing. I took it to mean someone created a deck of 16 face cards. Which is wrong.
    A more understandable version to me is:
    That means you cannot have drawn the KH.
  19. Dec 15, 2012 #18
    Ray Vickson
    The event we want occurs if the last (k+1) cards are the KH followed by k face cards, for k = 0,.., 15. We can compute the probabilities of these 16 possibilities and sum them. It helps to use a computer algebra system and to keep all results as rational numbers, because doing that produces a very simple final result. The final result is so simple and so obviously related to the number of face and non-face cards that it makes one suspect that a clever and insightful simple solution must exist.
  20. Dec 15, 2012 #19
    haruspex
    The OP was perfectly clear: keep drawing at random until no non-face cards are left; what is the probability the HK has not been drawn? In contrast, the version quoted above is opaque. I'm not at all sure it's saying the same thing.
  21. Dec 15, 2012 #20
    haruspex
    Quite so - see post #8.
  22. Dec 15, 2012 #21
    Would you mind taking a look at my previous post?
  23. Dec 15, 2012 #22
    I'm going to jump in and contribute here. Maybe I know what I'm talking about and maybe I don't.
    First, I'm going to assume the original poster meant 12 face cards (four kings, queens, and jacks) and not 16.
    As I understand the question, the percentage has to be at LEAST .0833.
    Naturally, when nothing but face cards are left in the deck, the king of hearts has an equal chance of being left as any other face card. And 1 chance out of 12 is .0833.
    Most of the time, all face cards will be drawn prior to the end of the deck. And when that happens, the entire "sim" or "game" or "trial" can be thrown out, since it doesn't meet the requirements. The requirements state
    ..."until only face cards remain in the deck."
    I wrote a computer program to simulate this. I'm still checking my code for errors, but as of now, after a short, 5 million trial run, 76% of the time I must exit the sim and start over... since I removed all of the face cards PRIOR to running through the deck.
    And yet when I DO COME TO A TRIAL when NOTHING but face cards remain in the deck, I can then check the remaining cards. And .1059 percent of the time the King of Hearts is among those few remaining cards.
    As I read through the posts, it seems clear to me that not everyone is on the same page, regarding the actual question.
  24. Dec 15, 2012 #23
    haruspex
    Not sure what you mean. I'm saying, suppose we draw from the top always. (It can't matter whether we do that or draw randomly from anywhere within the deck.) Consider the positions of the non face cards and the HK within that deck at the start. For what initial positions will the HK be left when we've drawn all non-face cards? Does it matter where the other face cards are?
    Whatever. Say there are F face cards, D cards in the full deck.
    I'm not following what you're saying there. "Old" deck? Removing them as part of the draw process or throwing them away in advance? But you have the right answer.
  25. Dec 15, 2012 #24
    I meant removing the king of hearts as part of the process of randomly drawing them.
    So the correct answer is: 1/(52-11) = 1/41 ?
    Seems too simple...if someone would please explain indepth why that is.
  26. Dec 15, 2012 #25
    haruspex
    Yes, if only 12 face cards. More generally, 1/(D-F+1), where D in the deck, F face cards, one face card of interest.
    All that matters is that the HK would be drawn (if we were to continue right through the deck) after all non-face cards have been drawn. Where in the sequence other face cards are drawn is immaterial. So it comes down to the prob that the HK is the last of those D-F+1 cards to be drawn.
