What is the secret behind this math card trick?
  • Thread starter Whalstib
In summary, the person showing the trick must tell the person they are showing the trick the math behind it in order to keep them in the dark.
Whalstib
119
I've spent a few minutes...or more<G> trying to crack this one...
http://www.metacafe.com/watch/535213/math_card_trick_revealed/
...to no avail.
After trying it much becomes apparent but not the final answer.
I tried it 5 times and it worked every time!
Warren
It works on how the cards are laid down. That is about as far as I can explain that without trowing gibberish!
If you like the math card tricks check out CardTrickTeacher (Mismag822) on youtube. he has a whole bunch of math card tricks!
It only matters the three first blocks of cards, since all the others are discarded. Suppose the cards that initiate each block are A, B and C respectively.
You have 11 - A cards in the first block, 11 - B in the second and 11 - C in the third, or 33 - (A + B + C) in the total.
Since there are 52 cards in the deck, the remaining cards are 52 - [33 - (a + B + C)] or 19 + A + B + C.
You discard 19 cards from the remaining. You have A + B + C cards.
You uncover the top cards of the first and third blocks (A and C).
You separate A + C cards from the remaining and you get B, the top card of the center block.
The thing is, it really doesn't involve math at all when you think about it, which makes it simpler... It's memory.
Notice he doesn't shuffle the stacks, so it may involve some math shenanigans, but its also a memory trick possibility.
I just tried it both ways, and both ways work (math and memory)
The best part of the trick though is using the formula and telling the person you are showing the trick exactly what you are doing the whole way through. The average person will be just as baffled, if not more so. Every person I have shown it to has believed I was pulling a fast one on them even though I told them at the beginning it was purely a trick of math.
Yea the point of the trick is not that you know what the top card is, but that the number of cards you are holding is the same as the top card.
What is the "Math Card Trick: 535213"?
The "Math Card Trick: 535213" is a mathematical card trick that involves a series of steps to reveal the chosen card of a participant.
How does the "Math Card Trick: 535213" work?
The trick involves using basic mathematical operations to determine the chosen card. The numbers 5, 3, 5, 2, 1, and 3 represent the steps in the trick, and each step narrows down the possible choices until the chosen card is revealed.
Do I need any special equipment to perform the "Math Card Trick: 535213"?
No, the "Math Card Trick: 535213" can be performed with a standard deck of playing cards and does not require any special equipment.
Is the "Math Card Trick: 535213" difficult to learn?
The trick may seem complicated at first, but with practice, it can be easily mastered. It may require some quick mental math, but it is not considered a difficult trick.
Can the "Math Card Trick: 535213" be performed with any deck of cards?
Yes, the trick can be performed with any deck of cards as long as the numbers 5, 3, 5, 2, 1, and 3 are used as the steps in the trick. However, it is important to make sure the deck is well-shuffled before beginning the trick.
  • General Discussion
  • Mechanical Engineering
  • Math Proof Training and Practice
  • New Member Introductions
