Calculating Maximum Cycle Temperature in Carnot Cycle | Homework Solution
In summary, the conversation revolved around calculating the maximum cycle temperature and required heat supply for an ideal engine operating on the Carnot cycle. Participants discussed the use of the first law of thermodynamics and the Carnot efficiency equation to solve for the maximum temperature. The final solution was found to be 66.67°C with an efficiency of 62.5%.
db725
35
An ideal engine operating on the Carnot cycle with a minimum temperature of 25°C develops 20 kW and rejects heat a rate of 12 kW. Calculate the maximum cycle temperature and the required heat supply of the cycle.
Qhot/Thot =Qcold/Tcold
Since this is ideal entropy must be conserved. Δs hot =Δs cold is as far as I got.
Really stuck with this not sure how to go about it, any help would be greatly appreciated
What about the first law of thermodynamics?
Carnot Efficiency is n=1-(Qc/Qh), Qc is heat rejected, Qh is heat supplied
also Carnot efficiency is n=1-(Tc/Th)
Drawing a control volume around the device, (20 KW + 12 leaving) means 32 input or Qh=32, thus you have an efficiency, and then you can use this efficiency to solve for Th
So n=1-(12/32)=62.5% efficient
.625=1-(tc/th)
Tc/.375=Th thus 25/.375=66.67 C
hope that helps
Thanks very much. Makes complete sense now
I would approach this problem by using the fundamental principles of thermodynamics. The Carnot cycle is a theoretical cycle that represents the most efficient way to convert heat into work, and it consists of two isothermal and two adiabatic processes.
First, we can use the equation for efficiency in a Carnot cycle: η = 1 - Tcold/Thot. We know that the efficiency of an ideal Carnot cycle is 1, so we can rearrange this equation to solve for the maximum cycle temperature, Thot. This gives us Thot = Tcold / (1 - η). Plugging in the given values, we get Thot = (273+25) K / (1 - 1) = 298 K.
Next, we can use the equation for heat transfer in an isothermal process: Q = nRTln(V2/V1). In this case, we are given the work (20 kW) and heat rejection (12 kW) rates, so we can solve for the heat supply, Qhot. This gives us Qhot = (20 kW + 12 kW) / ln(V2/V1). We know that in an isothermal process, the volume ratio is equal to the temperature ratio, so V2/V1 = Thot/Tcold. Plugging in the values, we get Qhot = (32 kW) / ln(298 K / 298 K) = 32 kW.
Therefore, the maximum cycle temperature is 298 K (or 25°C) and the required heat supply is 32 kW. This shows that the Carnot cycle is able to convert all of the supplied heat into work, and it also highlights the importance of temperature difference in the efficiency of a heat engine.
1. How do you calculate the maximum cycle temperature in a Carnot Cycle?
In order to calculate the maximum cycle temperature in a Carnot Cycle, you need to use the Carnot efficiency formula: Efficiency = (Thot - Tcold) / Thot, where Thot is the absolute temperature of the hot reservoir and Tcold is the absolute temperature of the cold reservoir. The maximum cycle temperature will be the temperature of the hot reservoir.
2. What is the significance of calculating the maximum cycle temperature in a Carnot Cycle?
The maximum cycle temperature in a Carnot Cycle gives us an idea of the theoretical upper limit for the efficiency of any heat engine operating between the given temperatures of the hot and cold reservoirs. This is important in understanding the limitations of real-world heat engines and improving their efficiency.
3. Can the maximum cycle temperature in a Carnot Cycle ever be reached?
No, the maximum cycle temperature in a Carnot Cycle is a theoretical limit and cannot be reached in reality. This is due to factors such as friction, heat loss, and other inefficiencies in real-world heat engines. However, the closer an engine operates to the maximum cycle temperature, the more efficient it is.
4. How does the maximum cycle temperature in a Carnot Cycle compare to the hot and cold reservoir temperatures?
The maximum cycle temperature in a Carnot Cycle is always higher than the cold reservoir temperature and lower than the hot reservoir temperature. This is because the Carnot efficiency formula requires the difference between these two temperatures to calculate the maximum cycle temperature.
5. Can the maximum cycle temperature in a Carnot Cycle be affected by any external factors?
No, the maximum cycle temperature in a Carnot Cycle is solely determined by the temperatures of the hot and cold reservoirs. It is not affected by any external factors such as the type of working fluid or the size of the engine, as long as the temperatures of the reservoirs remain constant.
