1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Carnot Engine
  1. Nov 1, 2014 #1
    rlc
    A Carnot engine uses a hot reservoir consisting of a large amount of boiling water and a cold reservoir consisting of a large tub of ice and water. When 6437 J of heat is put into the engine and the engine produces work, how many kilograms of ice in the tub are melted due to the heat delivered to the cold reservoir?
    2. Relevant equations
    Q=m*(deltaHf)
    efficiency=1-(T_cold/T_hot)
    3. The attempt at a solution
    Searching online, I found those equations but nothing is working for me.
    With the efficiency, I found:
    1-(273/373)=0.268
    And the heat of fusion for water is 3.34E5 J/kg
    What am I missing?
  3. Nov 1, 2014 #2
    haruspex
    2016 Award
    Given the efficiency and the quantity of heat input, how much work is output? How much heat is left to go into the cold reservoir?
  4. Nov 1, 2014 #3
    rude man
    You know T1 and T2 and Q1. Using zero universe entropy change as your criterion you can figure out Q2 and then of course the amount of ice meltred. Assume there is still ice left at T2 when the process ends (T2 is constant = 273K).
  5. Nov 2, 2014 #4
    rlc
    Would the work output be the efficiency times the J heat put into the engine?
  6. Nov 2, 2014 #5
    rlc
    Aha! I figured it out!
    100-26.8% = 73.2%--of the added energy should be delivered as heat to the cold reservoir.
    deltaH=m(Lf)
    (0.732)(6437J)=m(3.34E5J/kg)
    m=0.0141 kg ice melted
    Thank you both for helping me!!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Carnot Engine
  1. Carnot engine (Replies: 7)
  2. Carnot Engine (Replies: 2)
Loading...
