Carnot Reversible Machine: Exploring the Impact on 2nd Law of Thermodynamics
In summary: In other words, the Carnot refrigerator will not work and the heat engine will be violating the 2nd law.
Chacabucogod
56
I was reading Cengel's thermodynamics and noticed that he uses a thought experiment to show that there is no machine that is more efficient than the Carnot reversible machine. He says that both a reversible machine and an irreversible machine are connected to high and low temperature deposits, and that they both receive Qh from the high temperature deposit. He next assumes that the irreversible machine is more efficient than the Carnot machine, and reverses the Carnot machine so that it works as a "refrigerator". The refrigerator is going to be providing Qh to the hot deposit and the irreversible machine will receive Qh so that the deposit can be taken away and both of the machines connected. Then the machines would not have two deposits to complete the cycle and it would not agree with the second law.
Now if I don't assume that the Carnot machine is less efficient than the irreversible machine and reverse it wouldn't the second law be broken too? Or would the Qh that the Carnot machine is providing be less than the required by they second machine?
Thank you
Science news on Phys.org
Another way to see it is with both reservoirs connected, and the combination of the heat engine and the Carnot refrigerator as one machine. You would then get a heat engine that transfers heat from the cold reservoir to the hot one, without any external input. This is an obvious violation of the 2nd law.
Remember that there is "work" between the two machines. If the heat engine's efficiency is equal or less than a Carnot engine, then the work produced by it, when supplied to the Carnot refrigerator, will lead to a transfer of heat from cold to hot reservoirs (by the Carnot refrigerator) that is less than the consumption of heat from the hot reservoir by the heat engine.
1. What is a Carnot Reversible Machine?
A Carnot Reversible Machine is a theoretical device that operates on a reversible thermodynamic cycle, meaning it can run both forward and backward without any loss of energy. It is a highly efficient machine that serves as a benchmark for other real-life machines.
2. How does a Carnot Reversible Machine work?
A Carnot Reversible Machine works by undergoing a series of reversible processes, such as isothermal expansion and compression and adiabatic expansion and compression. These processes allow the machine to convert heat energy into work without any energy loss.
3. What is the impact of a Carnot Reversible Machine on the 2nd Law of Thermodynamics?
A Carnot Reversible Machine demonstrates the 2nd Law of Thermodynamics, which states that heat cannot flow spontaneously from a colder object to a hotter object. The machine achieves this by maintaining a constant temperature difference between the hot and cold reservoirs, ensuring that heat only flows in one direction.
4. What are the practical applications of a Carnot Reversible Machine?
Although a Carnot Reversible Machine is a theoretical concept, its principles have been applied in real-life applications such as heat engines, refrigeration systems, and power plants. It serves as a standard for measuring the efficiency of these machines.
5. Can a Carnot Reversible Machine ever be achieved in reality?
No, a Carnot Reversible Machine is a theoretical concept that cannot be achieved in reality due to the presence of friction and other energy losses. However, its principles have been used to design highly efficient machines that come close to its theoretical efficiency.
12K
12K
15K
