Cartesian Equation Graph help
In summary, the Cartesian equation y=square root of x represents a curve where the value of y is equal to the square root of the corresponding value of x. When t>0, the parametrized curve traces the positive portion of the curve, while t<0 traces the negative portion. By dropping the t<0 part, we lose the negative portion of the graph, leaving only the positive portion. However, it would be more accurate to ask for the portion of the graph of y=x^2 traced by the parametrized curve.
akeber0
Cartesian Equation Graph HEELP!
1. x=t, y=square root of t, t>0
cartesian equation: y=root of x
2. what portion of the graph of the cartesian equation is traced by the parametrized curve?
3. I don't understand how to find the solution
When t=0, what are x and y? If t> 0, what are x and y? If t< 0, what are x and y? What part of the graph of [itex]y= \sqrt{x}[/itex] do you lose by dropping the t< 0 part? What part is left (the t> 0 part) ?
Does the problem itself mention the Cartesian equation [itex]y= \sqrt{x}[/itex]? It would be a better problem if it asked "What portion of the graph of y= x2 is traced by the paramtrized curve?"
1. What is a Cartesian equation graph?
A Cartesian equation graph, also known as a rectangular coordinate graph, is a visual representation of an equation in the x-y coordinate plane. It is named after the French mathematician and philosopher René Descartes, who first introduced the concept.
2. How do I plot a point on a Cartesian equation graph?
To plot a point on a Cartesian equation graph, you need to locate the x-coordinate and y-coordinate on the graph and mark the point where they intersect. The x-coordinate is the horizontal distance from the origin (usually marked as 0) and the y-coordinate is the vertical distance from the origin.
3. What is the difference between a linear and a nonlinear Cartesian equation graph?
A linear Cartesian equation graph is a straight line, while a nonlinear Cartesian equation graph is a curved line. This is because linear equations have a constant slope, while nonlinear equations have a changing slope.
4. How do I determine the slope of a line on a Cartesian equation graph?
The slope of a line on a Cartesian equation graph can be determined by finding the change in y-coordinates over the change in x-coordinates between two points on the line. This is represented by the formula slope = (y2-y1)/(x2-x1).
5. Can I use a Cartesian equation graph to solve equations?
Yes, a Cartesian equation graph can be used to solve equations by graphing the equation and finding the point(s) where the graph intersects the x-axis. These points represent the solutions to the equation.
