How Does Catalysis Work in Catalytic Converters?
  • Thread starter sciman
  • Tags
    Converter
In summary, a catalytic converter is a device that reduces harmful emissions from a vehicle's exhaust system through a chemical reaction with precious metals. The catalysts in the converter speed up the reaction, and the device has benefits such as reducing air pollution and improving fuel efficiency. Factors such as temperature and maintenance can affect its efficiency, and common problems can be fixed through replacement or cleaning.
sciman
24
You have to show your attempts, this is a forum policy. Also, all homework like questions should go to homework forum.
how exactly does catalysis in catalytic converter works?
I mean, what is the molecular role of the metal catalysts that facilitate the reaction?
Chemistry news on Phys.org
anyone??
where can I find a paper analysing this subject?
in medicine you have articles for almost everything you ever wanted to study or any hypotheses you would like to make
and all in one place: pubmed
but in scientific/engineering stuff I think the literature is rather poor
or I miss something?
What is a catalytic converter and how does it work?
A catalytic converter is a device that is used to reduce harmful emissions from a vehicle's exhaust system. It works by converting pollutants such as carbon monoxide, nitrogen oxides, and hydrocarbons into less harmful substances through a process called catalytic conversion. This is achieved through a chemical reaction between the pollutants and precious metals, such as platinum, palladium, and rhodium, which are coated onto a ceramic honeycomb structure inside the converter.
What is the role of a catalyst in a catalytic converter?
A catalyst is a substance that speeds up a chemical reaction without being consumed in the process. In a catalytic converter, the precious metals act as catalysts, facilitating the conversion of harmful pollutants into less harmful substances. The catalytic converter is designed to provide a large surface area for the catalyst to interact with the exhaust gases, allowing for more efficient conversion.
What are the benefits of using a catalytic converter?
The use of a catalytic converter in vehicles has significantly reduced air pollution and improved air quality. It also helps to comply with emissions regulations set by government agencies. Additionally, a catalytic converter can improve fuel efficiency by allowing the engine to operate at optimal levels, leading to cost savings for the vehicle owner.
What factors can affect the efficiency of a catalytic converter?
The efficiency of a catalytic converter can be affected by a variety of factors, including the operating temperature, the ratio of air to fuel in the engine, and the condition of the converter itself. A malfunctioning oxygen sensor or a damaged converter can also decrease its effectiveness. Regular maintenance and proper use of the vehicle can help maintain the efficiency of the catalytic converter.
What are the common problems with catalytic converters and how can they be fixed?
Some common problems with catalytic converters include clogging due to the buildup of unburned fuel, physical damage, and contamination by substances such as engine oil. These issues can be fixed by replacing the damaged converter or using a chemical cleaner to remove the build-up of pollutants. It is important to address any issues with the catalytic converter promptly to prevent further damage and ensure proper functioning of the vehicle.
