Why Does the Sag Formula Require Multiple Applications for Measuring Distances?
In summary, the sag formula (Cs = (-w squared)(L cubed)/24(P squared)) is necessary when measuring a distance with a 100 foot steel tape supported at both ends. This is because the sag in the tape varies as the square of the span, making it necessary to apply the formula eight times for a distance of 735 feet. This formula is based on the parabolic approximation of the more exact catenary curve, and works well for small sag/span ratios. The accuracy of the approximation is not known until the exact equation is solved, making it a challenge to find the exact solution. However, with modern technology such as laser measurements, the need for the sag formula is eliminated.
Tsmith
Sag formula
When measuring a distance with a 100 foot steel tape supported at both ends the sag formula needs to be applied to correct the distance. Does anybody know why an overall distance does not work in this sag formula? For example If you measure a distance of 735 feet you would have to apply the formula eight times once for each set of measurements. Seven for 100 feet and once for 35 feet and add the eight results. Why does the formula not work if you enter 735 feet?
Cs = (-w squared) (L cubed) / 24 (P squared)
Cs = correction for sag
w = weight per unit length of the tape (pounds per foot)
l = length of the suspended section of tape in feet
P= tension applied to the tape
It would work IF your tape was 735 feet long! (and the sags were relatively small compared to the span; the formula you site is the for the parabolic approximation of the more exact catenary curve, and works quite well for small sag/span ratios).
But you only have a 100 foot tape, and the corrections for sag must be made each time for 8 times. This is because the sag in the tape varies as the square of the span, such that the correction must be made for each measurement. The correction for sag, for a 100 foot length, added up over 7 times for a 700 foot measurement,will be much less than the correction factor for a full length 700 foot tape over that distance.
Welcome to PF!
A quick answer is that the amount of sag is not simply proportional to the length of tape. So for example, a 200 foot tape sags more than twice as much as a 100 foot tape.
Also, a picture is worth a thousand words:
Solving the exact situation of a cable supporting its own weight (uniform catenary problem) over a horizontal distance x:
In this case, the slope of the cable dy/dx as a function of the horizontal distance x from the center is
dy/dx = sinh(x/c) where c = T/w,
T = horizontal tension (pounds) and w = cable weight/foot (pounds per ft.)
Using horizontal distance x and cable length L, the cable length is given by integrating
L = int{ [1 + sinh2(x/c)]1/2} dx from -x/2 to +x/2
L = int{cosh(x/c)} dx from -x/2 to x/2 = 2c sinh(x/c)0x/2 = 2c sinh(x/2c)
Inverting L and x, we get x as a function of L (the measuring tape length)
x = 2c sinh-1(L/2c)
So using measuring tape length L = 100 ft, T = 100 pounds (horizontal tension)
and w = 0.1 pounds per foot, and c = T/w = 1000 feet.
We get for the horizontal (line of sight) distance x = 99.9584 feet.
So in this case for a measured distance using stretched 100 foot tape, the actual horizontal distance is 99.9584 feet. Thus the actual distance is 0.0416 feet shorter than the 100 foot measuring tape. For 700 feet (7 x 100 ft measurements), the actual distance x is 699.7088 feet. adding 34.9982 feet for the final 35 foot measurement, we get a straight line distance of 734.987 feet.
You get just about exactly the same value using Tsmith's equation which is based on the parabolic approximation of the catenary curve (y=wl^2/8(T), and delta L = 8(y)^2/3L, thus C_f = w^2(L^3)/24T^2), which is a heck of a lot easier. When sags are small compared to spans (less than a few percent), the approximation works extremely well.
Although it is always nice to find an adequate approximation like the parabola for suspension bridges, the accuracy of the approximation is not known until the exact equation is solved. Besides, isn't finding the exact solution a challenge?
I suppose if you have a calculator with the hyperbolic functions, it's not such a big deal; but when measuring with a tape measure, the accuracy is only as good as your assumed value for tension (and temperature) which could be way off. I learned the correction factor back in the days when all we had were slide rules. I now like the laser measurements instead. No challenge!
Thanks for you responses. I work in the survey field. I understood why it would not work but did not have the background in physics to explain it.
What is the catenary correction formula and what is its purpose?
The catenary correction formula is a mathematical equation used to determine the difference in length between a straight line and a curve suspended between two points. It is commonly used in engineering to calculate the sag in cables or wires, and it accounts for the weight and tension of the suspended object.
How is the catenary correction formula derived?
The catenary correction formula is derived from the catenary curve, which is the shape formed by a rope or cable suspended between two points under its own weight. The formula takes into account the natural logarithm and the length of the suspended object to calculate the correction needed.
What factors affect the value of the catenary correction formula?
The value of the catenary correction formula is affected by the weight and tension of the suspended object, the distance between the two points, and the slope of the suspended curve. Changes in any of these factors will result in a different value for the catenary correction formula.
How is the catenary correction formula used in real-world applications?
The catenary correction formula is used in many real-world applications, such as the construction of suspension bridges, power lines, and cable-stayed structures. It is also used in the design and installation of zip lines and other recreational activities that involve suspended cables.
Are there any limitations to the catenary correction formula?
While the catenary correction formula is a useful tool in engineering and design, it does have limitations. It is based on the assumption that the suspended object has a uniform weight distribution, and it does not take into account external factors such as wind or weather conditions. Additionally, the formula may not be accurate for objects with a large sag or significant changes in tension.
