Homework Help: Cauchy distribution
  1. Dec 12, 2008 #1
    http://img132.imageshack.us/img132/1/48572399ly5.png [Broken]
    3. The attempt at a solution
    I tried dividing the two pdf's but that isn't right. If you have X normal and Y normal distributed how can you derive the distribution function of X/Y?
  3. Dec 12, 2008 #2
    Dick
    Of course you don't divide the pdf's. To get the quotient pdf as a function of Z, you take the dirac delta function [itex]\delta(Z-X/Y)[/itex] and integrate it times the pdf's for X and Y, dXdY.
  4. Dec 12, 2008 #3
    statdad
    Another method (based techniques typically presented early in mathematical stats) is this:
    Define these two variables (one you already have)
    [tex]
    W = \frac{Z_1}{Z_2}, \quad V = Z_2
    [/tex]
    Then
    [tex]
    Z_1 = V \cdot W, \quad Z_2 = V
    [/tex]
    By their definitions both new random variables range over [tex] (-\infty, \infty) [/tex].
    Use the basic ideas for transformation of a joint distribution to get the distribution of [tex] V [/tex] and [tex] W [/tex], then integrate out [tex] V [/tex].
  5. Aug 1, 2010 #4
    Hi,
    I'm actually going over some probability problems and I got a bit stuck in this one too.
    If you let:
    W=Z1/Z2 and V=Z2
    Then truly Z1=V*W and Z2=V
    And if you calculate the Jacobian determinant of such transformations you get:
    Jacobian determinant = V (here we take the absolute value when sticking into formula below)
    Therefore:
    f(w,v) =[PLAIN]http://www3.wolframalpha.com/Calculate/MSP/MSP91219bfg00e7b70caif00005aa636h4egb540i1?MSPStoreType=image/gif&s=39&w=148&h=44 [Broken]
    and so all you need to get the probability density function of W is to integrate the joint probability with respect to v as follows:
    First note that: d/dv (e-v2(1+w2)/2) = -v(1+w2)*e-v2(1+w2)/2
    =>[PLAIN]http://www3.wolframalpha.com/Calculate/MSP/MSP243119bff8ch835e1b7i00001639e2c5d96b97gg?MSPStoreType=image/gif&s=39&w=366&h=54 [Broken]
    and here is where I seem to be overlooking something, in order to get f(w) you must evaluate the integral from minus infinity to plus infinity and so I believe you get:
    [PLAIN]http://www3.wolframalpha.com/Calculate/MSP/MSP237019bff8ch83i380ib0000641a5786ggg043f3?MSPStoreType=image/gif&s=39&w=124&h=43 [Broken]
    Which is just plainly equal to zero, so I must've done something wrong, can anyone spot what was it? I would appreciate if someone did. Thanks.
