CDF and expectation
  1. Oct 31, 2015 #1
    Hi,
    I have trouble with the following problem:
    Gaussian random variable is defined as follows
    [tex]\phi(t) = P(G \leq t)= 1/\sqrt{2\pi} \int^{t}_{-\infty} exp(-x^2/2)dx.[/tex]
    Calculate the expected value
    [tex]E(exp(G^2\lambda/2)).[/tex]
    Hint:
    Because [itex]\phi[/itex] is a cumulative distribution function, [itex]\phi(+\infty) = 1[/itex].
    My attempt at solution:
    I start with:
    [tex] E(exp(G^2\lambda/2)) = \int^{\infty}_{-\infty}P(exp(G^2\lambda/2) \geq t)dt = \int^{\infty}_{-\infty}P(-\sqrt{2/\lambda*lnt}) \geq G \geq \sqrt{2/\lambda*lnt})dt[/tex]
    [tex]=1/\sqrt{2\pi} \int^{\infty}_{-\infty}(\int^{\sqrt{2/\lambda*lnt})}_{\sqrt{2/\lambda*lnt})}e^{-x^2/2}dx)dt.[/tex]
    Then my instinct would be to use Fubini theorem because I'd like to get rid of the integral of exp(-x^2/2) by [itex]\phi(+\infty) = 1[/itex].
    However, because both bounds are functions of t, it wouldn't work.
    Any help?
  3. Oct 31, 2015 #2
    mathman
    General formula: Let h(G) be a function of G. Let f(x) be the probability density function for G. Then:
    [itex]E(h(G))=\int_{-\infty}^{\infty}h(x)f(x)dx[/itex].
    In your case [itex]h(G)=exp(G^2 \lambda /2)[/itex] and [itex]f(x)=\frac{1}{\sqrt{2\pi}}e^{-\frac{x^2}{2}}[/itex].
    As you can see [itex]\lambda < 1[/itex] is necessary.
  4. Nov 2, 2015 #3
    Jaggis, I suggest you double-check your first equals sign.
