Cds and dvds
  • Thread starter skywolf
what is the difference between a Cd and a dvd?
i mean microscopically
are the holes smaller? different procces altogether?
Answers and Replies
Danger
251
As far as I know, the only difference is that DVD's use shorter wavelength lasers, and so the spots are closer together and there are more tracks available in the same diameter.
dduardo
Staff Emeritus
1,891
The only difference between a pressed CD and DVD is the size of the bumps/pits, depending on which side you look.
If you are comparing a CDR to a DVDR then the major difference is the photosenstive dye used. When the high power mode laser is writing to the disk the dye reacts and turns dark. When the low power mode laser is reading the light reflects back where it isn't dark and and doesn't reflect back where it is.
Finally the difference between a CDRW and DVDRW is the active alloy used. In high power mode the laser basically melts the alloy in a specific region and when the cyrstalline stucture cools off it loses its reflectivity. In a lower power mode the crystalline stucture can be reformed to become reflective again.
Danger
251
I stand corrected. Thanks, ddude. :biggrin:
DrGreg
1,216
Are there significant physical differences between DVD+R and DVD-R?
Or between DVD+RW, DVD-RW and DVD-RAM?
dduardo
Staff Emeritus
1,891
DVD+RW and DVD-RAM use a high frequency wobbled grove technique while the DVD-RW uses a lower frequency wobble. In a nutshell the high frequency wobble allows for better data integrity. The +RW and -RAM also have better error correction built in.
Related Threads on Cds and dvds
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
64K
  • Last Post
  • Last Post
