Center of Gravity and a Balanced TV Stand
  • Thread starter billycar
nvn
2,128
32
billycar: The relative stability at xp = 5.522 inch is 1.127. Therefore, the horizontal tipping force, applied at a height of 63 inch above the stand bottom surface, would be F1(5.522) = 1.127*F1min = 1.127*(17.42 lbf), for xp = 5.522 inch. Tipping is from front to back, and back to front. A negative relative stability value means F1(xp) is applied in the back-to-front direction, instead of front-to-back.
The stability at xp = -1.19 inch is currently slightly higher than at xp = 8.66 inch. You can pick the stability you prefer.
I think I'll try mounting the Pole Pipes to the back: 26 (-1.19) lbf > 24 (8.660) lbf > 20 (5.522) lbf.
This design will also keep the top and shelf space for the Audio & Video components that would be lost due to my boring holes down into the cabinet ... although I liked the design idea of the pvc pipe pressure rings allowing fixed and up/down movement of the vertical Poles.
After trying the back mounting position, I could always go to the other design.
One other observation: even though the other positions have varying degrees of stability, the overall setup is still relatively stable. F1min = 17.42 lbf is more than a subtle breeze hitting the TV ...
Oh, what is the explanation for the change of sign for F1 between 8.660 and 9.0?
nvn
2,128
32
billycar: To be rigorous, we should have written F1(8.660)/F1min = +/-1.390, instead of 1.390. xp = 8.660 inch is a transition point, where the assembly stability is exactly the same in the forward and backward directions.
Finished project. (Background artwork removed)
Enjoyed the path to arrive at a solution: rear mounting of Pipes and Poles, providing optimal stabilization, and more efficient use of Stand surface area for A/V equipment.
I might now replace the PVC with metal pipe, and rest them on 2 swivel wheels, making it easier to move from one location to another, and to simply swivel the entire setup from left to right.
Final Design
Stand Pipes using Black Iron Pipe
Casters Tap Set in Pipe Caps
TV Mount Shown in Portrait and Landscape Orientations
Related Threads for: Center of Gravity and a Balanced TV Stand
  • Last Post
  • Last Post
  • Last Post
15K
