1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Center of gravity of a car
  1. Mar 10, 2013 #1
    An automobile with a mass of 1321 kg has 3.40 m between the front and rear axles. Its center of gravity is located 1.78 m behind the front axle.
    (a) With the automobile on level ground, determine the magnitude of the force from the ground on each front wheel (assuming equal forces on the front wheels).
    (b) Determine the magnitude of the force from the ground on each rear wheel (assuming equal forces on the rear wheels)
    2. Relevant equations
    I don't think there are any?
    3. The attempt at a solution
    The way I attempted to approach this was splitting up the mass according to the center of gravity. I assumed that because the center of gravity was 1.78m behind the front axle, it would have 1.78/3.4 of the mass and the rear wheels would have (3.4-1.78)/3.4 of the mass, so I got 691.58kg for the front of the car and 629.42kg for the back of the car. Then I multiplied these by 9.8 to get force and got 6777.507N and 6168.293N, respectively. I then divided each of these values by two, because I assumed the force would be split between the two wheels. For the front of the car, I got 3388.754N per wheel, but WebAssign's telling me this isn't right. That was my only idea, so now I have no idea what to do.
  3. Mar 10, 2013 #2
    SteamKing
    Staff Emeritus
    Set up your problem in a rational way.
    you can draw a free body diagram of the car, showing the location of the c.g. in relation to the position of the wheels. Use the equations of statics to determine the reactions at the front and rear wheels.
  4. Mar 10, 2013 #3
    Isn't that just the sum of the forces and torques = 0? How could I use that?
  5. Mar 10, 2013 #4
    SteamKing
    Staff Emeritus
    You would be surprised how useful the equations of statics are.
    By the way, how did your approach work?
  6. Mar 10, 2013 #5
    PeterO
    If you consider roataion about the contact point of the front wheels, the c of m is 1.78 m away, and the back wheels are 3.4m away.
    The torque effect of the whole weight through the centre of mass must equal the torque of the rear tyre support through the tyres.
  7. Mar 11, 2013 #6
    I still don't really understand. My teacher hasn't been focusing on this very much, but it's pretty much the only thing on my homework, so I'm really lost here. I'm not looking for anyone to give me the answer, just a push in the right direction so I'll understand it.
  8. Mar 11, 2013 #7
    PeterO
    How much is torque effect of the weight of the car, with reference to the contact point of the front tyres?
  9. Mar 11, 2013 #8
    Well τ=rFsinθ, so is r the distance from the front tire to the center of gravity, and F just the mass of the car times gravity?
  10. Mar 11, 2013 #9
    PeterO
    Correct - that is what r is, and that is what F is, but I asked what the torque was.
  11. Mar 11, 2013 #10
    PeterO
    Perhaps your formula might look more hepful if you wrote it is τ = F.rsinθ
  12. Mar 11, 2013 #11
    Well Fr is 23043.524, but I'm a little confused on the angle. The angle between the distance r and the force due to the weight is just 90, right? So would the torque then be 23043.524?
  13. Mar 11, 2013 #12
    PeterO
    I don't see how you can calculate Fr - you don't know r, but you can determine rsinθ [or should it actually be rcosθ? depends how you define the answer.
    The CofM may be 178 cm behind but 1 m above the front wheels, so r = 204 cm.
    The CofM may be 178 cm behind but 1.5m above the front wheels, so r = 233 cm
    Of course the CofM may be 178 cm behind, and level with the front wheels, so r = 178cm
    What value of r did you use - and why? What significance does your choice have on the value of θ ?
  14. Mar 11, 2013 #13
    SteamKing
    Staff Emeritus
    It might help to pretend the car was like a seesaw. The board of the seesaw is 3.4 m long. The balance point is located at the center of gravity of the car, or 1.78 m from one end.
    What forces, when applied to the ends of the board, will cause the seesaw to balance?
  15. Mar 11, 2013 #14
    PeterO
    Yes the torque would be, I was just trying to get you to explain why.
    So the torque from the rear wheels has to be that same value, but in the opposite direction.
    SO what Force has to act through the rear wheels [you know the radius].
    To find the force through the front wheels you can either repeat the torque calculations using the rear wheels as the pivot point, or just consider the total up force has to match the total down force.
  16. Mar 11, 2013 #15
    I had my physics class today so I got there a little early and went to ask my teacher, we revisited what SteamKing was saying about the static equilibrium. He talked me through how the two torques had to balance each other out, like what PeterO just said. I realize I appear pretty clueless here, my teacher hasn't been lecturing much during this unit so I was pretty lost. After he marked my free-body diagram a little, I understood what you guys were saying much more easily. Many thanks to both of you!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Center of gravity of a car
  1. Center of gravity (Replies: 2)
  2. Center of gravity? (Replies: 3)
  3. Centers of gravity (Replies: 1)
  4. Center of gravity (Replies: 3)
Loading...
