Calculating the Position of Center of Gravity for a Slender Rod Satellite
In summary: Is this just a coincidence, or is there a reason you chose to write it that way?The Attempt at a SolutionI changed to a length integral (half of the bar multiplied by 2), and have this:##F = 2 \int_{\rho_C}^{\sqrt{\rho_C^2+l^2/4}} \frac{\mu Mmd \rho }{l \rho^2} ##using the fact that ##dm = \frac{m}{l} d\rho##I'm not confident
sun18
Consider a slender rod satellite in a circular orbit. Show that the position of the center of gravity, ##\rho_G##, can be written in terms of the position of the center of mass, ##\rho_C##, as: ##\rho_G = \rho_C (1+\frac{l^2}{4\rho_C^2})^\frac{1}{4} ##, where ## l## is the length of the rod.
I'm not sure how to best describe this, but the rod is oriented like this, perpendicular to the position vector:
##\rho_C##--------------------##\rho##-----------------------M
I know the total force on the rod acts on the CoG:
## F = \frac{\mu mM}{\rho_G^2} ##
m is the total mass of the bar, M is the mass of the attracting body, ##\rho## is a position vector.
I need to set this force equal to an integral, which I believe goes something like this:
## F = \int_{0}^{m} \frac{\mu M dm}{\rho^2} ##
I'm not confident that this is correct, as I can't seem to get the right answer. Something seems off about this integral, but I'm not sure what.
Can you define the terms?
ρ = position vector = distance from the Earth's center of mass M to any arbitrary point?
ρC = distance from the Earth's center of mass M to the cylinder's center of mass m?
ρG = distance from the Earth's center of mass M to the cylinder's center of gravity?
Are you sure the cylinder is oriented perpendicular to the position vector?
You are correct on all three accounts:
ρ is the position vector from the Earth's center (mass M), to the infinitesimal mass element dm.
ρc is the distance from Earth's center to the rod's (mass m) center of mass
ρG is the distance from Earth's center to the rod's center of gravity.
And yes, the rod is perpendicular to the position vector. The first part of the problem had the rod aligned "vertically" with respect to the surface of the earth. In this case, it is perpendicular.
OK, then it looks like what you are doing is taking ρ from ρC to one end of the rod in your integral and then using symmetry to double it.
I am not sure that you can do this since this would give you the same center of gravity as a parallel rod with length = √(ρC2+(L/2)2) -ρC. Maybe it works out to be the same.
Could you instead take the angle θ and create an integral from θ=0 to L/(2ρC) ?
Hm I hadn't thought about using the angle. I will give that a try tomorrow and report back. Thanks for the responses by the way, I really appreciate it.
Doesn't look right to me. Working with the angle should make it clearer.
I think that's ok.
dm=m/l dρ
Seems OK to me. m/l is the density of the rod.
paisiello2 said:
dm=m/l dρ
Sure, but ρ is the distance from Earth's centre, not a distance along the rod.
But dρ is along the length of the rod.
Eh?! dρ is a change in distance from Earth's centre as we move along an element of the rod. That will not be the same as the length of the element.
Yes, of course, you're right. I was thinking for a moment the rod was parallel.
That's probably why he was getting the wrong answer.
Hello sun18,
It's an interesting problem, for sure! Anyway I worked through it and there are two mistakes in your general approach and perhaps another quibble about your notational semantics. I'll start with notation part.
Not bad so far. But let me comment on the notation.
Newton's universal law of gravitation for point mass particles is often expressed as, using [itex] \vec \rho [/itex] as the displacement vector,
[tex] \vec F = G \frac{Mm}{\rho^2} \ \hat \rho [/tex]
That said, it's often expressed using [itex] \mu = GM [/itex] as
[tex] \vec F = \frac{\mu m}{\rho^2} \hat \rho [/tex]
where [itex] \mu [/itex] is called the "standard gravitational parameter" and has the mass of the gravitating body (often Earth when dealing with things orbiting Earth) folded into it along with Newton's gravitational constant.
In the notation you were using, you've simply replaced [itex] G [/itex] with [itex] \mu [/itex], but didn't fold [itex] M [/itex] into it. The notation that I've seen most often has [itex] M [/itex] folded into the [itex] \mu [/itex], along with the [itex] G [/itex].
Of course, this is all just notational semantics, and isn't important on the grand scheme of things. But for what it's worth, I thought I should mention it.
There's one problem right there.
The change in mass does not vary linearly with the change in [itex] \rho [/itex] in this case. It does vary linearly in the case where the rod is parallel to the displacement vector; in that case it would work fine. But here, with the rod perpendicular to the displacement vector, it does not hold true.
Let's define [itex] x [/itex] as the distance from [itex] \rho_c [/itex] to some point along the rod. So you can say easily,
[tex] dm = \frac{m}{\ell} dx [/tex]
You should be able to form a relationship between [itex] x [/itex] and [itex] \rho [/itex] knowing that they form a right triangle. [itex] \rho^2 = \rho_c^2 + x^2 [/itex].
Now for the second problem: you are forgetting about the pesky unit vector [itex] \hat \rho [/itex].
In the case where the rod was parallel to the position vector, the direction of the force wasn't important; the force on every individual [itex] dm [/itex] all pointed in the same direction, so the unit direction vector didn't really matter. But in this case, where the rod is perpendicular, the each of the individual force directions are different.
You need to break up the [itex] \hat \rho [/itex] into its x- and y-components. It's in the form, [itex] \hat \rho = a_x \hat x + a_y \hat y [/itex]. Due to symmetry you know that the horizontal (x-) components will all ultimately cancel. But the y-components will not. You need to put that into your expression: The way you express the unit vector for a given [itex] dm [/itex] should be should be a function of [itex] \rho_c [/itex] and [itex] x [/itex]. [Edit: or alternatively, express things in polar coordinates involving an angle. Either way will work, as long as you take directionality into account one way or the other.]
Good luck! :wink:
[Edit: Looks like @haruspex and others beat me to the punch. I suppose I should either type faster or write shorter. :smile:]
Oh right of course, my mistake. I was forgetting that μ absorbs G and M. Luckily it should end up cancelling out anyways.
I had a feeling that the directionality was non-trivial. The first part of the problem had the rod colinear with the displacement vector ρ, so it didn't matter then.
So I had the integral ## \vec{F} = 2 \int_{\rho_C}^{\sqrt{\rho_C^2+l^2/4}} \frac{\mu md\rho}{l\rho^2}\hat{\rho} ##
Using ## \rho^2 = \rho_C^2 + x^2 ##, ## \vec{\rho} = \rho_C \hat{y} + x\hat{x}##, ## \hat{\rho} = \vec{\rho}/\rho ##, and changing the bounds of my integral, I have
## \vec{F} = \int_{-l/2}^{l/2} \frac{\mu mdx}{l\rho^2}\hat{\rho} ## (I didn't replace the ρ's yet for brevity)
I evaluated the integral, and as you said, the ##\hat{x}## components cancel, and I'm left with this integral:
## \frac{\mu m \rho_C \hat{y}}{l} \int_{-l/2}^{l/2} \frac{dx}{(\rho_C^2+x^2)^{\frac{3}{2}}} ##
**EDIT: Yep! This got me the right answer. It's a tricky integral to do, I wonder if it's easier to do in polar coordinates?
Thanks again for all the responses, I appreciate it!
Likes collinsmark
1. What is the center of gravity of a slender rod?
The center of gravity of a slender rod is the point at which the entire weight of the rod can be considered to be concentrated. It is the point at which the rod would balance if suspended at that point.
2. How is the center of gravity of a slender rod calculated?
The center of gravity of a slender rod can be calculated by dividing the length of the rod in half and measuring from one end to the center of the rod. Alternatively, it can also be calculated by using the formula: x = L/2 * cosθ, where x is the distance from one end of the rod to the center of gravity and θ is the angle between the rod and the horizontal plane.
3. Why is the center of gravity important for a slender rod?
The center of gravity is important for a slender rod because it affects the stability and balance of the rod. If the center of gravity is not located at the base of the rod, it can cause the rod to topple over or become unstable, making it difficult to control or use.
4. How does the mass distribution of a slender rod affect its center of gravity?
The mass distribution of a slender rod greatly affects its center of gravity. The more evenly distributed the mass is along the rod, the closer the center of gravity will be to the center of the rod. However, if the mass is mostly concentrated at one end of the rod, the center of gravity will be closer to that end.
5. Can the center of gravity of a slender rod be moved?
Yes, the center of gravity of a slender rod can be moved by changing the mass distribution of the rod. For example, if additional weight is added to one end of the rod, the center of gravity will shift towards that end. This can also be achieved by changing the angle or position of the rod.
