atavistic
- 106
Is it different from the center of mass? My book says yes but doesn't answer the question.
The center of gravity refers to the point at which the entire weight of an object is concentrated and acts as if it were a single force. The center of mass, on the other hand, refers to the point at which an object is perfectly balanced and has equal distribution of mass in all directions.
While these terms have different definitions, they are often used interchangeably because in most situations, the center of gravity and center of mass are located at the same point within an object.
The center of mass can be calculated by finding the weighted average of the individual masses of the object's components. This can be done by multiplying the mass of each component by its distance from a chosen reference point and then dividing the sum of these values by the total mass of the object.
The center of gravity is important in physics because it affects the stability and equilibrium of an object. A low center of gravity provides better stability, while a high center of gravity makes an object more prone to tipping over.
Yes, the center of mass can be outside of an object if there is an external force acting on the object. This can cause the object to rotate or shift, resulting in the center of mass being located outside of the physical boundaries of the object.
